Josh Mitterling
Published © GPL3+
Stacker Game - BeagleBone Black with LED Matrix
A miniature take on the classic arcade game known as Stacker, this project allows one to explore the BeagleBone with an emphasis on Python.
BeginnerFull instructions provided2 hours4
Breadboard (generic)
LED Dot Matrix Display, Red
Pushbutton switch 12mm
SparkFun Pushbutton switch 12mm
VS Code
Microsoft VS Code
Circuit Diagram
recreate this on your own breadboard
Stacker_game.py
use this file to run the game. once the setup is complete and circuit is wired, this will play the game.
#!/usr/bin/env python3
# Luke Wendel 1and Josh Mitterling 2/20/22
# A stack game that uses the I2C 8x8 Bi-color LED Matrix
# The goal of the game is to stack the bricks to the top without letting them all fall
# You use the one button in order to stop the brick
# When you win or lose, you hit the button again to restart the game
import sys
import smbus
yMax = 8 #global variable for the y size of the matrix
xMax = 8 #global variable for the x size of the matrix
level = 0 #global variable for which row the game is on
size = [1,1,1] #global list for the size of the block that you are stopping
change = 0 #global variable to skip steps if the button has been pressed
speed = 0.1 #global variable for the speed of the block
gaming = True #global variable to see if the game is being played
saved_indices = [] #global list to see what indicies to delete from list "size"
bounce = 40 #global variable for debounce time for button
indicie = 0 #global variable for the current indicie  of the LED matrix
trigger = 0 #checks to see if the button interrupt as activated
win = [["*", "", "", "", "", "", "", "*"], #matrix screen for winning
lose = [["", "", "*", "*", "*", "*", "*", "*"], #matrix screen for losing
perfect = [["", "", "", "", "", "", "", "*"], #matrix screen for perfect win
firework1 = [["", "", "", "", "", "", "", ""], #matrix screen for beginning of firework
firework2 = [["", "", "", "", "", "", "", ""], #matrix screen for middle of firework
firework3 = [["", "", "", "", "", "", "", ""], #matrix screen for middle of firework
firework4 = [["*", "*", "*", "*", "*", "*", "*", "*"], #matrix screen for ending of firework
bus = smbus.SMBus(2)
matrix_address = 0x70
# set up the LED led_matrix
time.sleep(0.5)
bus.write_byte_data(matrix_address, 0x21, 0)
time.sleep(0.5)
bus.write_byte_data(matrix_address, 0x81, 0)
time.sleep(0.5)
bus.write_byte_data(matrix_address, 0xe7, 0)
time.sleep(0.5)
GPIO.setup("P9_23", GPIO.IN, pull_up_down=GPIO.PUD_UP) #set up the pushbutton as a pullup
def ISR_P9_23(channel):  # This is the ISR that's invoked when a pulse is detected
    global trigger
    trigger = 1
# Clear the interrupt and re-enable it for the next time
    GPIO.remove_event_detect("P9_23")
    time.sleep(0.1)
    GPIO.add_event_detect("P9_23", GPIO.FALLING, callback=ISR_P9_23, bouncetime=bounce)
#add event detect and event callback for button press
GPIO.add_event_detect("P9_23", GPIO.FALLING)
GPIO.add_event_callback("P9_23", ISR_P9_23, bouncetime=bounce)
# Creating the stacker virtual grid space
grid = [[' ' for i in range(xMax)] for j in range (yMax)]
# Function that updates the LED matrix based on the virtual grid space given
def led_update(grid):
    led_matrix = ["", "", "", "", "", "", "", ""]
    # binary for led led_matrix
    for i in range(len(grid)):
      for j in range(len(grid)):
        if grid[j][i] == '*':
          led_matrix[i] += '1'
          led_matrix[i] += '0'
    for i in range(len(led_matrix)):
      led_matrix[i] = int(led_matrix[i], 2)
    # make red
    block_data = []
      block_data.append(0)
      block_data.append(led_matrix[i])
    # write to the i2c bus
    bus.write_i2c_block_data(matrix_address, 0, block_data)
# Function that checks the position of the blocks
def check_blocks(reverse):
    global saved_indices
    global speed
    global level
    global change
    if reverse == 1: #determines which was the block was going
        if level != 0: #checks to make sure that its not the first level
            for l in reversed(range(len(size))):
                if indicie >= 5: #check if the indicie is on the end and prevents out of range errors
                    test = grid[level][i+l] #checks if the current brick indicie is lit up
                    test2 = grid[level-1][i+l] #checks if the brick under the current brick indicie is lit up
                    test = grid[level][i+l+1] #checks if the current brick indicie is lit up
                    test2 = grid[level-1][i+l+1] #checks if the brick under the current brick indicie is lit up
                if test != test2: #go in this if the brick above and below are not both lit
                    saved_indices.append(l)
