# -*- coding: utf-8 -*-
Main Game Script
License:
Copyright 2021 Oscar Soto
Software API:
SPI_DISPLAY()
- Provide i2c bus that dispaly is on
- Provide i2c address for the display
blank()
- Fills the display with black (i.e. color (0,0,0))
fill(color)
- Fills the display with the given (R, G, B) color tuple
image(filename, rotation=90)
- Erases display and shows image from filename
text(value, fontsize=24, fontcolor=(255,255,255), backgroundcolor=(0,0,0),
justify=LEFT, align=TOP, rotation=90):
- Erases display and shows text value on display
- Value can either be a string or list of strings for multiple lines of text
update_image(filename,rotaiton)
- Coordinates with the GPIO button to update the position of the image on the
SPI display. The image will move from the left end of the screen to the right end.
HT16K33()
- Class to manage a HT16K33 I2C display
setup()
- Initialize the HEX Display with commands from the os library
encode()
- Encode data to TM1637 format.
- This function will convert the data from decimal to the TM1637 data
set_digit()
- uses the os library to set the digits on the HEX Display
set_digit_raw(digit_number, data, double_point=False):
- Update the given digit of the display using raw data value
set_colon(enable):
- Set the colon on the display.
- Allows you to add a colon on the HEX display
blank():
- Clear the display to read nothing
clear():
- Clear the display to read '0000'
update(value):
- Update the value on the HEX display.
- This function will clear the display and then set the appropriate digits
- param value: Value must be between 0 and 9999.
- Will throw a ValueError if number is not between 0 and 9999.
text(value):
- UpdateS the value on the display with text
- :param value: Value must have between 1 and 4 characters
- Will throw a ValueError if there are not the appropriate number of
characters or if characters are used that are not supported.
cleanup():
# Clean up the HEX display to a message so that we know it's done
BuzzerSound():
- Class to manage the 5V piezo buzzer
play_tone(frequency, length):
- Plays a given note for a given length
end():
- Terminates the note played by play_tone
Background Information:
Links:
- https://learn.adafruit.com/adafruit-2-8-and-3-2-color-tft-touchscreen-breakout-v2/overview
- https://learn.adafruit.com/adafruit-2-8-and-3-2-color-tft-touchscreen-breakout-v2/spi-wiring-and-test
- https://learn.adafruit.com/adafruit-2-8-and-3-2-color-tft-touchscreen-breakout-v2/python-wiring-and-setup
- https://learn.adafruit.com/adafruit-2-8-and-3-2-color-tft-touchscreen-breakout-v2/python-usage
- https://circuitpython.readthedocs.io/projects/rgb_display/en/latest/api.html#module-adafruit_rgb_display.rgb
- https://circuitpython.readthedocs.io/projects/rgb_display/en/latest/_modules/adafruit_rgb_display/rgb.html
Software Setup:
- sudo apt-get update
- sudo pip3 install --upgrade Pillow
- sudo pip3 install adafruit-circuitpython-busdevice
- sudo pip3 install adafruit-circuitpython-rgb-display
- sudo apt-get install ttf-dejavu -y
#Import the apporiate libraries used by the script
import busio
import board
import digitalio
from PIL import Image, ImageDraw, ImageFont
from adafruit_rgb_display import color565
import adafruit_rgb_display.ili9341 as ili9341
import subprocess
import game_timer_stopwatch as GTS
import os
import sys
import math
import random
# Constants
# HEX Display Constants
LEFT = 0
RIGHT = 1
TOP = 2
BOTTOM = 3
CENTER = 4
PADDING = -5 # May need to adjust based on font
HEX_DIGITS = [0x3f, 0x06, 0x5b, 0x4f, # 0, 1, 2, 3
0x66, 0x6d, 0x7d, 0x07, # 4, 5, 6, 7
0x7f, 0x6f, 0x77, 0x7c, # 8, 9, A, b
0x39, 0x5e, 0x79, 0x71] # C, d, E, F
LETTERS = { "a" : 0x77, "A" : 0x77, # "A"
"b" : 0x7c, "B" : 0x7c, # "b"
"c" : 0x58, "C" : 0x39, # "c", "C"
