Ye ZhouKostis AlexopoulosJason Zhang
Autonomous RC Car
Inspired by the Fast & Furious we built an autonomous RC car capable of staying within lane and stopping at traffic stop signs.
AdvancedFull instructions provided13
Autonomous RC Car
BeagleBone AI-64
BeagleBoard.org BeagleBone AI-64
USB WiFi Adapter
Webcam
Portable charger
Webcam, Logitech® HD Pro
4 to 1 USB Hub
OpenCV
OpenCV
main.py
# Team: Paul Walker
# Authors: Haochen(Jason) Zhang, Ye Zhou, Konstantinos Alexopoulos
# Class: COMP/ELEC 424/553
# Final Project: Autonomous RC Car
# Fall 2022
# Code drawn from:
# https://www.hackster.io/really-bad-idea/autonomous-path-following-car-6c4992
# Tiny Traffic Stop Sign Detection model used from
# https://github.com/Alzaib/Traffic-Signs-Detection-Tensorflow-YOLOv3-YOLOv4
import cv2
import numpy as np
import matplotlib.pyplot as plt
import math
import sys
import os
from tensorflow.keras.models import load_model
# Manage car behaviour
speed_encode = False
stop_at_light = False
# Encoder
encoder_path = "/sys/module/gpiod_driver/parameters/encoder_val"
encoder_target_rotation = 4046040
encoder_rotation_variance = 1500000
encoder_max_rotation = encoder_target_rotation + encoder_rotation_variance
# Camera
frame_width = 160
frame_height = 120
cam_idx = 2
sightDebug = False
# PD variables
kp = 0.07
kd = kp * 0.2
# Throttle
zero_speed = 1550000
base_speed = 1634000
speed_variance = 100
zero_turn = 1500000
go_forward = 8.18
go_faster_addition = 0.015
dont_move = 7.5
# Max number of loops
max_ticks = 240
# ML confidence
confidence_threshold = 0.3
class NotSudo(Exception):
    pass
def check_stop(video_capture, net, output_layers, ):
    '''Test: WEBCAM '''
    _, img = video_capture.read()
    '''Test: SCREEN '''
    height, width, channels = img.shape
    window_width = width
    # Detecting objects (YOLO)
    blob = cv2.dnn.blobFromImage(img, 0.00392, (416, 416), (0, 0, 0), True, crop=False)
    net.setInput(blob)
    outs = net.forward(output_layers)
    # Showing informations on the screen (YOLO)
    class_ids = []
    confidences = []
    boxes = []
    for out in outs:
        for detection in out:
            scores = detection[5:]
            class_id = np.argmax(scores)
            confidence = scores[class_id]
            if confidence > confidence_threshold:
                # Object detected
                center_x = int(detection[0] * width)
                center_y = int(detection[1] * height)
                w = int(detection[2] * width)
                h = int(detection[3] * height)
                # Rectangle coordinates
                x = int(center_x - w / 2)
                y = int(center_y - h / 2)
                boxes.append([x, y, w, h])
                confidences.append(float(confidence))
                class_ids.append(class_id)
    return 3 in class_ids
def set_speed(pwm):
    # ensure is string
    if not isinstance(pwm, str):
        pwm = str(pwm)
    # write
    with open('/dev/bone/pwm/1/a/duty_cycle', 'w') as filetowrite:
        filetowrite.write(pwm)
def set_turn(pwm):
    # ensure is string
        pwm = str(pwm)
    # write
    with open('/dev/bone/pwm/1/b/duty_cycle', 'w') as filetowrite:
def reset_car():
    set_speed(zero_speed)
    set_turn(zero_turn)
    print("Car: stopped & straightened")
def start_car():
    print("Car ready (input somethingto start)")
    input()
    set_turn(zero_turn)
