A simple synthesizer with a metronome and recording/loop playback based on the PocketBeagle
This project is about 2 capes to enable Ardupilot to Run in the BBIA. One is to use the BBBMini cape and the second is a new cape
A laser harp using 5V laser diodes and a PocketBeagle. Play musical notes just by waving your hand!
This guide will show you how to make a physical interface for LabVIEW.
We finished the Cobra MiniSumo chassis build in part 1 of this project. Let's add some brain power this time.
I made a Magic 8 Ball to make all my important decisions for me by attaching MPU 9DOF and OLED C clicks to a BeagleBoard.org PocketBeagle.
A simple guide for consuming Artiik Cloud API from Chrome using Postman Extension
Reading is keen, photoresistors are nice, and educating on Ideas from Books are both!
Have you ever wanted to set up an HTML email via Perl on the BBB w/ some gmail and to whomever you would like to send an email in mind?
This project is about using siri command to control beaglebone which can drive a servo to point camera to the target.
Texas Instruments (TI) ZigBee Home Automation Gateway reference design
Drive some geared, DC motors via 12vDC lead acid battery w/ the BBGW, Sabertooth 2 x 12, and a Motor Bridge Cape attached!
This will walk you through how to use the PCB Ruler to measure things that are longer than the maximum measuring capacity of the ruler.
This is a fun beginner-level project using PocketBeagle to record and play audio recordings!
Did you ever want to learn something but it seemed impossible b/c of too many articles on the subject or not enough? BBBW!
Did you want to see different aspects in a visual manner w/out Matplotlib or Numpy on ARM devices?
This project merges the electrical control board and chassis of an RC car into one!
Throwing some motors are okay but making them go with the LoadCape is much more sophisticated.
Build fbtft drivers for Linux 4.4 kernel so that BeagleBone Black can use TFT LCD connected via SPI as Framebuffer
I really need a way to use my 3D printed castle, so here’s the project, where LEDs dance with music!
Did you ever want to make a tiny (extra large) bot w/ some motors and the Motor Bridge Cape and the BeagleBone Green Wireless?
This item can show you when you door has been opened, closed, and if the door has stayed open for an allotted amount of time.
BeagleBone Black: read rotary encoder position using built-in TI eQEP hardware module
The GPIOD in the BeagleBone Black relies on Python wrappers to work. Our project allows Python code to work with the GPIOD directly.
