Build an autonomous vehicle using computer vision to follow a lane, stop at red, and stop at a stop sign (with ML) with BeagleBone AI-64.
GStreamer will be compiled from source to read compressed H264 video directly from an HD webcam to not waste CPU resources on a BeagleBone.
Our project is an autonomous car that will use lane tracking to follow a path and also stop in areas where the path is red.
PiTalk uses Quectel EG25-G Cat 4 module With maximum downlink and uplink speeds of 150 Mbps and 50 Mbps under LTE,
Compiling 8821AU WIFI card driver for Linux with BeagleBone Black
The BeagleBone will be controlled through the network and use a serial terminal to communicate with off-board devices such as MCU boards.
In this project, variable grip for a 6 finger augmentation device is possible through the use of a servo and potentiometer.
Did you want 16 servos in rotation all at once, well... do you?
GPS-RTK HAT for Raspberry Pi extension board with cm-level, high-precision RTK-GPS positioning
Did you want to work on the edge and learn along with a nice community?
Raspberry Pi HAT Launched, Can Detect Location with Centimeter-Level Accuracy
UHF RFID Series is Compatible with Raspberry Pi Boards, Raspberry Pi Pico, Raspberry Pi Pico W
The Automation kit is basically based on LoRa module and powered by Raspberry Pi RP2040 a 32-bit dual ARM Cortex-M0+ microcontroller
I believe that most of boys are desired to own a RC car and explore anywhere they want. Me too! So I thought of making one with my BeagleBon
Here I will share my latest creation, a wooden lamp that the color controlled by a 3-Axis Accelerator.
Distributed Indoor Air Quality analytics based on tags and open-source hardware and software with ability to integrate existing buildings.
The RangePi made it easier to connect LoRa network from anywhere at any time
A heart rate sensor that measures BPM and SPO2 and a temperature and humidity sensor. All data are displayed on the TFT touchscreen.
USB to TTL - CP2102 USB to Serial/UART with USB Type-C, Micro USB Plug
Never wonder whether you've taken your pills again - just put your hand under this medication dispenser to receive your daily dose!
Always-listening, privacy preserving voice assistant, designed to interact with IoT devices over MQTT.
Ever looked to the skies and wondered what it would be like to roam across the stars, look here to create your own 3d-printed drone!!!
Mechanical split flap displays controlled with the Pocket Beagle.
A guide to creating a simple guitar tuner in standard tuning.
