This little platform is designed for low-latency audio projects, building upon the tiny PocketBeagle computer.
An IoT hardware solution to make an old HVAC unit energy efficient. And quieter, too!
Create your own headless music player with the PocketBeagle and Mopidy!
Using a BeagleBone Black, this coffee temperature detector works in an Internet of Things to create a comprehensive and useful display.
This article is about porting the Turnigy Fabrikator Mini from HobbyKing to Machinekit. It explains the basics of porting a new 3D printer.
Hello... did you ever want to set up a gaussian distribution on your BeagleBoard. org family of boards, e.g. the BBAI?
Find out how to install Mono on your Raspberry Pi with the help of ExaGear Desktop and Wine. Detailed step-by-step instruction.
Create your very own full-size Star Wars BB-8 self-balancing robot using these instructions.
Often web server access to remote devices behind a firewall is needed (Wifi router, smart home). This is how you can solve this securely.
This tutorial describes the process of setting up a BeagleBone Black as a LabVIEW target using LINX.
Create an automatic light switch using a simple servo, PocketBeagle board, and Adafruit PIR motion sensor!
Tech out your Halloween Pumpkin with PocketBeagle from BeagleBoard.org This low cost embedded 1GHz Linux PC is fun and easy to learn.
A cape for the PocketBeagle that provides 6 HUB75 output connectors for driving standard P10/P5 panels.
Management system for rental cottage.
Write a C# App for Beaglebone. Access GPIO & AIN ports and store on Azure using WindowsAzur. Storage lib. Use remote debugging from VS 2017.
Do you like Linux/Embedded Linux? Do you like IoT? What about using SigFox in your Linux IoT projects?
Control your spice rack using your voice!
Example for using BeagleBone, Mikroelektronika Barometer click and Python
This tutorial describes the process of setting up the development software (LabVIEW and LINX) on the host PC.
Making some motors move for starters w/ Flask, Python, HTML, Bootstrap, and things! Enjoy!
This project enables ioT applications for your camper van. The central control unit consist of a Python GUI on a BBB.
Add a touch interface to the steering wheel of any car to control music on your phone!
Create LabVIEW Web Services to provide an easy way to connected your embedded LabVIEW application to browser based GUI.
Did you ever want to know if you were moving while you slept?
