Daniel RothfuszLauren IvoryRashi BoseIsabelle ScottBrandon Stanley
Published © GPL3+
Autonomous path following car
This car follows a path on the ground, stops at a stop sign, and a stoplight due to the magic of vision processing on a BeagleBone Black!
IntermediateShowcase (no instructions)6 hours751
Webcam, Logitech® HD Pro
USB WiFi Adapter
4 to 1 USB Hub - Sabrent
OpenCV
OpenCV
LaneKeepingAlgorithm.py
Main code necessary for running the RC car with lane detection
import cv2
import numpy as np
import matplotlib.pyplot as plt
import math
import sys
# based on: https://www.instructables.com/Autonomous-Lane-Keeping-Car-Using-Raspberry-Pi-and/
# Throttle
throttlePin = "P8_13"
go_forward = 7.91
go_faster_addition = 0.022
go_faster_tick_delay = 80
go_faster_tick = 0  # Do not change this here. Code will set this value after seeing stop sign
dont_move = 7.5
# Steering
steeringPin = "P9_14"
left = 9
right = 6
# Max number of loops
max_ticks = 2000
# Booleans for handling stop light
passedStopLight = False
atStopLight = False
passedFirstStopSign = False
secondStopLightTick = 0
def getRedFloorBoundaries():
    Gets the hsv boundaries and success boundaries indicating if the floor is red
    :return: [[lower color and success boundaries for red floor], [upper color and success boundaries for red floor]]
    return getBoundaries("redboundaries.txt")
def isRedFloorVisible(frame):
    Detects whether or not the floor is red
    :param frame: Image
    :return: [(True is the camera sees a red on the floor, false otherwise), video output]
    print("Checking for floor stop")
    boundaries = getRedFloorBoundaries()
    return isMostlyColor(frame, boundaries)
def getTrafficRedLightBoundaries():
    Gets the traffic red light hsv boundaries and success boundaries
    :return: [[lower color and success boundaries for red light], [upper color and success boundaries for red light]]
    return getBoundaries("trafficRedBoundaries.txt")
def isTrafficRedLightVisible(frame):
    Detects whether or not we can see a stop sign
    :param frame:
    :return: [(True is the camera sees a stop light, false otherwise), video output]
    print("Checking for traffic stop")
    boundaries = getTrafficRedLightBoundaries()
def getTrafficGreenLightBoundaries():
    Gets the traffic green light hsv boundaries and success boundaries
    :return: [[lower color and success boundaries for green light], [upper color and success boundaries for green light]]
    return getBoundaries("trafficGreenboundaries.txt")
def isTrafficGreenLightVisible(frame):
    Detects whether or not we can see a green traffic light
    :param frame:
    :return: [(True is the camera sees a green light, false otherwise), video output]
    print("Checking For Green Light")
    boundaries = getTrafficGreenLightBoundaries()
def isMostlyColor(image, boundaries):
    Detects whether or not the majority of a color on the screen is a particular color
    :param image:
    :param boundaries: [[color boundaries], [success boundaries]]
    :return: boolean if image satisfies provided boundaries, and an image used for debugging
    #Convert to HSV color space
    hsv_img = cv2.cvtColor(image, cv2.COLOR_BGR2HSV)
    #parse out the color boundaries and the success boundaries
    color_boundaries = boundaries[0]
    percentage = boundaries[1]
    lower = np.array(color_boundaries[0])
    upper = np.array(color_boundaries[1])
    mask = cv2.inRange(hsv_img, lower, upper)
    output = cv2.bitwise_and(hsv_img, hsv_img, mask=mask)
    #Calculate what percentage of image falls between color boundaries
    percentage_detected = np.count_nonzero(mask) * 100 / np.size(mask)
    print("percentage_detected " + str(percentage_detected) + " lower " + str(lower) + " upper " + str(upper))
    # If the percentage percentage_detected is betweeen the success boundaries, we return true, otherwise false for result
    result = percentage[0] < percentage_detected <= percentage[1]
    if result:
        print(percentage_detected)
    return result, output
def getBoundaries(filename):
    Reads the boundaries from the file filename
    Format:
        [0] lower: [H, S, V, lower percentage for classification of success]
        [1] upper: [H, S, V, upper percentage for classification of success]
    :param filename: file containing boundary information as above
    :return: [[lower color and success boundaries], [upper color and success boundaries]]
    default_lower_percent = 50
    default_upper_percent = 100
    with open(filename, "r") as f:
        boundaries = f.readlines()
        lower_data = [val for val in boundaries[0].split(",")]
        upper_data = [val for val in boundaries[1].split(",")]
        if len(lower_data) >= 4:
            lower_percent = float(lower_data[3])
            lower_percent = default_lower_percent
        if len(upper_data) >= 4:
            upper_percent = float(upper_data[3])
            upper_percent = default_upper_percent
        lower = [int(x) for x in lower_data[:3]]
        upper = [int(x) for x in upper_data[:3]]
        boundaries = [lower, upper]
        percentages = [lower_percent, upper_percent]
    return boundaries, percentages
def initialize_car():
    # give 7.5% duty at 50Hz to throttle
    PWM.start(throttlePin, dont_move, frequency=50)
    # wait for car to be ready
