mac28Michael AnginoKevin LataNicholas Meisburger
Published © MIT
Rockee
We teach a car to stay in it's lane and stop on a dime
IntermediateShowcase (no instructions)4 hours171
Rockee
Webcam, Logitech® HD Pro
usb wifi adapter
usb hub
OpenCV
OpenCV
driver.py
This contains the lane keeping and stopping logic
import cv2
import numpy as np
import math
# This function filters out all non blue pixels and applys a canny edge detection
# filter to the resulting image
def detect_edges(frame):
    # lower limit of blue color
    lower_blue = np.array([90, 120, 0], dtype="uint8")
    # upper limit of blue color
    # this mask will filter out everything but blue
    mask = cv2.inRange(frame, lower_blue, upper_blue)
    # run canny edge detection
    return edges
# The average value of red pixels that must be reached to stop
STOP_THRESHOLD = 15.0
# This function filters out all non red pixels, and averages the resulting image to quantify the
# amount of red in the frame. Returns true if the threshold to detect a stop sign is reached.
def detect_stop_sign(frame):
    # lower red limit
    lower_red = np.array([160, 100, 0], dtype="uint8")
    # upper red limit
    upper_red = np.array([180, 255, 255], dtype="uint8")
    # filter out all non read pixels
    red_stuff = cv2.inRange(frame, lower_red, upper_red)
    # take average of red pixels
    val = np.mean(red_stuff)
    return val > STOP_THRESHOLD
# This function crops the image to just the region of interest.
    height, width = edges.shape  # extract the height and width of the edges frame
    # make an empty matrix with same dimensions of the edges frame
    mask = np.zeros_like(edges)
    # specify the coordinates of 4 points (lower left, upper left, upper right, lower right)
    polygon = np.array([[
        (0, height),
        (0,  height/2),
        (width, height/2),
        (width, height),
    ]], np.int32)
    cv2.fillPoly(mask, polygon, 255)  # fill the polygon with blue color
    return cropped_edges
# This function performs the hough transform on the image to detect the line segments in the image.
# The input should be the image after the edge detection and roi functions are called.
    rho = 1
    theta = np.pi / 180
    min_threshold = 10
    # perform hough transform
                                    np.array([]), minLineLength=5, maxLineGap=0)
    return line_segments
# This is a helper function to make points that represent a given line in the image
def make_points(frame, line):
    slope, intercept = line
    if slope == 0:
        slope = 0.1
    return [[x1, y1, x2, y2]]
# This function groups the lines detected in the image into those for the left and right lane and
# averages them to get a single line for each edge
    lane_lines = []
    if line_segments is None:
        print("no line segment detected")
        return lane_lines
    left_fit = []
    right_fit = []
    boundary = 1/3
    # set region that corresponds to lines in the left edge
    # set region that corresponds to lines in the right edge
            if x1 == x2:
                # skip vertical lines, slope = infinity
                continue
            # calculate slope
            slope = (y2 - y1) / (x2 - x1)
            # calculate intercept
            intercept = y1 - (slope * x1)
            # add edge to left or right lane lines depeding on the location of the line
            # in the frame
            if slope < 0 and x1 < left_region_boundary and x2 < left_region_boundary:
            elif x1 > right_region_boundary and x2 > right_region_boundary:
    # average the left lane lines
    if len(left_fit) > 0:
    # average the right lane lines
    if len(right_fit) > 0:
    # lane_lines is a 2-D array consisting the coordinates of the right and left lane lines
    # for example: lane_lines = [[x1,y1,x2,y2],[x1,y1,x2,y2]]
    # where the left array is for left lane and the right array is for right lane
    # all coordinate points are in pixels
    return lane_lines
# This function overlays the lane lines on the image
def display_lines(frame, lines, line_color=(0, 255, 0), line_width=6):  # line color (B,G,R)
    # Create the lines
    if lines is not None:
        for line in lines:
            for x1, y1, x2, y2 in line:
                cv2.line(line_image, (x1, y1), (x2, y2),
                         line_color, line_width)