"d" : 0x5e, "D" : 0x5e, # "d"
"e" : 0x79, "E" : 0x79, # "E"
"f" : 0x71, "F" : 0x71, # "F"
"g" : 0x6F, "G" : 0x6F, # "g"
"h" : 0x74, "H" : 0x76, # "h", "H"
"i" : 0x04, "I" : 0x30, # "i", "I"
"j" : 0x0e, "J" : 0x0e, # "J"
# Cannot be implemented "k" : None, "K" : None,
"l" : 0x38, "L" : 0x38, # "L"
# Cannot be implemented "m" : None, "M" : None,
"n" : 0x54, "N" : 0x54, # "n"
"o" : 0x5c, "O" : 0x3f, # "o", "O"
"p" : 0x73, "P" : 0x73, # "P"
"q" : 0x67, "Q" : 0x67, # "q"
"r" : 0x50, "R" : 0x50, # "r"
"s" : 0x6D, "S" : 0x6D, # "S"
"t" : 0x78, "T" : 0x78, # "t"
"u" : 0x1c, "U" : 0x3e, # "u", "U"
# Cannot be implemented "v" : None, "V" : None,
# Cannot be implemented "w" : None, "W" : None,
# Cannot be implemented "x" : None, "X" : None,
"y" : 0x6e, "Y" : 0x6e, # "y"
# Cannot be implemented "z" : None, "Z" : None,
" " : 0x00, # " "
"-" : 0x40, # "-"
"0" : 0x3f, # "0"
"1" : 0x06, # "1"
"2" : 0x5b, # "2"
"3" : 0x4f, # "3"
"4" : 0x66, # "4"
"5" : 0x6d, # "5"
"6" : 0x7d, # "6"
"7" : 0x07, # "7"
"8" : 0x7f, # "8"
"9" : 0x6f, # "9"
"?" : 0x53 # "?"
CLEAR_DIGIT = 0x7F
POINT_VALUE = 0x80
DIGIT_ADDR = [0x00, 0x02, 0x06, 0x08]
COLON_ADDR = 0x04
HT16K33_BLINK_CMD = 0x80
HT16K33_BLINK_DISPLAYON = 0x01
HT16K33_BLINK_OFF = 0x00
HT16K33_BLINK_2HZ = 0x02
HT16K33_BLINK_1HZ = 0x04
HT16K33_BLINK_HALFHZ = 0x06
HT16K33_SYSTEM_SETUP = 0x20
HT16K33_OSCILLATOR = 0x01
HT16K33_BRIGHTNESS_CMD = 0xE0
HT16K33_BRIGHTNESS_HIGHEST = 0x0F
HT16K33_BRIGHTNESS_DARKEST = 0x00
# No constants for the SPI display, button, or Piezo Speaker
# Functions / Classes
class SPI_Display():
""" Class to manage an SPI display """
reset_pin = None
dc_pin = None
cs_pin = None
spi_bus = None
display = None
button = None
reset_time = None
def __init__(self, clk_pin=board.SCLK, miso_pin=board.MISO, mosi_pin=board.MOSI,
cs_pin=board.P1_6, dc_pin=board.P1_4, reset_pin=board.P1_2,
baudrate=24000000, rotation=90, button="P2_2", reset_time = 3.0):
""" SPI Display Constructor
:param clk_pin : Value must be a pin from adafruit board library
:param miso_pin : Value must be a pin from adafruit board library
:param mosi_pin : Value must be a pin from adafruit board library
:param cs_pin : Value must be a pin from adafruit board library
:param dc_pin : Value must be a pin from adafruit board library
:param reset_pin : Value must be a pin from adafruit board library
:param baudrate : SPI communication rate; default 24MHz
:param rotation : Rotation of display; default 90 degrees (landscape)
# Configuration for CS and DC pins:
self.reset_pin = digitalio.DigitalInOut(reset_pin)
self.dc_pin = digitalio.DigitalInOut(dc_pin)
self.cs_pin = digitalio.DigitalInOut(cs_pin)
# Setup SPI bus using hardware SPI
self.spi_bus = busio.SPI(clock=clk_pin, MISO=miso_pin, MOSI=mosi_pin)
# Create the ILI9341 display:
self.display = ili9341.ILI9341(self.spi_bus, cs=self.cs_pin, dc=self.dc_pin,
baudrate=baudrate, rotation=rotation)
self.reset_time = reset_time
self.button = button
# Initialize Hardware
self._setup()
# End def
def _setup(self):
"""Initialize the display itself"""
# Clear the display
self.blank()
# Initialize the button
GPIO.setup(self.button, GPIO.IN)
# End def
def blank(self):
"""Clear the display a black screen"""
self.fill((0,0,0))
# End def
def fill(self, color):
"""Fill the display with the given color"""
if ((color[0] < 0) or (color[0] > 255) or
(color[1] < 0) or (color[1] > 255) or
(color[2] < 0) or (color[2] > 255)):
raise ValueError("(R,G,B) must be between 0 and 255: ({0}, {1}, {2})".format(color[0], color[1], color[2]))
self.display.fill(color565(color[0], color[1], color[2]))
# End def
def _get_dimensions(self, rotation):
"""Get display dimensions"""
# Check image rotation
if rotation % 180 == 90:
height = self.display.width # Swap height/width to rotate it to landscape!
