A wearable metronome device using vibration motors with adjustable tempo and pulse that reacts to the surrounding noise level.
Create a prototype security system with three sequential layers of security -- a dial lock, pattern lock, and keypad password!
Making a cheap coffee maker a smart coffee maker.
This project is about using siri command to control beaglebone which can drive a servo to point camera to the target.
This project takes in colors as inputs via a color wheel and outputs musical notes.
LoopMaster allows you to create musical melodies or riffs, regardless of skill level or knowledge using "instruments" created in-house.
Did you ever want to view a nice visual of a fractal image on an embedded computer with the correct source?
Beaglebone based Alarm Clock with weather + remote alarm
A PocketBeagle device that alerts your phone through text when you go too far from it
Control lights and music for a Christmas wreath using a Beaglebone Black and a Blynk application!
Try to use your Adafruit-BBIO lib. with your BeagleBone Green Gateway to limit some DC Motors and/or Stepper Motors!
Two-zone fan-thermometer system that records ambient temperature and displays it on a LCD screen powered by a Pocketbeagle
Tracks and records the speed at which a golf ball falls into the hole. Provides audio and visual feedback. Also has a history display mode.
This project shows how you can use IPv6 over Bluetooth Smart using 6LoWPAN.
