Lisa Zhu
Published © MIT
Music Bracelet
Built on pocketbeagle with python, this bracelet can provide combined effects of vibration and LED while playing music.
IntermediateFull instructions providedOver 1 day179
Music Bracelet
WS2812 Addressable LED Strip
Digilent WS2812 Addressable LED Strip
Cut and Used 10 of the LEDs
Adafruit Level Shifter
Used to output a signal to the LED strip
Adafruit SPI Screen
Screen to display the song list
Resistor 1k ohm
Resistor 1k ohm
A 1k ohm resistor in the tool kit, used to control the button
SparkFun USB Type A Female Breakout
Connected to the usb hub and the speaker
USB Hub with Power
The hub is connected to a wall outlet to supply power for the LED strip, bluetooth adaptor and the speaker
USB Speaker
Bluetooth Adaptor
Not used in the project right now, plan to use it for a bluetooth speaker in the future
BeagleBoard.org PocketBeagle
Of course! PocketBeagle!
Jumper wires (generic)
As expected, a ton of wires
Gravity:Digital Push Button (Yellow)
DFRobot Gravity:Digital Push Button (Yellow)
A normal push button
SolidWorks
Built the bracelet in SolidWorks
Prusa 3D Printer
Printed the bracelet with a 3d printer and flexible filament
Custom parts and enclosures
CAD File for the Bracelet
This file can be 3d printed with flexible filament, and is created using solidworks
Schematics for the whole project
This schematics include:
- connections to the usb port (which is then connected to speaker)
- connections to the SPI screen and a button
- connections to the level shifter & led strip
SPI Screen Test
A test file for the SPI screen created by Erik Welsh
SPI Screen Test
License:
Copyright 2021 Erik Welsh
Test SPI Screen
import busio
import board
import digitalio
from adafruit_rgb_display import color565
import adafruit_rgb_display.ili9341 as ili9341
# Configuration for CS and DC pins:
reset_pin = digitalio.DigitalInOut(board.P2_35)
dc_pin    = digitalio.DigitalInOut(board.P2_33)
cs_pin    = digitalio.DigitalInOut(board.P2_31)
# Setup SPI bus using hardware SPI
spi = busio.SPI(clock=board.SCLK_1, MISO=board.MISO_1, MOSI=board.MOSI_1)
# Create the ILI9341 display:
display = ili9341.ILI9341(spi, cs=cs_pin, dc=dc_pin)
# Main loop:
    print("Test Display")
    # Clear the display
    display.fill(0)
    # Draw a red pixel in the center.
    display.pixel(120, 160, color565(255, 0, 0))
    # Pause 2 seconds.
    time.sleep(2)
    # Clear the screen blue.
    display.fill(color565(0, 0, 255))
    # Pause 2 seconds.
    time.sleep(2)
LED Strip Light Test
A test file for the LED strip created by Erik Welsh
License:
Based on Code from:  https://github.com/rpliu3/ENGI301/tree/master/Project_01/code
Copyright 2019 Rebecca Liu
Software API:
  * opc.client ensures that server is running so that LED string can be displayed
Background Information:
   * Base code for LED functions came from the following repositories:
        https://markayoder.github.io/PRUCookbook/01case/case.html#_neopixels_5050_rgb_leds_with_integrated_drivers_ledscape
        https://markayoder.github.io/PRUCookbook/06io/io.html#io_uio
        https://github.com/Yona-Appletree/LEDscape.git
        https://github.com/zestyping/openpixelcontrol
import opc
ADDRESS = 'localhost:7890'
# Create a client object
client = opc.Client(ADDRESS)
# Test if it can connect
if client.can_connect():
    print ('connected to %s' % ADDRESS)
    # We could exit here, but instead let's just print a warning
    # and then keep trying to send pixels in case the server
    # appears later
    print ('WARNING: could not connect to %s' % ADDRESS)
# Define Pixel String
STR_LEN=10
for i in range(STR_LEN):
    leds = [(255, 255, 255)] * STR_LEN
if not client.put_pixels(leds, channel=0):
    print ('not connected')
# Uses each light's address to set display to set a color
def task():
        print("loop")
        for i in range (0, 255):
            for j in range(STR_LEN):
                leds[j] = (i, i, i)
            time.sleep(0.1)
# End def
if __name__ == '__main__':
        task()
    except KeyboardInterrupt:
        pass
    print("Program Complete.")
