Tyler MontagueTremayne CurrieJakob ValdezKj Dix
Autonomous RC Car
Our system is designed to use computer vision to have an RC car follow a particular path and stop when it detects the color red.
IntermediateFull instructions provided649
Autonomous RC Car
USB Wifi Adapter
Webcam
USB Hub
Monster Energy
×2
OpenCV
OpenCV
main.py
The main lane detection code that calls on the PID code
#User raja_961, Autonomous Lane-Keeping Car Using Raspberry Pi and OpenCV. Instructables.
#URL: https://www.instructables.com/Autonomous-Lane-Keeping-Car-Using-Raspberry-Pi-and/
import cv2
import numpy as np
import math
import simple_pid
from matplotlib import pyplot as plt
prev_frame = 0
new_frame = 0
def convert_to_HSV(frame):
  cv2.imshow("HSV",hsv)
  return hsv
def detect_edges(frame):
    lower_blue = np.array([90, 50, 0], dtype = "uint8") # lower limit of blue color
    upper_blue = np.array([120, 255, 255], dtype="uint8") # upper limit of blue color
    mask = cv2.inRange(hsv,lower_blue,upper_blue) # this mask will filter out everything but blue
    # detect edges
    mask = cv2.erode(mask,None,iterations = 1)
    mask = cv2.dilate(mask,None,iterations = 1)
    edges = cv2.Canny(mask, 60, 100)
    cv2.imshow("edges",edges)
    return edges
def detect_stop(frame):
    stop = 0
    #detect red if it fits in lower and higher thresholds of read color on both ends of the color spectrum
    lower_red = np.array([0,50,50])
    upper_red = np.array([10,255,255])
    mask0 = cv2.inRange(hsv, lower_red, upper_red)
    lower_red = np.array([170,50,50])
    upper_red = np.array([180,255,255])
    mask1 = cv2.inRange(hsv, lower_red, upper_red)
    red_mask = mask = mask0+mask1
    cv2.imshow("red mask",red_mask)
    #if frame has at least 100 pixels of red then there must be a stop sign
    hasStop = np.sum(red_mask)
    if hasStop > 100:
        stop = 1
        print("Stop sign detected!")
    return stop
    height, width = edges.shape # extract the height and width of the edges frame
    mask = np.zeros_like(edges) # make an empty matrix with same dimensions of the edges frame
    # specify the coordinates of 4 points (lower left, upper left, upper right, lower right)
    polygon = np.array([[
        (0, height*(8/8)),
        (0,  height*(5/8)),
        (width , height*(5/8)),
        (width , height*(8/8)),
    	]], np.int32)
    cv2.fillPoly(mask, polygon, 255) # fill the polygon with blue color
    cv2.imshow("roi",cropped_edges)
    return cropped_edges
    rho = 1
    theta = np.pi / 180
    min_threshold = 10
                                    np.array([]), minLineLength=2, maxLineGap=1)
    return line_segments
    lane_lines = []
    if line_segments is None:
        print("no line segment detected")
        return lane_lines
    height, width,_ = frame.shape
    left_fit = []
    right_fit = []
    boundary = 1/3
            if x1 == x2:
                print("skipping vertical lines (slope = infinity)")
                continue
            slope = (y2 - y1) / (x2 - x1)
            intercept = y1 - (slope * x1)
            if slope < 0:
    if len(left_fit) > 0:
    if len(right_fit) > 0:
    # lane_lines is a 2-D array consisting the coordinates of the right and left lane lines
    # for example: lane_lines = [[x1,y1,x2,y2],[x1,y1,x2,y2]]
    # where the left array is for left lane and the right array is for right lane
    # all coordinate points are in pixels
    return lane_lines
def make_points(frame, line):
    slope, intercept = line
    if slope == 0:
        slope = 0.1
    return [[x1, y1, x2, y2]]
def display_lines(frame, lines, line_color=(0, 255, 0), line_width=6): # line color (B,G,R)
    if lines is not None:
        for line in lines:
            for x1, y1, x2, y2 in line:
    return line_image
    if len(lane_lines) == 2: # if two lane lines are detected
        _, _, left_x2, _ = lane_lines[0][0] # extract left x2 from lane_lines array
        _, _, right_x2, _ = lane_lines[1][0] # extract right x2 from lane_lines array
        mid = int(width / 2)
        y_offset = int(height / 2)
    elif len(lane_lines) == 1: # if only one line is detected
        x_offset = (x2 - x1)*.7
    elif len(lane_lines) == 0: # if no line is detected
