Michael Tang
Published © GPL3+
Programmable Music Box
Music boxes are a lot more fun when you can choose the song yourself!
BeginnerFull instructions provided5 hours752
BeagleBoard.org PocketBeagle
Adafruit Breadboard-Friendly PCB Mount Mini Speaker - 8 Ohm 0.2W
×3
SparkFun Servo - Generic Continuous Rotation (Micro Size)
Pushbutton switch 12mm
SparkFun Pushbutton switch 12mm
SparkFun 7-Segment Serial Display - Red
Female Header 8 Position 1 Row (0.1")
×2
Jumper wires (generic)
×20
Resistor 1k ohm
Resistor 1k ohm
×3
Copper Board
Soldering iron (generic)
Music Box Fritzing Schematic
Fritzing schematic for wiring up the music box (copper plate not depicted)
music_box.py
Python program that contains actual functionality of music box.
Music Box
License:
Copyright 2020 Michael Tang
Software for running a programmable music box.
Main Components used:
  - HT16K33 Display
  - 1 push button
  - 3 speakers
  - 1 Micro-size continuous rotation servo
  - Copper plate
Uses:
  - HT16K33 display library developed by Erik Welsh
  - motor.py (in folder) for running thread for continuous rotation servo
  - speaker.py (in folder) for running thread for speaker
from speaker import *
from motor import *
import Adafruit_BBIO.ADC as ADC
import threading
import ht16k33 as HT16K33
# Constants
# threshold sets what voltages our pins need to hit for a sound to be played
THRESHOLD = 500
# Global variables
# determines whether our music box is on or off; is controlled by the Button thread, and affects the MusicBox class
music_box_on = False
class MusicBox():
    # pins corresponding to each speaker, and a list for storing each speaker's threads
    speaker_0 = None
    speaker_1 = None
    speaker_2 = None
    speaker_threads = []
    # dict to store pins corresponding to each note
    note_pins = {}
    # object representing 7-segment display
    display = None
    # object representing motor
    motor = None
    motor_thread = None
    def __init__(self, speaker_0="P1_36", speaker_1="P2_3", speaker_2="P2_1", C="P1_27", D="P1_19", E="P1_21", F="P1_23", G="P1_25", A="P2_35", B="P2_36", i2c_bus=1, i2c_address=0x70, motor="P1_33"):
        Intializes variables to appropriate pins
        # initialize speaker pins
        self.speaker_0 = speaker_0
        self.speaker_1 = speaker_1
        self.speaker_2 = speaker_2
        # initialize note pins
        #self.note_pins['A'] = A
        self.note_pins['B'] = B
        self.note_pins['C'] = C
        self.note_pins['D'] = D
        self.note_pins['E'] = E
        self.note_pins['F'] = F
        self.note_pins['G'] = G
        # initialize 7-segment display
        self.display = HT16K33.HT16K33(i2c_bus, i2c_address)
        # Initialize motor pin
        self.motor = motor
        # setup all of the pins
        self._setup()
    def _setup(self):
        Sets up device for initial use
        # Initialize Display
        self.set_display_off()
        # Initialize Analog Inputs
        ADC.setup()
        # Initialize Motor
        self.motor_thread = RunMotor(self.motor)
        self.motor_thread.start()
        # Setup speaker threads into a dictionary
        self.speaker_threads = [PlayNote(self.speaker_0), PlayNote(self.speaker_1), PlayNote(self.speaker_2)]
        for thread in self.speaker_threads:
            thread.start()
    def run(self):
        Runs music box
        while(True):
            # only start running music box if button has been pressed to on
            if music_box_on:
                self.turn_on()
                # check each input pin to see if certain notes are being played (need 4 consecutive values to be high)
                on = []
                for note in self.note_pins.keys():
                    if self.check_threshold(self.note_pins[note]):
                        on.append(note)
                # only take first 3 notes detected (as we have 3 speakers)
                for i, note in enumerate(on[:3]):
                    self.speaker_threads[i].add_note(note)
            # if button is pressed to off, then turn off the music box
                self.turn_off()
    def check_threshold(self, pin):
        Checks if an input has hit under threshold voltage (ie. it is toggled on when
        voltage is low enough
        Input: analog input pin to check
        Output: true if input has hit threshold voltage
        measured = []
        # read 3 times to average out noise in pin reading
        for i in range(3):
            measured.append(ADC.read_raw(pin))
        return max(measured) <= THRESHOLD