    input()
    PWM.start(steeringPin, dont_move, frequency=50)
def stop():
    Stops the car
    :return: none
    PWM.set_duty_cycle(throttlePin, dont_move)
def go():
    Sends the car forward at a default PWM
    :return: none
    PWM.set_duty_cycle(throttlePin, go_forward)
def go_faster():
    Sends the car forward at a faster default PWM
    :return: none
    PWM.set_duty_cycle(throttlePin, go_forward + go_faster_addition)
def go_backwards():
    (Attempts to) send the car backwards
    :return: none
    PWM.set_duty_cycle(throttlePin, 7.1)
def detect_edges(frame):
    # filter for blue lane lines
    # cv2.imshow("HSV",hsv)
    lower_blue = np.array([90, 120, 0], dtype="uint8")
    mask = cv2.inRange(hsv, lower_blue, upper_blue)
    # cv2.imshow("mask",mask)
    # detect edges
    # cv2.imshow("edges",edges)
    return edges
    height, width = edges.shape
    mask = np.zeros_like(edges)
    polygon = np.array([[
        (0, height),
        (0, height / 2),
        (width, height / 2),
        (width, height),
    ]], np.int32)
    cv2.fillPoly(mask, polygon, 255)
    # cv2.imshow("roi",cropped_edges)
    return cropped_edges
    rho = 1
    theta = np.pi / 180
    min_threshold = 10
    return line_segments
    lane_lines = []
    if line_segments is None:
        print("no line segments detected")
        return lane_lines
    left_fit = []
    right_fit = []
    boundary = 1 / 3
            if x1 == x2:
                print("skipping vertical lines (slope = infinity")
                continue
            slope = (y2 - y1) / (x2 - x1)
            intercept = y1 - (slope * x1)
            if slope < 0:
    if len(left_fit) > 0:
    if len(right_fit) > 0:
    return lane_lines
def make_points(frame, line):
    slope, intercept = line
    if slope == 0:
        slope = 0.1
    return [[x1, y1, x2, y2]]
    if lines is not None:
        for line in lines:
            for x1, y1, x2, y2 in line:
    return line_image
def display_heading_line(frame, steering_angle, line_color=(0, 0, 255), line_width=5):
    x1 = int(width / 2)
    y1 = height
    y2 = int(height / 2)
    return heading_image
    if len(lane_lines) == 2:
        mid = int(width / 2)
        y_offset = int(height / 2)
    elif len(lane_lines) == 1:
        x_offset = x2 - x1
    elif len(lane_lines) == 0:
        x_offset = 0
    return steering_angle
def plot_pd(p_vals, d_vals, error, show_img=False):
    fig, ax1 = plt.subplots()
    t_ax = np.arange(len(p_vals))
    ax1.plot(t_ax, p_vals, '-', label="P values")
    ax1.plot(t_ax, d_vals, '-', label="D values")
    ax2 = ax1.twinx()
    ax2.plot(t_ax, error, '--r', label="Error")
    ax1.set_xlabel("Frames")
    ax1.set_ylabel("PD Value")
    ax2.set_ylim(-90, 90)
    ax2.set_ylabel("Error Value")
    plt.title("PD Values over time")
    fig.legend()
    fig.tight_layout()
    plt.savefig("pd_plot.png")
    if show_img:
        plt.show()
    plt.clf()
def plot_pwm(speed_pwms, turn_pwms, error, show_img=False):
    t_ax = np.arange(len(speed_pwms))
    ax1.plot(t_ax, speed_pwms, '-', label="Speed PWM")
    ax1.plot(t_ax, turn_pwms, '-', label="Steering PWM")
    ax2 = ax1.twinx()
    ax1.set_ylabel("PWM Values")
    plt.title("PWM Values over time")
    fig.legend()
    plt.savefig("pwm_plot.png")
    if show_img:
        plt.show()
    plt.clf()
# set up the car throttle and steering PWMs
initialize_car()
# set up video
video = cv2.VideoCapture(0)
video.set(cv2.CAP_PROP_FRAME_WIDTH, 320)
video.set(cv2.CAP_PROP_FRAME_HEIGHT, 240)
# wait for video to load
# PD variables
kp = 0.085
kd = kp * 0.1
lastTime = 0
lastError = 0
# counter for number of ticks
counter = 0
# start the engines
go()
# arrays for making the final graphs
p_vals = []
d_vals = []
err_vals = []
speed_pwm = []
steer_pwm = []
current_speed = go_forward
stopSignCheck = 1
sightDebug = False
isStopSignBool = False
while counter < max_ticks:
    ret, original_frame = video.read()
    frame = cv2.resize(original_frame, (160, 120))
    if sightDebug:
        cv2.imshow("Resized Frame", frame)
    # check for stop sign/traffic light every couple ticks
    if ((counter + 1) % stopSignCheck) == 0:
        # check for stop light
        if not passedStopLight and not atStopLight:
            trafficStopBool, _ = isTrafficRedLightVisible(frame)
            print(trafficStopBool)
            if trafficStopBool:
                print("detected red light, stopping")
                stop()
                atStopLight = True
                continue
        # check for the first stop sign
        elif passedStopLight and not passedFirstStopSign:
            isStopSignBool, floorSight = isRedFloorVisible(frame)
            if sightDebug:
                cv2.imshow("floorSight", floorSight)
            if isStopSignBool:
                print("detected first stop sign, stopping")
                stop()
                time.sleep(2)
                passedFirstStopSign = True
                # this is used to not check for the second stop sign until many frames later
                secondStopSignTick = counter + 200
                # now check for stop sign less frequently
                stopSignCheck = 3
                # add a delay to calling go faster
                go_faster_tick = counter + go_faster_tick_delay
                print("first stop finished!")
