Did you want a high performance set of instrumentation/machinery via USB from your BeagleBone Black Rev. C along w/ a compiled C++ SDK?
A simple demo to show how to write an ISR on a BBB in Python running Debian.
Did you ever want your BBB to do more than make a LED light up? You are in luck!
Looking to access your Raspberry Pi or Jetson nano remotely? This guide will help you access VNC & SSH over network in 2 minutes!
Beaglebone based Alarm Clock with weather + remote alarm
This project is about using siri command to control beaglebone which can drive a servo to point camera to the target.
Control lights and music for a Christmas wreath using a Beaglebone Black and a Blynk application!
The GPIOD in the BeagleBone Black relies on Python wrappers to work. Our project allows Python code to work with the GPIOD directly.
Data Analysis For Sailing Performance, A Maker's Solution
LoopMaster allows you to create musical melodies or riffs, regardless of skill level or knowledge using "instruments" created in-house.
Often web server access to remote devices behind a firewall is needed (Wifi router, smart home). This is how you can solve this securely.
Do you like Linux/Embedded Linux? Do you like IoT? What about using SigFox in your Linux IoT projects?
This is how to access Raspberry Pi shell over the internet using any web browser from anywhere worldwide. 5 minute guide!
A BeagleBone Implimentation of Pictochat.
Using a BeagleBone Black, you can create a custom smart mirror to keep you up to date and on track in the mornings when getting ready.
This project is a wireless drone that can be controlled using the Blynk app on your phone. It has an autonomous mode that avoids objects.
Making a cheap coffee maker a smart coffee maker.
Have you ever been tired of your old hardware and wanted to upgrade with all the fixings?
Did you ever want to use a FET for switching your LED on and off?
Create your very own full-size Star Wars BB-8 self-balancing robot using these instructions.
Determine a solar power plant's power output using data from the Cloud Motion Vector (CMV) Sensor System and a model of the power plant.
Current sprinkler systems leave much to be desired, so we've designed a sprinkler system that works smarter and saves water!
Project to show how to use xChips with a BeagleBone Black through a XinaBox bridge on the interface found on the SBC.
In this project, a microcontroller-based circuit controls an LED designed with a distributed (Xbox 360) user interface.