    def set_display_on(self):
        Set display to "on"
        self.display.set_digit_raw(0, 0x6F)        # "G"
        self.display.set_digit_raw(1, 0x3F)        # "O"
        self.display.set_digit_raw(2, 0x00)        # " "
        self.display.set_digit_raw(3, 0x00)        # " "
    def set_display_off(self):
        Set display to "off"
        self.display.set_digit_raw(0, 0x3F)        # "O"
        self.display.set_digit_raw(1, 0x71)        # "F"
        self.display.set_digit_raw(2, 0x71)        # "F"
    def turn_off(self):
        Sets music box to off mode
        # set display to off
        # stop motor
        self.motor_thread.pause()
    def turn_on(self):
        Sets music box to on mode
        # set display to on
        self.set_display_on()
        # start motor
        self.motor_thread.unpause()
    def cleanup(self):
        Clean up threads
        # Stop speaker threads
        for speaker_thread in self.speaker_threads:
            speaker_thread.end()
        # Stop motor thread
        self.motor_thread.end()
        # Clean up threads
        main_thread = threading.currentThread()
        for thread in threading.enumerate():
            if thread is not main_thread:
                thread.join()
        # Set Display to show program is complete
        self.display.set_digit(0, 13)        # "D"
        self.display.set_digit(1, 14)        # "E"
        self.display.set_digit(2, 10)        # "A"
        self.display.set_digit(3, 13)        # "D"
class BoxButton(threading.Thread):
    button = None
    # False corresponds to off, True corresponds to on
    prev_state = False
    stop = False
    def __init__(self, button="P2_2"):
        Initialize thread as well as class fields to appropriate pins
        threading.Thread.__init__(self)
        self.button = button
        # Initialize button
        GPIO.setup(self.button, GPIO.IN)
    def run(self):
        Runs button by having it continuous checking for it to turn on/off
        # make sure we can set global variable
        global music_box_on
        while not self.stop:
            # check if button is pressed
            if GPIO.input(self.button) == 0:
                # if prev_state was false, then it was just turned on
                if self.prev_state == False:
                    # previous state now becomes on
                    self.prev_state = True
                    music_box_on = True
                # if prev_state was true, then it was fjust turned off
                    self.prev_state = False
                # pause for a bit so it doesn't read a single click as multiple
                time.sleep(0.2)
    def end(self):
        Stops thread
        self.stop = True
if __name__ == '__main__':
    # Initialize all objects necessary to run music box
    box = MusicBox()
    button = BoxButton()
    button.start()
        box.run()
    # program terminates upon KeyBoard Interrupt
    except KeyboardInterrupt:
        # Initiate cleanup
        box.cleanup()
        button.end()
        # Stop threads
                thread.join()
motor.py
Python file that contains class that allows continuous rotation servo to be run as a Python thread
Continuous Servo Motor Functionality
License:
Python file that contains class to operate motor servo. Intended to work using
any continuous rotation servo.
import threading
class RunMotor(threading.Thread):
    motor = None
    stop = False
    halt = True
    def __init__(self, motor):
        Initializes thread and pin connected to continuous servo motor
        self.motor = motor
    def run(self):
        Servo runs by continuuously waiting for a stop signal
        # wait for stop to be signalled
            # if halt command is given, pause the motor's operation
            if self.halt:
                PWM.stop(self.motor)
            # if stop command is given, terminate the motor's operation
            if self.stop:
    def pause(self):
        Pause the motor
        self.halt = True
    def unpause(self):
        Unpause the motor
        self.halt = False
        # start motor
        PWM.start(self.motor, 25, 400)
    def end(self):
        Stop the thread
        self.stop = True
configure_pins.sh
SH
Shell script to configure pins needed for music box to function properly
#!/bin/bash
# Msuic Box - Configure Pins
# License:
# Copyright 2020 Michael Tang
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# 1. Redistributions of source code must retain the above copyright notice, this