Buzzer Test
A test file for the vibration motor/ buzzer created by Erik Welsh
# -*- coding: utf-8 -*-
Buzzer Test
License:
Based on library from
Copyright 2018 Nicholas Lester
import sys
import math
import random
# Global variables
# Main Tasks
class BuzzerSound():
    pin       = None
    def __init__(self, pin):
        self.pin = pin
    # End def
    def play_tone(self, frequency, length):
        """Plays a given note for a given length."""
        PWM.start(self.pin, 50, frequency)
        time.sleep(length)
    # end def
    def end(self):
        PWM.stop(self.pin)
        PWM.cleanup()
    # End def
# End class
# Main script
    print("Buzzer Test")
    buzzer = BuzzerSound("P2_1")
    print("Play tone")
    buzzer.play_tone(440, 1)        # Play 440Hz for 1 second
    buzzer.end()
    print("Test Complete")
vibration.py
Make motors vibrate!
Vibration
License:
Copyright 2021 Lisa Zhu
import sys
import math
import random
# Global variables
# Main Tasks
class Vibration():
    pin       = None
        self.pin = pin
    # End def
    def vibrate(self, frequency):
        PWM.start(self.pin, 100, frequency)
    # end def
    def end(self):
        PWM.stop(self.pin)
        PWM.cleanup()
        # End def
led_display.py
Let the LEDs blink!
LED Music Visualizer & Vibrator
License:
Control LED strip and vibration motors with WAV file data
LED lights and vibrations according to tuple values extracted from wav file
  * Setting up the LED strip:
  https://markayoder.github.io/PRUCookbook/01case/case.html#_neopixels_5050_rgb_leds_with_integrated_drivers_ledscape (Section 1.3. NeoPixels - 5050 RGB LEDs with Integrated Drivers (LEDScape))
  * Unpacking and analyzing wav file:
  https://stackoverflow.com/questions/2226853/interpreting-wav-data (Comment by SapphireSun on Feb 9 '10 at 6:18)
Copyright Information:
    Adopted from code by Juliana Wang:
    https://www.hackster.io/juliana-wang/pocketbeagle-led-music-visualizer-3e6c7c
# PART 1: READ/UNPACK WAV FILE DATA
import wave
import struct
import opc
import vibration as vibration
from multiprocessing import Process
# Constants
# Global variables
integer_data = []
# Functions
def pcm_channels(wave_file):
    """Given a file-like object or file path representing a wave file,
    decompose it into its constituent PCM data streams.
    Input: A file like object or file path
    Output: A list of lists of integers representing the PCM coded data stream channels
        and the sample rate of the channels (mixed rate channels not supported)
    global integer_data
    stream = wave.open(wave_file,"rb")
    num_channels = stream.getnchannels()
    sample_rate  = stream.getframerate()
    sample_width = stream.getsampwidth()
    num_frames   = stream.getnframes()
    raw_data = stream.readframes( num_frames ) # Returns byte data
    stream.close()
    total_samples = num_frames * num_channels
    if sample_width == 1:
        fmt = "%iB" % total_samples # read unsigned chars
    elif sample_width == 2:
        fmt = "%ih" % total_samples # read signed 2 byte shorts
        raise ValueError("Only supports 8 and 16 bit audio formats.")
