LINX 3.0 – 06 | Deploying A Startup Executable
This tutorial describes the process of creating a startup executable from a VI and deploying it to run each time the LINX device starts.
  • Open the LabVIEW project created in the previous tutorial.
  • Expand the LINX target (BBB or RPI).
  • Right
    Build Specifications
    and choose
    New»Real-Time Application
  • Rename the build specification.
  • Click the
    Source Files
    section on the left side of the dialog.
  • Under
    Project Files
    select the top level VI (Blink.vi in the example) and click the right arrow to add it to
    Startup VIs
  • Click OK.
  • Right click the new build specification and choose
    Build
  • Click
    Done
    Run as Startup
  • Click
    Yes
    to reboot the target.
  • The VI will now run whenever the target is powered on.