    # add the lines to the image
    return line_image
# This function takes in the lane lines and computes the average to find the heading angle for the car.
# Returns the angle (in degrees 0..180) that the car should turn
    if len(lane_lines) == 2:  # if two lane lines are detected
        # extract left x2 from lane_lines array
        # extract right x2 from lane_lines array
        mid = int(width / 2)
        y_offset = int(height / 2)
    elif len(lane_lines) == 1:  # if only one line is detected
        x_offset = x2 - x1
    elif len(lane_lines) == 0:  # if no line is detected
        x_offset = 0
    # Compute the final angle
    return steering_angle
# This function takes in the new heading angle and overlays the resulting heading line on the image.
def display_heading_line(frame, steering_angle, line_color=(0, 0, 255), line_width=5):
    x1 = int(width / 2)
    y1 = height
    y2 = int(height / 2)
    # create the line
    # overlay the line on the image
    return heading_image
# This function sets the speed by changing the PWM value for the pin controlling the motor
def set_drive_speed(speed):
    PWM.start("P9_14", speed, 50)
# This function sets the turning angle by changing the PWM value for the pin controlling the servo motor
def set_turn_angle(angle):
    PWM.start("P8_13", angle, 50)
# This represents the default PWM value for 'straight' in the servo motor.
# It is not 7.5 to counteract slight skew in the wheels
DEFAULT_ANGLE = 7.0
# Steers the car based on a heading angle. If the angle is within +/- linear range from 0,
# then it scales the PWM value linearly within this range s.t. the change in PWM is 0 at 0 degrees, and
# max_delta at +/- linear range degrees. Outside of the linear_range degrees it defaults to the DEGAULT_ANGLE +/- max_delta
def steer(steering_angle, linear_range, max_delta):
    heading = DEFAULT_ANGLE - (deviation * (max_delta/linear_range))
    # Restrict the range of the resulting PWM value
    heading = min(heading, DEFAULT_ANGLE + max_delta)
    heading = max(heading, DEFAULT_ANGLE - max_delta)
    # log the deviation and heading
    print(deviation, heading)
    set_turn_angle(heading)
# Optional delta to increase speed by after stopping to counteract less acceleration
SPEED_DELTA = 0.0
# This class controls the car
class Driver:
    def __init__(self):
        # set the default PWM values in the pins
        set_drive_speed(7.5)
        set_turn_angle(7.5)
    # This function runs the car and performs lane keeping and stopping.
    def run(self, speed, linear_range, max_delta, show_image=False):
        # Capture the video
        self.video = cv2.VideoCapture(0)
        # scale the video feed
        self.video.set(cv2.CAP_PROP_FRAME_WIDTH, 320)
        self.video.set(cv2.CAP_PROP_FRAME_HEIGHT, 240)
        # Start the motor
            # indicates if the previous frame was at a stop sign. This is to ensure the car doesn't stop multiple times
            # at consecutive frames at a stop sign
            last_stop = False
            count = 401
            has_stopped_before = False
                if count == 30:
                    # How many frames to wait for after stopping. After 30 frames
                    # restart the motor
                    set_drive_speed(speed+SPEED_DELTA)
                count += 1 # count frames
                # get image from camera
                ret, frame = self.video.read()
                # resize image to speedup processing
                frame = cv2.resize(frame, (160, 120))
                # covert to hsv
                if detect_stop_sign(hsv):
                    # If stop sign is detected and wasn't detected in previous frame then stop
                    if not last_stop:
                        print("STOPPING")
                        last_stop = True
                        count = 0
                        if has_stopped_before:
                            # If the car has stopped before then it is at the final stop sign and it can end the
                            # control loop
                            self.release()
                            print("Finished")
                        has_stopped_before = True
                    # If no stop sign is detected mark that it has left the stop sign
                    last_stop = False
                # detect edges
                edges = detect_edges(hsv)
                # get region of interest
                # detect all lane edge lines
                lines = detect_line_segments(roi)
                # average egde lines to get lane lines
                lane_lines = average_slope_intercept(frame, lines)
                # get the steering angle
                # steer the car based on the angle
                # display the heading lines and edge lines
                output = display_lines(frame, lane_lines)
                output = display_heading_line(output, steering_angle)
                if show_image:
                    # optionally display the image. This is optional because
                    # this can slow down the processing
                    cv2.imshow('view', output)
                    key = cv2.waitKey(1)
                    if key == 27:
        # if control-c is hit then stop the car
        except KeyboardInterrupt:
            self.release()
            print("Stopped")
    # stops the car and resets PWM values and releases video.
    def release(self):
        self.video.release()
        cv2.destroyAllWindows()
        set_turn_angle(7.5)
mac28
mac28
Michael Angino
Michael Angino
Kevin Lata
Kevin Lata
Nicholas Meisburger
Nicholas Meisburger
