Elijah SchwartzJuan Cano DuenasFredy MartinezNayana Chandrashekara Sharma
Lane-Keeping RC Car using Beaglebone Black
Make a lane-keeping RC car using the Beaglebone Black, Linux knowledge, and Python's computer vision library OpenCV!
IntermediateShowcase (no instructions)369
Webcam
Sabrent 4 Port USB 2.0 Data Hub
USB WiFi Adapter
OpenCV
OpenCV
Lane Tracking Code
Code used to control our car
# -*- coding: utf-8 -*-
"""elec424projectWALLEE.py
Team WALL EE: Elijah Schwartz, Fredy Martinez, Nayana Chandrashekara Sharma, Juan Cano Duenas
citation:
code modifed from User raja_961, Autonomous Lane-Keeping Car Using Raspberry Pi and OpenCV. Instructables. URL: https://www.instructables.com/Autonomous-Lane-Keeping-Car-Using-Raspberry-Pi-and/
import cv2
import numpy as np
import math
import sys
#Initialize throttle
throttlePin = "P9_16" #check reference pic to locate
PWM.start(throttlePin, 7.5, 50)
#Initialize steering
steeringPin = "P9_14" #check reference pic to locate
PWM.start(steeringPin, 7.5, 50)
#Steering info
#duty cycle < 7.5 => right
#duty cycle = 7.5 => straight
#duty cycle > 7.5 => left
#PWM.set_duty_cycle(steeringPin, duty_cycle)
#Throttle info
#duty cycle = 7.5 => stop
#duty cycle > 7.5 => forward
#do not exceed duty cycle of 8
#PWM.set_duty_cycle(throttlePin, duty_cycle)
def detect_edges(frame):
    # filter for blue lane lines
    #cv2.imshow("HSV",hsv)
    lower_blue = np.array([90, 120, 0], dtype = "uint8")
    mask = cv2.inRange(hsv,lower_blue,upper_blue)
    #cv2.imshow("mask",mask)
    # detect edges
    #cv2.imshow("edges",edges)
    return edges
    height, width = edges.shape
    mask = np.zeros_like(edges)
    polygon = np.array([[
        (0, height),
        (0,  height/2),
        (width , height/2),
        (width , height),
    ]], np.int32)
    cv2.fillPoly(mask, polygon, 255)
    #cv2.imshow("roi",cropped_edges)
    return cropped_edges
    rho = 1
    theta = np.pi / 180
    min_threshold = 10
    return line_segments
def detect_stopsign(image):
    hsv = cv2.cvtColor(image, cv2.COLOR_BGR2HSV)
    #red color has two ranges in hsv
    lower_red1 = np.array([0, 70, 20])
    upper_red1 = np.array([15, 255, 255])
    lower_red2 = np.array([150, 70,20])
    upper_red2 = np.array([179,255,255])
    red_mask_lower = cv2.inRange(hsv, lower_red1, upper_red1)
    red_mask_upper = cv2.inRange(hsv, lower_red2, upper_red2)
    red_mask = red_mask_lower + red_mask_upper
    red = cv2.bitwise_and(image, image, mask = red_mask)
    total_pixels = red.size
    #if there is a significant amount of red, recognize it as a stopsign/light
    red_pixels = np.count_nonzero(red)
    percent = (red_pixels / total_pixels) * 100
    if percent > 25:
        return True
    return False
    lane_lines = []
    if line_segments is None:
        print("no line segments detected")
        return lane_lines
    height, width,_ = frame.shape
    left_fit = []
    right_fit = []
    boundary = 1/3
            if x1 == x2:
                print("skipping vertical lines (slope = infinity")
                continue
            slope = (y2 - y1) / (x2 - x1)
            intercept = y1 - (slope * x1)
            if slope < 0:
    if len(left_fit) > 0:
    if len(right_fit) > 0:
    return lane_lines
def make_points(frame, line):
    slope, intercept = line
    if slope == 0:
        slope = 0.1
    return [[x1, y1, x2, y2]]
    if lines is not None:
        for line in lines:
            for x1, y1, x2, y2 in line:
    return line_image
def display_heading_line(frame, steering_angle, line_color=(0, 0, 255), line_width=5 ):
    x1 = int(width / 2)
    y1 = height
    y2 = int(height / 2)
    return heading_image
    height,width,_ = frame.shape
    if len(lane_lines) == 2:
        mid = int(width / 2)
        y_offset = int(height / 2)
    elif len(lane_lines) == 1:
        x_offset = x2 - x1
    elif len(lane_lines) == 0:
