Looking to access your Raspberry Pi or Jetson nano remotely? This guide will help you access VNC & SSH over network in 2 minutes!
Did you want to change from ARM to RISC-V Processing and did not know how to make the jump? BeagleV!
Did you want linuxCNC to work and make it work w/ the BBG? You came to the right place!
Hey! Did you ever want to look at yourself, or do real work, with thermal imagery? FLIR! Oh and use the external libs. for additional ideas!
3d area scanner utilizing off the shelf and 3d printed parts and components.
Try to use your Adafruit-BBIO lib. with your BeagleBone Green Gateway to limit some DC Motors and/or Stepper Motors!
Beaglebone based Alarm Clock with weather + remote alarm
This project is about using siri command to control beaglebone which can drive a servo to point camera to the target.
Control lights and music for a Christmas wreath using a Beaglebone Black and a Blynk application!
Two-zone fan-thermometer system that records ambient temperature and displays it on a LCD screen powered by a Pocketbeagle
Boil Buddy uses a piezoelectric disc to sense vibrations in the pot as water boils and sends a text alert.
The GPIOD in the BeagleBone Black relies on Python wrappers to work. Our project allows Python code to work with the GPIOD directly.
Make a car that can be controlled by solely by voice!
Music boxes are a lot more fun when you can choose the song yourself!
A PocketBeagle device that alerts your phone through text when you go too far from it
Tracks and records the speed at which a golf ball falls into the hole. Provides audio and visual feedback. Also has a history display mode.
PocketBeagle based device that displays and texts user about plant's sunlight and water levels
Data Analysis For Sailing Performance, A Maker's Solution
Did you want to handle some 12v servos with your BBBW and make them available with an already completed SDK?
In this series of posts, we will explore Linux's hardware-software interface using a BeagleBoard.
My personal experience testing out features on the PocketBeagle by Beagleboard and technical knowledge I learned along the way!
In this easy project we'll connect a temperature and humidity sensor to an Arduino Uno with an Ethernet Shield and we'll use Blynk.
LoopMaster allows you to create musical melodies or riffs, regardless of skill level or knowledge using "instruments" created in-house.
In this tutorial, I will demonstrate how to use Seeed Studio Wio Terminal as a USB HMI display for BeagleBone.