width = self.display.height
width = self.display.width
height = self.display.height
return (width, height)
# End def
def image(self, filename, rotation=90):
"""Display the initial image on the screen"""
# Fill display with black pixels to clear the image
self.blank()
# Create image with file name
image = Image.open(filename)
# Get screen dimensions
width, height = self._get_dimensions(rotation)
im_back = Image.new("RGB",(width,height))
draw = ImageDraw.Draw(im_back)
draw.rectangle((0,0, width, height) , outline = 0, fill = (0,0,0)) #This is our configured rectangle, it is the background image (a black screen)
# Scale the image to the smaller screen dimension
image_ratio = image.width / image.height
screen_ratio = width / height
if screen_ratio < image_ratio:
scaled_width = image.width * height // image.height
scaled_height = height
scaled_width = width
scaled_height = image.height * width // image.width
image = image.resize((int(scaled_width/4), int(scaled_height/3)), Image.BICUBIC) # resizes the image so it's easier to move around
#Display the image on the background image for
im_back.paste(image,(0,80))
self.display.image(im_back)
def update_image(self,filename,rotation=90):
self.display.image(im_back) #initiates the image
# Code to update the image position with button clicks
button_count = 0
button_press_time = 0.0
while(1):
while (GPIO.input(self.button) == 1):
time.sleep(0.1)
# Record time
button_press_time = time.time()
# Wait for button release
while (GPIO.input(self.button) == 0):
time.sleep(0.1)
# Compare time to increment or reset people_count
if (time.time() - button_press_time) > self.reset_time:
image = Image.new("RGB", (width, height))
# Get drawing object to draw on image.
draw = ImageDraw.Draw(image)
draw.rectangle((0, 0, width, height), outline=0, fill=(0, 0, 0))
self.text(["Didi has clicked the detonator.","Game Over!"], justify=CENTER, align=CENTER, fontcolor = (255,0,0))
time.sleep(3)
# Will exit the game on the fail condition and display "Game Over" on the SPI Display
return
button_count = (button_count + 1)
t0 = time.time()
if button_count == 15:
im_back2 = Image.new("RGB",(width,height))
draw = ImageDraw.Draw(im_back2)
im_back2.paste(image, (60,80))
self.display.image(im_back2)
elif button_count == 30:
im_back3 = Image.new("RGB",(width,height))
draw = ImageDraw.Draw(im_back3)
im_back3.paste(image, (120,80))
self.display.image(im_back3)
elif button_count == 45:
im_back4 = Image.new("RGB",(width,height))
draw = ImageDraw.Draw(im_back4)
im_back4.paste(image, (180,80))
self.display.image(im_back4)
elif button_count == 60:
im_back5 = Image.new("RGB",(width,height))
draw = ImageDraw.Draw(im_back5)
im_back5.paste(image, (240,80))
self.display.image(im_back5)
self.text(["You stopped Didi.","WELL DONE!"], justify=CENTER, align=CENTER, fontcolor = (0,255,0))
return
# End def
def text(self, value, fontsize=18, fontcolor=(255,255,255),
backgroundcolor=(0,0,0), justify=LEFT, align=TOP,
rotation=90):
""" Update the display with text
:param value : Value can be a string or list of string
:param fontsize : Size of font
:param fontcolor : (R, G, B) tuple for the color of the text
:param backgroundcolor : (R, G, B) tuple for the color of the background
:param justify : Value in [LEFT, CENTER, RIGHT]