        x_offset = 0
    return steering_angle
video = cv2.VideoCapture(0)
video.set(cv2.CAP_PROP_FRAME_WIDTH,320)
video.set(cv2.CAP_PROP_FRAME_HEIGHT,240)
##fourcc = cv2.VideoWriter_fourcc(*'XVID')
##out = cv2.VideoWriter('Original15.avi',fourcc,10,(320,240))
##out2 = cv2.VideoWriter('Direction15.avi',fourcc,10,(320,240))
lastTime = 0
lastError = 0
#proportional and derivative constants
kp = 0.05
kd = kp * 0.65
#variables used for stop sign timing
i=0
j=0
frame_count = 0
frame_num = -20
#initial speed
throttle_speed = 7.88
#lists to be extracted to make graphs
frames = []
errors = []
steering_pwms = []
throttle_pwms = []
p_response = []
d_response = []
while frame_count < 500:
    ret,frame = video.read()
    i += 1
    frames.append(i)
    frame = cv2.flip(frame,-1)
    frame = cv2.resize(frame, (60, 40)) #resize camera feed
    frame_count += 1
    #set camera
    #cv2.imshow("original",frame)
    edges = detect_edges(frame)
    lane_lines = average_slope_intercept(frame,line_segments)
    lane_lines_image = display_lines(frame,lane_lines)
    heading_image = display_heading_line(lane_lines_image,steering_angle)
    cv2.imshow("heading line",heading_image)
    #set throttle
    PWM.set_duty_cycle(throttlePin, throttle_speed)
    #detect stop sign every 3 frames and past 20 frames from last stop
    if i % 3 == 0 and i >= frame_num + 20:
        stop = detect_stopsign(frame)
        if stop == True:
          throttle_speed = 7.905 #give speed boost after stop
          print("stopped")
          frame_num = i
          j+=1
          PWM.set_duty_cycle(throttlePin, 7.5)
          time.sleep(5)
          if j == 3:
            break  #end script after three stops
          print("started")
    #PD controller
    now = time.time()
    dt = now - lastTime
    error = abs(deviation)
    errors.append(error)
    steering = 0
    proportional = kp * error
    PD = int(steering + derivative + proportional)
    steering = abs(PD)
    print("steering: " + str(steering))
    p_response.append(proportional)
    d_response.append(derivative)
    #steering logic using PD values
    new_val = 7.5
    if deviation < 9 and deviation > -9:
      print("Not Steering")
      print("Deviation: " + str(deviation))
      new_val = 7.5
      deviation = 0
      error = 0
      PWM.set_duty_cycle(steeringPin, 7.5)
    elif deviation > 15:
      print("Steering Right")
      new_val = 6 - steering/18
      print("right val: " + str(new_val))
      PWM.set_duty_cycle(steeringPin, new_val)
    elif deviation > 9:
      print("Steering right")
      new_val = 6 - steering/20
    elif deviation < -25:
      print("Steering Left")
      new_val = 8.6 + steering/13
      print("left val: " + str(new_val))
      throttle_speed = 7.91
    elif deviation < -20:
    elif deviation < -9:
      new_val = 8.1 + steering/15
    #append lists
    steering_pwms.append(new_val)
    throttle_pwms.append(throttle_speed)
    lastError = error
    lastTime = time.time()
#   out.write(frame)
#   out2.write(heading_image)
    key = cv2.waitKey(1)
    if key == 27:
#extract lists to separate file for analysis
with open("graph_data.txt", "w") as f:
  f.write("frames: \n")
  for item in frames:
    f.write("%s, " % item)
  f.write("\nerrors: \n")
  for item in errors:
  f.write("\nsteering pwms: \n")
  for item in steering_pwms:
    f.write("%s," % item)
  f.write("\nthrottle pwms: \n")
  for item in throttle_pwms:
  f.write("\np response: \n")
  for item in p_response:
  f.write("\nd response: \n")
  for item in d_response:
#close video feed and stop car
video.release()
##out.release()
##out2.release()
cv2.destroyAllWindows()
#close pins when finished
PWM.stop("P9_16")
PWM.stop("P9_14")
PWM.cleanup()
Elijah Schwartz
Elijah Schwartz
1 project • 1 follower
Juan Cano Duenas
Juan Cano Duenas
1 project • 2 followers
Fredy Martinez
Fredy Martinez
Thanks to .