    set_speed(base_speed)
def manage_speed():
    # read the file
    f = open(encoder_path, "r")
    enc = int(f.readline())
    f.close()
    # If within bounds (wait for car to start / stop)
    ret = base_speed
    if enc <= encoder_max_rotation:
        # speed encode based on percentage
        enc_pct_rotation = (enc - (encoder_target_rotation - encoder_rotation_variance)) / (2 * encoder_rotation_variance)
        ret = int(((speed_variance * 2) * abs(enc_pct_rotation - 1)) + (base_speed - speed_variance))
    return ret
def turn_car(turn_amt):
   set_turn(int(turn_amt * 200000))
def detect_edges(frame):
    # filter for blue lane lines
    lower_blue = np.array([90, 120, 0], dtype="uint8")
    mask = cv2.inRange(hsv, lower_blue, upper_blue)
    return edges
    height, width = edges.shape
    mask = np.zeros_like(edges)
    polygon = np.array([[
        (0, height),
        (0, height / 2),
        (width, height / 2),
        (width, height),
    ]], np.int32)
    cv2.fillPoly(mask, polygon, 255)
    return cropped_edges
    rho = 1
    theta = np.pi / 180
    min_threshold = 10
    return line_segments
    lane_lines = []
    if line_segments is None:
        return lane_lines
    left_fit = []
    right_fit = []
    boundary = 1 / 3
            if x1 == x2:
                continue
            slope = (y2 - y1) / (x2 - x1)
            intercept = y1 - (slope * x1)
            if slope < 0:
    if len(left_fit) > 0:
    if len(right_fit) > 0:
    return lane_lines
def make_points(frame, line):
    slope, intercept = line
    if slope == 0:
        slope = 0.1
    return [[x1, y1, x2, y2]]
    if lines is not None:
        for line in lines:
            for x1, y1, x2, y2 in line:
    return line_image
def display_heading_line(frame, steering_angle, line_color=(0, 0, 255), line_width=5):
    x1 = int(width / 2)
    y1 = height
    y2 = int(height / 2)
    return heading_image
    if len(lane_lines) == 2:
        mid = int(width / 2)
        y_offset = int(height / 2)
    elif len(lane_lines) == 1:
        x_offset = x2 - x1
    elif len(lane_lines) == 0:
        x_offset = 0
    return steering_angle
def plot_pd(p_vals, d_vals, error, show_img=False):
    fig, ax1 = plt.subplots()
    t_ax = np.arange(len(p_vals))
    ax1.plot(t_ax, p_vals, '-', label="P values")
    ax1.plot(t_ax, d_vals, '-', label="D values")
    ax2 = ax1.twinx()
    ax2.plot(t_ax, error, '--r', label="Error")
    ax1.set_xlabel("Frames")
    ax1.set_ylabel("PD Value")
    ax2.set_ylim(-90, 90)
    ax2.set_ylabel("Error Value")
    plt.title("PD Values over time")
    fig.legend()
    fig.tight_layout()
    plt.savefig("pd_plot.png")
    if show_img:
        plt.show()
    plt.clf()
def plot_pwm(speed_pwms, turn_pwms, error, show_img=False):
    t_ax = np.arange(len(speed_pwms))
    ax1.plot(t_ax, speed_pwms, '-', label="Speed PWM")
    ax1.plot(t_ax, turn_pwms, '-', label="Steering PWM")
    ax2 = ax1.twinx()
    ax1.set_ylabel("PWM Values")
    plt.title("PWM Values over time")
    fig.legend()
    plt.savefig("pwm_plot.png")
    if show_img:
        plt.show()
    plt.clf()
def main():
    seen_stop = False
    # set up video
    video = cv2.VideoCapture(cam_idx)
    video.set(cv2.CAP_PROP_FRAME_WIDTH, frame_width)
    video.set(cv2.CAP_PROP_FRAME_HEIGHT, frame_height)
    reset_car()
    # arrays for making the final graphs
    p_vals = []
