Neil W.Douglas Brummund
Published © GPL3+
Extending Communications – Drone-based Radio Repeater
The "Rescue Repeater" is a drone-based radio repeater solution to allow communications to be rapidly restored or extended over the horizon.
AdvancedWork in progress5 days8,467
BeagleBoard.org PocketBeagle
Arduino Pro Mini 328 - 5V/16MHz
SparkFun Arduino Pro Mini 328 - 5V/16MHz
Hamshield Mini
Antenna - Flexible 144/440MHz Dual Band Antenna
DSD Tech Converter
Grommet, Rubber
×4
Jumper wires (generic)
KIT-HGDRONEK66
NXP KIT-HGDRONEK66
Battery - LiPo 3-Cell 11.1V
32GB microSD card (generic)
RDDRONE-FMUK66
NXP RDDRONE-FMUK66
Arduino IDE
Arduino IDE
BeagleBoard.org Debian 9.9 2019-08-03 4GB SD IoT
AX25-Tools
AX25-Apps
LIBAX25
APRX
MINICOM
YAAC APRS Software
Soldering iron (generic)
3D Printer (generic)
Breadboard, 170 Pin
Breadboard, 170 Pin
Oscilloscope - Generic
Custom parts and enclosures
Rescue Repeater - Radio Housing
This part was designed as an initial housing to test and house the electronics for the Rescue Repeater.
Rescue Repeater Wiring Diagram
Wiring diagram for all radio electronics
Rescue Repeater Software Installation & Configuration
Step-by-step directions of programming the radio electronics for the Rescue Repeater.
Rescue Repeater Code
Required scripts for programming PocketBeagle, Arduino Mini, and HamShield
Neil W.
Neil W.
1 project • 2 followers
Douglas Brummund
Douglas Brummund
1 project • 4 followers