# list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright notice,
# this list of conditions and the following disclaimer in the documentation
# and/or other materials provided with the distribution.
# 3. Neither the name of the copyright holder nor the names of its contributors
# may be used to endorse or promote products derived from this software without
# specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
# FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
# DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
# SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
# CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
# OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# Configure pins for digital Music Box:
#   - PWM0 A / P1_36 (doesn't work for some reason)
#   - PWM0 B / P1_33 (for motor servo)
#   - PWM1 A / P2_1 (for speaker)
#   - PWM1 B / Pw_3 (for speaker)
#   - I2C1
# PWMs
config-pin P1_36 pwm    # for speaker
config-pin P1_33 pwm    # for motor
config-pin P2_01 pwm    # for speaker
config-pin P2_03 pwm    # for speaker
# I2C1 (for 7-seg display)
config-pin P2_09 i2c
config-pin P2_11 i2c
# Button
config-pin P2_02 gpio
run
SH
Shell script to run project; can be used in conjunction with Chron to allow program to run on PocketBeagle startup
#!/bin/bash
# Music Box - Run Script
# License:
# Run Music Box in /var/lib/cloud9/ENGI301/project_01
cd /var/lib/cloud9/ENGI301/project_01
./configure_pins.sh
python3 music_box.py
speaker.py
Contains class that can be used to play notes on a speaker
Speaker Sound Functionality
License:
Python threading class designed to provide speaker functionality. Designed to work
with any speaker that operates using PWM.
import threading
class PlayNote(threading.Thread):
    speaker = None
    freq_to_note = {'C' : 261, 'D' : 294, 'E' : 330, 'F' : 249, 'G' : 392, 'A' : 440, 'B': 494}
    stop = False
    notes = []
    def __init__(self, speaker):
        Initialize thread and speaker pin
        self.speaker = speaker
    def run(self):
        Keep speaker on continuous loop, waiting for a new note to play
            if self.notes:
                note = self.notes.pop(0)
                PWM.start(self.speaker, 5, self.freq_to_note[note])
                time.sleep(0.5)
                PWM.stop(self.speaker)
    def add_note(self, note):
        Adds a note to speaker's note buffer, which will be played as soon as possible
        self.notes.append(note)
    def end(self):
        Stop the thread
        self.stop = True
ht16k33.py
Class to interface with HT16K33 4-digit 7-segment display. Created by Erik Welsh.
# -*- coding: utf-8 -*-
HT16K33 I2C Library
License:
Copyright 2018 Erik Welsh
Software API:
  HT16K33(bus, address=0x70)
    - Provide i2c bus that dispaly is on
    - Provide i2c address for the display
    clear()
      - Sets value of display to "0000"
    update(value)
      - Update the value on the display.  Value must be between 0 and 9999.
Background Information:
  * Using seven-segment digit LED display for Adafruit's HT16K33 I2C backpack:
    * http://adafruit.com/products/878
    * https://learn.adafruit.com/assets/36420
    * https://cdn-shop.adafruit.com/datasheets/ht16K33v110.pdf
    * Base code (adapted below):
        * https://github.com/emcconville/HT16K33/blob/master/FourDigit.py
        * https://github.com/emcconville/HT16K33/blob/master/_HT16K33.py
        * https://github.com/adafruit/Adafruit_Python_LED_Backpack/blob/master/Adafruit_LED_Backpack/HT16K33.py
        * https://github.com/adafruit/Adafruit_Python_LED_Backpack/blob/master/Adafruit_LED_Backpack/SevenSegment.py
        * https://github.com/adafruit/Adafruit_Python_LED_Backpack/blob/master/examples/sevensegment_test.py
import os
# Constants
HEX_DIGITS                  = [0x3f, 0x06, 0x5b, 0x4f,    # 0, 1, 2, 3
                               0x66, 0x6d, 0x7d, 0x07,    # 4, 5, 6, 7
                               0x7f, 0x6f, 0x77, 0x7c,    # 8, 9, A, b
                               0x39, 0x5e, 0x79, 0x71]    # C, d, E, F
CLEAR_DIGIT                 = 0x7F
POINT_VALUE                 = 0x80
DIGIT_ADDR                  = [0x00, 0x02, 0x06, 0x08]
COLON_ADDR                  = 0x04