    d_vals = []
    err_vals = []
    speed_pwm = []
    steer_pwm = []
    current_speed = go_forward
    # other loop-related variables
    stopSignCheck = 1
    isStopSignBool = False
    counter = 0
    lastTime = 0
    lastError = 0
    # ---------- YOLOv4-tiny init -----------
    HEIGHT = 32
    WIDTH = 32
    '''Load YOLO (YOLOv3 or YOLOv4-Tiny)'''
    net = cv2.dnn.readNet("yolov4-tiny_training_last.weights", "yolov4-tiny_training.cfg")
    classes = []
    with open("signs.names.txt", "r") as f:
        classes = [line.strip() for line in f.readlines()]
    output_layers = net.getUnconnectedOutLayersNames()
    colors = np.random.uniform(0, 255, size=(len(classes), 3))
    check_time = True
    font = cv2.FONT_HERSHEY_SIMPLEX
    start_time = time.time()
    frame_count = 0
    detection_confidence = 0.3
    '''Load Classification Model'''
    classification_model = load_model('traffic.h5') #load mask detection model
    classes_classification = []
    with open("signs_classes.txt", "r") as f:
        classes_classification = [line.strip() for line in f.readlines()]
    '''To test the AI on the webcam'''
    video_capture_logi = cv2.VideoCapture(4)
    video_capture_logi.set(cv2.CAP_PROP_FRAME_WIDTH, 160)
    video_capture_logi.set(cv2.CAP_PROP_FRAME_HEIGHT, 120)
    # start car
    start_car()
    curr_speed = base_speed
    while counter < max_ticks:
        # manage video
        ret, original_frame = video.read()
        frame = cv2.resize(original_frame, (160, 120))
        # process the frame to determine the desired steering angle
        edges = detect_edges(frame)
        lane_lines = average_slope_intercept(frame, line_segments)
        lane_lines_image = display_lines(frame, lane_lines)
        heading_image = display_heading_line(lane_lines_image,steering_angle)
        if sightDebug:
            cv2.imshow("heading line",heading_image)
        # calculate changes for PD
        now = time.time()
        dt = now - lastTime
        # PD Code
        error = -deviation
        base_turn = 7.5
        proportional = kp * error
        # take values for graphs
        p_vals.append(proportional)
        d_vals.append(derivative)
        err_vals.append(error)
        # determine actual turn to do
        turn_amt = base_turn + proportional + derivative
        turn_amt = max(turn_amt, 6)
        turn_amt = min(turn_amt, 9)
        turn_car(turn_amt)
        # speed encoding
        if speed_encode:
            if counter % 3 == 0:
                temp_speed = manage_speed()
                if temp_speed != curr_speed:
                    set_speed(temp_speed)
                    curr_speed = temp_speed
        # detect traffic light
        if stop_at_light:
            if not seen_stop and (counter % 3 == 0) :
                if check_stop(video_capture_logi, net, output_layers):
                    print("SEEN STOP")
                    seen_stop = True
                    set_speed(0)
                    time.sleep(2)
        steer_pwm.append(turn_amt)
        speed_pwm.append(current_speed)
        # update PD values for next loop
        lastError = error
        lastTime = time.time()
        key = cv2.waitKey(1)
        if key == 27:
        counter += 1
    # clean up resources
    reset_car()
    video.release()
    video_capture_logi.release()
    cv2.destroyAllWindows()
    plot_pd(p_vals, d_vals, err_vals, True)