        # check for the second stop sign
        elif passedStopLight and passedFirstStopSign and counter > secondStopSignTick:
            isStop2SignBool, _ = isRedFloorVisible(frame)
            print("is a floor stop: ", isStopSignBool)
            if isStop2SignBool:
                # last stop sign detected, exits while loop
                print("detected second stop sign, stopping")
                stop()
    # makes car go faster, helps it have enough speed to get to the end of the course
    if isStopSignBool and counter == go_faster_tick:
        print("Going FASTER")
        go_faster()
        current_speed += go_faster_addition
    # look for green stop light while waiting after red stop light
    if not passedStopLight and atStopLight:
        print("waiting at red light")
        trafficGoBool, _ = isTrafficGreenLightVisible(frame)
        if trafficGoBool:
            passedStopLight = True
            atStopLight = False
            print("green light!")
            go()
            continue
    # process the frame to determine the desired steering angle
    # cv2.imshow("original",frame)
    edges = detect_edges(frame)
    lane_lines = average_slope_intercept(frame, line_segments)
    lane_lines_image = display_lines(frame, lane_lines)
    # heading_image = display_heading_line(lane_lines_image,steering_angle)
    # cv2.imshow("heading line",heading_image)
    # calculate changes for PD
    now = time.time()
    dt = now - lastTime
    if sightDebug:
        cv2.imshow("Cropped sight", roi)
    # PD Code
    error = -deviation
    base_turn = 7.5
    proportional = kp * error
    # take values for graphs
    p_vals.append(proportional)
    d_vals.append(derivative)
    err_vals.append(error)
    # determine actual turn to do
    turn_amt = base_turn + proportional + derivative
    # caps turns to make PWM values
    if 7.2 < turn_amt < 7.8:
        turn_amt = 7.5
    elif turn_amt > left:
        turn_amt = left
    elif turn_amt < right:
        turn_amt = right
    # turn!
    PWM.set_duty_cycle(steeringPin, turn_amt)
    steer_pwm.append(turn_amt)
    speed_pwm.append(current_speed)
    # update PD values for next loop
    lastError = error
    lastTime = time.time()
    key = cv2.waitKey(1)
    if key == 27:
    counter += 1
# clean up resources
video.release()
cv2.destroyAllWindows()
PWM.set_duty_cycle(throttlePin, 7.5)
PWM.set_duty_cycle(steeringPin, 7.5)
PWM.stop(throttlePin)
PWM.stop(steeringPin)
PWM.cleanup()
plot_pd(p_vals, d_vals, err_vals, True)
plot_pwm(speed_pwm, steer_pwm, err_vals, True)
Plain text
Color and success boundaries for computer vision to recognize traffic red light
140, 20, 100, 0.6
179, 80, 255
Plain text
Color and success boundaries for computer vision to recognize traffic green light
40 , 50, 84, 1
90, 255, 255, 100
redboundaries.txt
Plain text
Color and success boundaries for computer vision to recognize red stop sign on floor
140 , 90, 200, 0.003
200, 255, 250
Github Repo
Daniel Rothfusz
Daniel Rothfusz
1 project • 4 followers
Lauren Ivory
Lauren Ivory
1 project • 2 followers
Rashi Bose
Rashi Bose
Isabelle Scott
Isabelle Scott
1 project • 3 followers
Brandon Stanley
Brandon Stanley
Thanks to raja_961.