HT16K33_BLINK_CMD           = 0x80
HT16K33_BLINK_DISPLAYON     = 0x01
HT16K33_BLINK_OFF           = 0x00
HT16K33_BLINK_2HZ           = 0x02
HT16K33_BLINK_1HZ           = 0x04
HT16K33_BLINK_HALFHZ        = 0x06
HT16K33_SYSTEM_SETUP        = 0x20
HT16K33_OSCILLATOR          = 0x01
HT16K33_BRIGHTNESS_CMD      = 0xE0
HT16K33_BRIGHTNESS_HIGHEST  = 0x0F
HT16K33_BRIGHTNESS_DARKEST  = 0x00
# Functions / Classes
class HT16K33():
    """ Class to manage a HT16K33 I2C display """
    bus     = None
    address = None
    command = None
    def __init__(self, bus, address=0x70):
        """ Initialize variables and set up display """
        self.bus     = bus
        self.address = address
        self.command = "/usr/sbin/i2cset -y {0} {1}".format(bus, address)
        self.setup(blink=HT16K33_BLINK_OFF, brightness=HT16K33_BRIGHTNESS_HIGHEST)
    # End def
    def setup(self, blink, brightness):
        """Initialize the display itself"""
        # i2cset -y 1 0x70 0x21
        os.system("{0} {1}".format(self.command, (HT16K33_SYSTEM_SETUP | HT16K33_OSCILLATOR)))
        # i2cset -y 1 0x70 0x81
        os.system("{0} {1}".format(self.command, (HT16K33_BLINK_CMD | blink | HT16K33_BLINK_DISPLAYON)))
        # i2cset -y 1 0x70 0xEF
        os.system("{0} {1}".format(self.command, (HT16K33_BRIGHTNESS_CMD | brightness)))
    # End def
    def encode(self, data, double_point=False):
        """Encode data to TM1637 format.
        This function will convert the data from decimal to the TM1637 data fromt
        :param value: Value must be between 0 and 15
        Will throw a ValueError if number is not between 0 and 15.
        ret_val = 0
            if (data != CLEAR_DIGIT):
                if double_point:
                    ret_val = HEX_DIGITS[data] + POINT_VALUE
        except:
            raise ValueError("Digit value must be between 0 and 15.")
        return ret_val
    # End def
    def set_digit(self, digit_number, data, double_point=False):
        """Update the given digit of the display."""
        os.system("{0} {1} {2}".format(self.command, DIGIT_ADDR[digit_number], self.encode(data, double_point)))
    # End def
    def set_digit_raw(self, digit_number, data, double_point=False):
        """Update the given digit of the display using raw data value"""
        os.system("{0} {1} {2}".format(self.command, DIGIT_ADDR[digit_number], data))
    # End def
    def set_colon(self, enable):
        """Set the colon on the display."""
        if enable:
            os.system("{0} {1} {2}".format(self.command, COLON_ADDR, 0x02))
            os.system("{0} {1} {2}".format(self.command, COLON_ADDR, 0x00))
    # End def
    def clear(self):
        """Clear the display to read '0000'"""
        self.set_colon(False)
        self.set_digit(3, 0)
        self.set_digit(2, 0)
        self.set_digit(1, 0)
        self.set_digit(0, 0)
    # End def
    def update(self, value):
        """Update the value on the display.
        This function will clear the display and then set the appropriate digits
        :param value: Value must be between 0 and 9999.
        Will throw a ValueError if number is not between 0 and 9999.
        if ((value < 0) or (value > 9999)):
            raise ValueError("Value is not between 0 and 9999")
        self.set_digit(3, (value % 10))
        self.set_digit(2, (value // 10) % 10)
        self.set_digit(1, (value // 100) % 10)
        self.set_digit(0, (value // 1000) % 10)
    # End def
# End class
# Main script
    delay = 0.1
    print("Test HT16K33 Display:")
    display = HT16K33(1, 0x70)
    for i in range(0, 10):
        display.update(i)
        time.sleep(delay)
    for i in range(0, 100, 10):
        display.update(i)
        time.sleep(delay)
    for i in range(0, 1000, 100):
        display.update(i)
        time.sleep(delay)
    for i in range(0, 10000, 1000):
        display.update(i)
        time.sleep(delay)
    for value in [0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0x00]:
        display.set_digit_raw(0, value)
        time.sleep(delay)
    display.set_colon(True)
    display.clear()
    print("Test Finished.")
Music Box Project Repo
Repo that contains all code displayed above.
Michael Tang
Michael Tang