:param align : Value in [TOP, CENTER, BOTTOM]
:param rotation : Orientation of the display
# Debug variable
debug = False
# Check inputs:
if justify not in [LEFT, CENTER, RIGHT]:
raise ValueError("Input justify must be in [LEFT, CENTER, RIGHT]")
if align not in [TOP, CENTER, BOTTOM]:
raise ValueError("Input align must be in [TOP, CENTER, BOTTOM]")
# Determine if text value is string or list
# - Rest of function assumes value is a list of strings
if (type(value) is not list):
value = [value]
# Clear screen
self.fill(backgroundcolor)
# Get display dimensions
# Create a canvas for drawing
canvas = Image.new("RGB", (width, height))
# Get drawing object to draw on canvas
draw = ImageDraw.Draw(canvas)
# Load a TTF Font
font = ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf", fontsize)
# Get height of a character
font_height = font.getsize(" ")[1]
if (debug):
print("Canvas h = {0}".format(height))
print("Font h = {0}".format(font_height))
# Calculate number of lines supported on screen w/ font choice
num_line = height // font_height
if (debug):
print("Num Lines = {0}".format(num_line))
# Issue warning if too many lines
if (len(value) > num_line):
print("WARNING: Too many lines for font size. Truncating.")
print(" Required lines : {0}".format(len(value)))
print(" Available lines: {0}".format(num_line))
# Truncate list
del value[num_line:]
# Create list of positions for each line
text_height = len(value) * font_height # Number of lines * font height
# Get initial y position
if align == TOP:
y = 0
if align == BOTTOM:
y = height - text_height
if align == CENTER:
y = (height // 2) - (text_height // 2)
# Adjust y position by padding
y = y + PADDING
# Only print lines there is space for
for i, line in enumerate(value):
# Get width of line
line_width = font.getsize(line)[0]
# Issue warning if too many characters
if (line_width > width):
print("WARNING: Too many characters for the line. Truncating.")
print(" Required width : {0}".format(line_width))
print(" Available width: {0}".format(width))
# Truncate line
for i in range(len(line)):
line_width = font.getsize(line[:-(i+1)])[0]
if (line_width <= width):
line = line[:-(i+1)]
# Get x position
if justify == LEFT:
x = 0
if justify == RIGHT:
x = width - line_width
if align == CENTER:
x = (width // 2) - (line_width // 2)
# Draw the text
draw.text((x, y), line, font=font, fill=fontcolor)
y += font_height
# Display image
self.display.image(canvas)
# End def
# End class
class HT16K33():
""" Class to manage a HT16K33 I2C display """
bus = None
address = None
command = None
def __init__(self, bus, address=0x70):
""" Initialize variables and set up display """
self.bus = bus
self.address = address
self.command = "/usr/sbin/i2cset -y {0} {1}".format(bus, address)
self.setup(blink=HT16K33_BLINK_OFF, brightness=HT16K33_BRIGHTNESS_HIGHEST)
self.blank()
# End def
def setup(self, blink, brightness):
# i2cset -y 1 0x70 0x21
os.system("{0} {1}".format(self.command, (HT16K33_SYSTEM_SETUP | HT16K33_OSCILLATOR)))
# i2cset -y 1 0x70 0x81
os.system("{0} {1}".format(self.command, (HT16K33_BLINK_CMD | blink | HT16K33_BLINK_DISPLAYON)))
# i2cset -y 1 0x70 0xEF
os.system("{0} {1}".format(self.command, (HT16K33_BRIGHTNESS_CMD | brightness)))
# End def
def encode(self, data, double_point=False):
"""Encode data to TM1637 format.