    integer_data = struct.unpack(fmt, raw_data)
    del raw_data # Keep memory tidy (who knows how big it might be)
# PART 2: TRIGGER LED LIGHT STRIP WITH WAV DATA
def led_strip(wave_file):
    global integer_data
    vib1 = vibration.Vibration("P2_1")
    vib2 = vibration.Vibration("P2_3")
    vib3 = vibration.Vibration("P1_33")
    vib4 = vibration.Vibration("P1_36")
    stop_time = time.time() + 60
    STR_LEN = 10
    offset      = 0
    data_length = len(integer_data)
        # appears later
    leds = [(0, 0, 0)] * STR_LEN
    while time.time() < stop_time:
        vib_freq = 0
            datavalue = abs(integer_data[(i+offset)])//16
            vib_freq += datavalue
            leds[i]  = (datavalue,datavalue,datavalue)
        offset = offset + STR_LEN   #Leaves remainder numebr of pixels to shift
        vib_freq = vib_freq // STR_LEN
        if vib_freq == 0: # frequency can't be zero
            vib_freq = 1
        if offset > data_length:
            print('not connected')
        # Do vibration
        process_1 = Process(target=vib1.vibrate,args=(vib_freq,))
        process_2 = Process(target=vib2.vibrate,args=(vib_freq,))
        process_3 = Process(target=vib3.vibrate,args=(vib_freq,))
        process_4 = Process(target=vib4.vibrate,args=(vib_freq,))
        processes = [process_1, process_2, process_3, process_4]
        for process in processes:
            process.start() #start vibration
        process_1.join()
        process_2.join()
        process_3.join()
        process_4.join()
        time.sleep(0.001)
    vib1.end()
    vib2.end()
    vib3.end()
    vib4.end()
song_names.py
Call led_strip and vibration to execute the program
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
Song Name Display & Music Player
License:
Copyright 2021 <Lisa Zhu>
Reference of SPI display related code: Melissa LeBlanc-Williams for Adafruit Industries
Use the ili9341 Display, a button, five vibration motors, a led strip and a speaker to
create a music player with selectable songs, with led color change and vibrations to
enhance the experience.
Requirements:
  - Display all selectable songs on the screen
  - Increment the counter by one each time the button is pressed
  - Stop incrementing the counter 5 seconds after the button is released
  - Play the song corresponding to the counter
  - Sync vibrations and LEDs with the music
Uses:
  - digitalio, board, busio, PIL, adafruit_rgb_display.ili9341 libraries are used to control the display
  - time library is used to time the program and exit when appropriate
  - Adafruit_BBIO.GPIO library is used to take input from the button
  - os library is used to play the music
  - multiprocessing library is used to sync vibration and led with the music
import digitalio
import board
import busio
from PIL import Image, ImageDraw, ImageFont
import os
import led_display as led
# First define some constants to allow easy resizing of shapes.
BORDER = 20
FONTSIZE = 18
class SongNames():
    vib1       = None
    vib2       = None
    vib3       = None
    vib4       = None
    button     = None
    display    = None
    def __init__(self, reset_time=5.0, button="P1_26", spi = busio.SPI(board.SCLK_1, board.MOSI_1, board.MISO_1)):
        """ intialize variables and set up display """
        self.vib1 = vibration.Vibration("P2_1")
        self.vib2 = vibration.Vibration("P2_3")
        self.vib3 = vibration.Vibration("P1_33")
        self.vib4 = vibration.Vibration("P1_36")
        # Configuration for CS and DC pins (these are PiTFT defaults):
        # Config for display baudrate (default max is 24mhz):
        BAUDRATE = 24000000
        self.button    =button
        self.display   =ili9341.ILI9341(
                        spi,
                        rotation=90,  # 2.2", 2.4", 2.8", 3.2" ILI9341
                        cs=cs_pin,
                        dc=dc_pin,
                        rst=reset_pin,
                        baudrate=BAUDRATE,
        self._setup()
    def _setup(self):
        # Create blank image for drawing.
        # Make sure to create image with mode 'RGB' for full color.
        if self.display.rotation % 180 == 90:
            height = self.display.width  # we swap height/width to rotate it to landscape!