                    for u in range(level): #this for loop makes it so the brick falls all the way to the bottom and destroys everything in its path
                        if indicie >= 5:
                            grid[level-u][i+l] = "0"
                            grid[level-(u+1)][i+l] = "*"
                            grid[level-u][i+l+1] = "0"
                            grid[level-(u+1)][i+l+1] = "*"
                        led_update(grid)
                        time.sleep(0.5)
                    if indicie >= 5: #this destorys the falling brick when its on the bottom
                        grid[0][i+l] = "0"
                        grid[0][i+l+1] = "0"
                    led_update(grid)
        for t in range(len(saved_indices)): #this for loop deletes the indicies that did not have a lit brick beneath it
                del size[saved_indices[t]] #some try excepts for out of range index errors
            except:
                    if size.count(1) == 1:
                        del size[0]
                except:
        level = level+1 #increases the level of the game
        speed = speed - 0.005 #increases the speed of the game
        change = 1
            for l in range(len(size)):
                if indicie == 0: #check if the indicie is on the end and prevents out of range errors
                    test = grid[level][i-1+l] #checks if the current brick indicie is lit up
                    test2 = grid[level-1][i-1+l] #checks if the brick under the current brick indicie is lit up
                        if indicie == 0:
                            grid[level - u][i+l] = "0"
                            grid[level - (u+1)][i+l] = "*"
                            grid[level-u][i-1+l] = "0"
                            grid[level-(u+1)][i-1+l] = "*"
                        led_update(grid)
                        time.sleep(0.5)
                    if indicie == 0: #this destorys the falling brick when its on the bottom
                        grid[0][i+l] = "0"
                        grid[0][i-1+l] = "0"
                    led_update(grid)
            except:
                        del size[0]
                except:
    saved_indices = []
while True: #Main Loop
    while gaming: #While loop that runs while the game is being played
        for i in range(xMax - len(size)+1): #loop that runs through the brick moving forth
            if trigger == 1: #check to see if the button was pressed
                check_blocks(0)
                trigger = 0
            indicie = i #set the indicie of the brick
                grid[level] = ["0" for x in grid[level]] #set all the bricks in the level to be turned off
                for k in range(len(size)): #this for loops lights up the brick the size it needs to be
                    grid[level][k+i] = "*"
                led_update(grid)
                time.sleep(speed) #sleep for the amount of time the speed is set at
            except:
                gaming = False #if there is an index error on top you have won the game
            if size.count(1) == 0: #also if there is no bricks for you to stack left then you have lost the game
                gaming = False
        for i in reversed(range(xMax - len(size)+1)): #loop that runs through the brick moving back
            if gaming == False: #checks to see if the game has ended and breaks out of the while loop
                check_blocks(1)
                trigger = 0
            if change == 1: #checks to see if the button was pressed earlier to skip this code
                change = 0
                led_update(grid)
            except:
                gaming = False
    if size.count(1) == 0: #checks to see if you lost and plays the lose screen
        led_update(lose)
    elif size.count(1) == 3: #checks to see if you won perfectly and plays the perfect win screen
        led_update(firework1)
        time.sleep(0.5)
        led_update(firework2)
        time.sleep(0.5)
        led_update(firework3)
        time.sleep(0.5)
        led_update(firework4)
        time.sleep(0.5)
        led_update(perfect)
        time.sleep(0.5)
        led_update(firework1) #checks to see if you won and plays the win screen
        time.sleep(0.5)
        time.sleep(0.5)
        time.sleep(0.5)
        time.sleep(0.5)
        led_update(win)
        time.sleep(0.5)
    if trigger == 1: #waits for the button to be pressed again and restarts the game
        level = 0
        speed = 0.1
        saved_indicies = []
        size = [1,1,1]
        gaming = True
        indicie = 0
        change = 0
        trigger = 0
Stacker_game_project
Clone this repository, or copy the content of the Arcade_game.py file
Josh Mitterling
Josh Mitterling