This function will convert the data from decimal to the TM1637 data fromt
:param value: Value must be between 0 and 15
Will throw a ValueError if number is not between 0 and 15.
ret_val = 0
if (data != CLEAR_DIGIT):
if double_point:
ret_val = HEX_DIGITS[data] + POINT_VALUE
except:
raise ValueError("Digit value must be between 0 and 15.")
return ret_val
# End def
def set_digit(self, digit_number, data, double_point=False):
"""Update the given digit of the display."""
os.system("{0} {1} {2}".format(self.command, DIGIT_ADDR[digit_number], self.encode(data, double_point)))
# End def
def set_digit_raw(self, digit_number, data, double_point=False):
"""Update the given digit of the display using raw data value"""
os.system("{0} {1} {2}".format(self.command, DIGIT_ADDR[digit_number], data))
# End def
def set_colon(self, enable):
"""Set the colon on the display."""
if enable:
os.system("{0} {1} {2}".format(self.command, COLON_ADDR, 0x02))
os.system("{0} {1} {2}".format(self.command, COLON_ADDR, 0x00))
# End def
def blank(self):
"""Clear the display to read nothing"""
self.set_colon(False)
self.set_digit_raw(3, 0x00)
self.set_digit_raw(2, 0x00)
self.set_digit_raw(1, 0x00)
self.set_digit_raw(0, 0x00)
# End def
def clear(self):
"""Clear the display to read '0000'"""
self.set_digit(3, 0)
self.set_digit(2, 0)
self.set_digit(1, 0)
self.set_digit(0, 0)
# End def
def update(self, value):
"""Update the value on the display.
:param value: Value must be between 0 and 9999.
if ((value < 0) or (value > 9999)):
raise ValueError("Value is not between 0 and 9999")
self.set_digit(3, (value % 10))
self.set_digit(2, (value // 10) % 10)
self.set_digit(1, (value // 100) % 10)
self.set_digit(0, (value // 1000) % 10)
# End def
def text(self, value):
""" Update the value on the display with text
if ((len(value) < 1) or (len(value) > 4)):
raise ValueError("Must have between 1 and 4 characters")
# Clear the display
self.blank()
# Set the display to the correct characters
for i, char in enumerate(value):
char_value = LETTERS[char]
self.set_digit_raw(i, char_value)
except:
raise ValueError("Character {0} not supported".format(char))
def cleanup(self):
self.set_digit(0, 13) # "D"
self.set_digit(1, 14) # "E"
self.set_digit(2, 10) # "A"
self.set_digit(3, 13) # "D"
# End class
class BuzzerSound():
pin = None
def __init__(self, pin):
self.pin = pin
# End def
def play_tone(self, frequency, length):
"""Plays a given note for a given length."""
PWM.start(self.pin, 30, frequency)
time.sleep(length)
# end def
def end(self):
PWM.stop(self.pin)
PWM.cleanup()
# End def
# End def
# End class
# Main script
if __name__ == '__main__':
delay = 2
print("Test SPI Display:")
#print("Create Display")
display = SPI_Display()
# time.sleep(delay)
# Test Functions
#print("Fill Black")
display.blank()
time.sleep(delay)
#print('Display pregame instructions')
display.text(["Didi has stolen","Dexter's nuclear detonator!"], justify=CENTER, align=CENTER)
time.sleep(delay+2)
display.text(["Stop her before it's","too late!"], justify=CENTER, align=CENTER)
time.sleep(delay)
display.text(["Press the green button to run.", "Good Luck!"], justify=CENTER, align=CENTER)
time.sleep(delay+2)
display2 = HT16K33(1, 0x70)
buzzer = BuzzerSound("P2_1")
display2.update(3)
buzzer.play_tone(330, 0.1) # Play 330 Hz for 1 second
buzzer.end()
display2.update(2)
buzzer.end()
display2.update(1)
buzzer.end()
display2.text(" GO")
buzzer.play_tone(440, 0.25)
buzzer.end()
time.sleep(0.75)
display.image("dexter.jpg")
display.update_image("dexter.jpg")
buzzer.play_tone(400,0.25)
buzzer.end()
time.sleep(3)
display.blank()
display2.cleanup()
exit()