            width = self.display.height
            width = self.display.width  # we swap height/width to rotate it to landscape!
            height = self.display.height
        image = Image.new("RGB", (width, height))
        # Get drawing object to draw on image.
        draw = ImageDraw.Draw(image)
        # Draw a black box as the background
        draw.rectangle((0, 0, width, height), fill=0)
        self.display.image(image)
        # Draw a smaller inner purple rectangle
        draw.rectangle(
            (BORDER, BORDER, width - BORDER - 1, height - BORDER - 1), fill=(170, 0, 136)
        # Initialize Button
        GPIO.setup(self.button, GPIO.IN)
        # Load a TTF Font
        font = ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf", FONTSIZE)
        padding = BORDER+1
        x= BORDER+2
        # Display song names
        song1 = "Stay with Me -- Press Once"
        song2 = "Glassy Sky    -- Press Twice"
        song3 = "Verona          -- Press 3 Times"
        song4 = "Aimer           -- Press 4 Times"
        y=padding+15
        draw.text(
            (x, y),
            song1,
            font=font,
            fill=(255, 255, 0),
        y+=font.getsize(song1)[1]+15
        draw.text(
            (x, y),
            song2,
            font=font,
            fill=(255, 255, 0),
        y+=font.getsize(song2)[1]+15
        draw.text(
            (x, y),
            song3,
            font=font,
            fill=(255, 255, 0),
        y+=font.getsize(song3)[1]+15
        draw.text(
            (x, y),
            song4,
            font=font,
            fill=(255, 255, 0),
        # Display image.
    def run(self):
        """Execute the main program."""
        press_count         = 0      # Number of times button was pressed
        button_press_done   = False
        timeout             = False
        while(not button_press_done):
            while(GPIO.input(self.button) == 1):
                if press_count != 0:
                    if (time.time() - initial_time) > 5: #stop counting if the button remains unpressed for 5 seconds
                        button_press_done = True
                        timeout = True
                time.sleep(0.1)
            if press_count == 0:
                initial_time = time.time()
            if not timeout:
                press_count += 1
                print(press_count)
            # Wait for button release
            while(GPIO.input(self.button) == 0):
                if (button_press_done):
                time.sleep(0.1)
        #Each button press count corresponds to a different set of music, vibration and led effects
        if (press_count ==1):
            process1=Process(target=os.system, args=("mplayer ../speaker/music/stay_with_me.mp3",))
            process2=Process(target=led.led_strip, args=("/var/lib/cloud9/ENGI301/Project_1/speaker/music/stay_with_me.wav",))
        if (press_count ==2):
            process1=Process(target=os.system, args=("mplayer ../speaker/music/glassy_sky.mp3",))
            process2=Process(target=led.led_strip, args=("/var/lib/cloud9/ENGI301/Project_1/speaker/music/glassy_sky.wav",))
        if (press_count ==3):
            process1=Process(target=os.system, args=("mplayer ../speaker/music/verona.mp3",))
            process2=Process(target=led.led_strip, args=("/var/lib/cloud9/ENGI301/Project_1/speaker/music/verona.wav",))
        if (press_count ==4):
            process1=Process(target=os.system, args=("mplayer ../speaker/music/aimer.mp3",))
            process2=Process(target=led.led_strip, args=("/var/lib/cloud9/ENGI301/Project_1/speaker/music/aimer.wav",))
        processes = [process1, process2]
            process.start() #start vibration, music and led effects
        process1.join()
        process2.join()
    def cleanup(self):
        self.vib1.end()
        self.vib2.end()
        self.vib3.end()
        self.vib4.end()
    print("Program Start")
    # Create instantiation of song name display
    song_name=SongNames()
        # Run the song name display
        song_name.run()
        # Clean up hardware when exiting
        song_name.setup()
    song_name.cleanup()
    print("Program Complete")
Lisa Zhu Github Repository
Lisa Zhu
Lisa Zhu
Thanks to Juliana Wang and Erik Welsh.
