Bring a building-sized digital clock to life using 129,600 independent RGB LEDs controlled by 72 BeagleBone Greens.
Fun, getting started project with PocketBeagle, a Breadboard and components. Build an electronic version of this fun 1970's arcade game.
Did you ever want to check the coordinates of your RoverBot after completing some initial tests in the field?
Make a car that can be controlled by solely by voice!
Create a robot on Raspberry Pi (or any other ARM device) for automated trading on Forex 24/7 and at almost no costs!
In this easy project we'll connect a temperature and humidity sensor to an Arduino Uno with an Ethernet Shield and we'll use Blynk.
On-board USB host function of PocketBeagle can be extended by this "Hub-Cape" to 2/4 port!
MikroElecktronika Click Boards & Device Tree Software make extending your BeagleBoard.org PocketBeagle easy! Start with the OLED C display!
Houston weather changes drastically from day to day and I need an easy way to tell what the outdoor temperature is each day.
Adding Text-to-Speech to any PocketBeagle project is easy and fun with a USB sound card, speaker and libraries.
Anticipating our favorite time of the year with BeagleBoard. org® PocketBeagle® Christmas Countdown Display.
Easy to build and program health monitor provides heart rate, temperature and moisture readings. Uses BeagleBoard PocketBeagle.
Counter from 0 to 9 in display of 7 Segments on Beagle Board with Node.js
Use the BeagleBoard.org PocketBeagle with motion sensor to activate LEDs on your DIY "ugly Christmas" wearables. Fun and easy to learn!
Never kill a plant again with this hands-free plant babysitter that quenches your plant's thirst so you don't have to!
An IoT hardware solution to make an old HVAC unit energy efficient. And quieter, too!
In this project, a microcontroller-based circuit controls an LED designed with a distributed (Xbox 360) user interface.
Create an automatic light switch using a simple servo, PocketBeagle board, and Adafruit PIR motion sensor!
Tech out your Halloween Pumpkin with PocketBeagle from BeagleBoard.org This low cost embedded 1GHz Linux PC is fun and easy to learn.
PocketBeagle tablet device that displays the weather (highs and lows) for the day as well as the news headlines of the day.
Motion sensor + PocketBeagle light up the Holidays when visitors come to your home or office. This project's a great starter to build on.
Make a mini AC unit to keep you cool! Add MikroElektronika DC Motor & Weather Click Boards to a BeagleBoard. org® PocketBeagle®.
Have significantly more fun eating candy than grabbing it out of a bag! Extra fun if you're a Zelda fan!
A simple synthesizer with a metronome and recording/loop playback based on the PocketBeagle