    plot_pwm(speed_pwm, steer_pwm, err_vals, True)
if __name__ == "__main__":
    main()
gpiod_driver.c
C/C++
#include <linux/module.h>
#include <linux/of_device.h>
#include <linux/kernel.h>
#include <linux/gpio/consumer.h>
#include <linux/platform_device.h>
#include <linux/interrupt.h>
# include <linux/timekeeping.h>
# include <linux/ktime.h>
# include <linux/moduleparam.h>
* Author: Haochen(Jason) Zhang, Ye Zhou, Konstantinos Alexopoulos
* Class: COMP 424 ELEC 424/553 001
* Final Project: Autonomous Car
* Fall 2022
* Interrupt code drawn from:
* https://github.com/Johannes4Linux/Linux_Driver_Tutorial/blob/main/11_gpio_irq/gpio_irq.c
// Init variables
unsigned int irq_number;
static struct gpio_desc *my_enc;
static volatile u64 prev_time;
static volatile u64 curr_time;
static int encoder_val;
module_param(encoder_val, int, 0644);
// Interrupt Handler
static irq_handler_t gpio_irq_handler(unsigned int irq, void *dev_id, struct pt_regs *regs) {
	// Ensure time difference between interrupts is greater than 1 ms
	int enc_val = gpiod_get_value(my_enc);
	curr_time = ktime_get_ns();
	unsigned long elapsed_time = curr_time - prev_time;
	if (enc_val == 1 && elapsed_time > 1000000) {
		prev_time = curr_time;
		encoder_val = elapsed_time;
		printk(KERN_INFO "irq_handler - timing detected: %lu", elapsed_time);
	return (irq_handler_t) IRQ_HANDLED;
// probe function
static int enc_probe(struct platform_device *pdev)
	//struct gpio_desc *my_btn;
	struct device *dev;
	dev = &pdev->dev;
	printk("enc_probe - RUNNING v5\n");
	// Get button
	my_enc = gpiod_get(dev, "userbutton", GPIOD_IN);
	if(IS_ERR(my_enc)) {
		printk("enc_probe - could not gpiod_get_index 0 for btn\n");
		return -1;
	// Setup interrupt & debounce
	irq_number = gpiod_to_irq(my_enc);
	gpiod_set_debounce(my_enc, 1000000);
	if(request_irq(irq_number, (irq_handler_t) gpio_irq_handler, IRQF_TRIGGER_RISING, "my_gpio_irq", NULL) != 0){
		printk("Error!\nCan not request interrupt nr.: %d\n", irq_number);
		return -1;
	prev_time = ktime_get_ns();
	printk("enc_probe - SUCCESS\n");
	return 0;
// remove function
static int enc_remove(struct platform_device *pdev)
	free_irq(irq_number, NULL);
	printk("enc_remove - Freed interrupt & Removing\n");
	return 0;
static struct of_device_id matchy_match[] = {
    { .compatible = "hello", },
// platform driver object
static struct platform_driver adam_driver = {
	.probe	 = enc_probe,
	.remove	 = enc_remove,
	.driver	 = {
	       .name  = "The Rock: this name doesn't even matter",
	       .owner = THIS_MODULE,
	       .of_match_table = matchy_match,
module_platform_driver(adam_driver);
MODULE_DESCRIPTION("424\'s finest");
MODULE_AUTHOR("GOAT");
MODULE_LICENSE("GPL v2");
MODULE_ALIAS("platform:adam_driver");
BONE-PWM0.dts.txt
C/C++
// SPDX-License-Identifier: GPL-2.0
 * Copyright (C) 2022 BeagleBoard.org - https://beagleboard.org/
 * https://elinux.org/Beagleboard:BeagleBone_cape_interface_spec#PWM
/dts-v1/;
/plugin/;
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/board/k3-j721e-bone-pins.h>
 * Helper to show loaded overlays under: /proc/device-tree/chosen/overlays/
&{/chosen} {
	overlays {
		BONE-PWM0.kernel = __TIMESTAMP__;
&bone_pwm_0 {
	status = "okay";
	gpio-leds {
		compatible = "hello";
		userbutton-gpios = <gpio_P8_03 GPIO_ACTIVE_HIGH>;
Ye Zhou
Ye Zhou
Kostis Alexopoulos
Kostis Alexopoulos
Jason Zhang
Jason Zhang