        x_offset = 0
    return steering_angle
def display_heading_line(frame, steering_angle, line_color=(0, 0, 255), line_width=5 ):
    x1 = int(width / 2)
    y1 = height
    y2 = int(height / 2)
    cv2.imshow("heading",heading_image)
    return heading_image
video = cv2.VideoCapture(0)
#initialize states
state = [0,0]
#initialize parameters
params = [.25,.2,0]
speedPWM = 7.5
PWM.start("P9_14",7.5, 50, 0)
#intialize variables
i = 0
check = 1
dont_check = 0
stop_num = 0
#create lists for plotting
speedPWM_list = []
steerPWM_list = []
error_list = []
der_resp_list = []
prop_resp_list = []
# The loop
  #motor only starts after 50 frames of video read
  if i > 50:
    speedPWM = 7.915
    PWM.start("P9_14",7.915, 50,0) #7.87
  ret,frame = video.read()
  #set resolution to 100x60 for each frame
  frame = cv2.resize(frame,(100,60),fx=0,fy=0, interpolation = cv2.INTER_CUBIC)
  #convert frame to hsv
  hsv = convert_to_HSV(frame)
  edges = detect_edges(hsv)
  #if check = 1, check whether there is a stop sign
  if check == 1:
    stop = detect_stop(hsv)
  #if stop sign recently seen, (last 50 frames) then dont check for a stop sign
    #count 50 frames before allowing for stop sign check
    if dont_check != 50:
      dont_check += 1
      dont_check = 0
      check = 1
  if stop == 1:
    #count the number of stop signs seen, stop the car if stop sign seen
    stop_num += 1
    speedPWM = 7.5
    PWM.start("P9_14", 7.5, 50, 0)
    check = 0
    #if second stop sign seen then car stops permanently
    if stop_num == 2:
    #car stops for 2 seconds at first stop sign
    time.sleep(2)
    #car speeds up again
    speedPWM = 7.915
    PWM.start("P9_14", 7.915, 50, 0)
    stop = 0
  #functions for getting steering angle from from blue line detection
  lane_lines = average_slope_intercept(frame,line_segments)
  lane_lines_image = display_lines(frame,lane_lines)
  steering_angle = (get_steering_angle(frame, lane_lines))
  #input steering angle into pid python file to and return steering PWM, derivative response, and proportional response
  steerPWM,der_resp,prop_resp = simple_pid.update_steer(state,-(steering_angle-90),params,5)
  #plot lane lines and steering angle
  heading_image = display_heading_line(lane_lines_image,steering_angle)
  i += 1
  #add values into their respective lists
  speedPWM_list.append(speedPWM)
  steerPWM_list.append(steerPWM)
  prop_resp_list.append(prop_resp)
  der_resp_list.append(der_resp)
  error_list.append(steering_angle - 90)
  key = cv2.waitKey(1)
  if key == 27:
#reset PWM values to rest
PWM.start("P9_14", 7.5,50,0)
PWM.start("P8_13", 7.5,50,0)
video.release()
cv2.destroyAllWindows()
#plots
plt.plot(error_list,label = "Error")
plt.plot(speedPWM_list, label = "Speed PWM")
plt.plot(steerPWM_list, label = "Steer PWM")
plt.title("Error and PWM")
plt.legend(loc = 'best')
plt.savefig('ErrorAndPWM.png')
plt.clf()
plt.plot(prop_resp_list, label= "Proportional Response")
plt.plot(der_resp_list, label = "Derivative Response")
plt.title("Error and Response")
plt.savefig('ErrorAndResponse.png')
Simple_Pid
PID control used in main file
import numpy as np
import math
def update_steer(state,angle,params,v): #updates steering control
	steer = "P8_13" #pin asssinment for steering servo
	d = angle-state[0] #calculates discrete time derivative of error
	state[0] = angle #saves current error in state variable for next update
	state[1] = state[1]+angle #caululates discrete time integral of error
	action = (params[0]*angle)+(params[1]*d)+(params[2]*state[1])+0.000001 #calculates PID response
	steerpwm = w_to_command(action,v) #getspwm value of desired angular velocity
	PWM.start(steer, steerpwm, 50, 0) #commands steering
	return(steerpwm,(d*params[1]),params[0]*angle) #returns values of interest
def w_to_command(w,v): #converts angular velocity and velocity to steering PWM
	intan = 11/((v*180)/(w*math.pi))
	action =  ((np.arctan(intan)*(180/math.pi))+97.055)/13.055 #fitting function
	if action>9: #clamps output to steering range
		return 9
	if action<6:
		return 6
	return action
Tyler Montague
Tyler Montague
Tremayne Currie
Tremayne Currie
Jakob Valdez
Jakob Valdez
Kj Dix
Kj Dix
