Summer Barrette
Mood-Drawing Robot
A robot which measures the user's body temperature, decides 'happy' or 'sad', and draws either a smiley or frowny face.
IntermediateFull instructions providedOver 1 day124
Mood-Drawing Robot
BeagleBoard.org PocketBeagle
Humidity and Temperature Sensor
Adafruit Humidity and Temperature Sensor
SG90 Micro-servo motor
Dual H-Bridge motor drivers L293D
Texas Instruments Dual H-Bridge motor drivers L293D
DC Motor, 12 V
DC Motor, 12 V
×2
Tactile Switch, Top Actuated
×2
LED (generic)
LED (generic)
Resistor 1k ohm
Resistor 1k ohm
×2
Resistor 10k ohm
Resistor 10k ohm
Electrolytic Capacitor, 0.1 µF
Solderless Breadboard Half Size
Jumper wires (generic)
Soldering iron (generic)
Laser cutter (generic)
Custom parts and enclosures
Laser Cut Vector File
Block Diagram
Fritzing Diagram
Main Script, Pin Configuration, Run Script, and ReadMe
Summer Barrette
Summer Barrette
Thanks to Erik Welsh, Brian Dinh, and Jae Kim.
