Alan LopezBenZaltsmanTeddy HoisingtonFreddy Angarita - Cuesta
FATBB Autonomous Vehicle
In this project, our team built a lane following, autonomous RC car with the beagle bone black using the OpenCV library.
IntermediateShowcase (no instructions)20
Webcam, Logitech® HD Pro
USB Expansion HUB, USB 2.0 Powered
usb wifi adapter
OpenCV
OpenCV
SelfDrive.py
This is the code to run the entire car
#A Huge thank you to: User raja_961, Autonomous Lane-Keeping Car Using Raspberry Pi and OpenCV. Instructables.
#Code was modified from raja_961's.
import cv2
import numpy as np
import math
import sys
#throttle and steering and button interrupt setup
throttlePin = "P9_14" # Physical pin P9_14
steeringPin = "P8_13" # Physical Pin P8_13
button = "P8_7"
#frame count
i = 0
#number of stops seen
signs_seen = 0
#PD Coefficients and speed set up
kp = 2.5
kd = 0.4
speed = 7.95
#GPIO set up for interrupt
GPIO.setup(button, GPIO.IN)
# Steering init
PWM.start(steeringPin, 7.5 ,50,0)
# Throttle init
PWM.start(throttlePin, 7.5, 50, 0)
def detect_edges(frame):
    # filter for blue lane lines
    lower_blue = np.array([90, 120, 0], dtype = "uint8")
    mask = cv2.inRange(hsv,lower_blue,upper_blue)
    # detect edges
    return edges
    height, width = edges.shape
    mask = np.zeros_like(edges)
    polygon = np.array([[
        (0, height),
        (0,  height/2),
        (width , height/2),
        (width , height),
    ]], np.int32)
    cv2.fillPoly(mask, polygon, 255)
    #cv2.imshow("roi",cropped_edges)
    return cropped_edges
    rho = 1
    theta = np.pi / 180
    min_threshold = 10
    return line_segments
    lane_lines = []
    if line_segments is None:
        print("no line segments detected")
        return lane_lines
    height, width,_ = frame.shape
    left_fit = []
    right_fit = []
    boundary = 1/3
            if x1 == x2:
                print("skipping vertical lines (slope = infinity")
                continue
            slope = (y2 - y1) / (x2 - x1)
            intercept = y1 - (slope * x1)
            if slope < 0:
    if len(left_fit) > 0:
    if len(right_fit) > 0:
    return lane_lines
def make_points(frame, line):
    slope, intercept = line
    if slope == 0:
        slope = 0.1
    return [[x1, y1, x2, y2]]
    if lines is not None:
        for line in lines:
            for x1, y1, x2, y2 in line:
    return line_image
def display_heading_line(frame, steering_angle, line_color=(0, 0, 255), line_width=5 ):
    x1 = int(width / 2)
    y1 = height
    y2 = int(height / 2)
    return heading_image
    height,width,_ = frame.shape
    if len(lane_lines) == 2:
        mid = int(width / 2)
        y_offset = int(height / 2)
    elif len(lane_lines) == 1:
        x_offset = x2 - x1
    elif len(lane_lines) == 0:
        x_offset = 0
    return steering_angle
video = cv2.VideoCapture(0)
video.set(cv2.CAP_PROP_FRAME_WIDTH,320)
video.set(cv2.CAP_PROP_FRAME_HEIGHT,240)
#video.set(cv2.CAP_PROP_BUFFERSIZE, 3)
lastTime = 0
lastError = 0
    i = i+1
    ret,frame = video.read()
    frame = cv2.resize(frame, (100,75),interpolation=cv2.INTER_AREA)
    #Decrease cam resolution for better performance
    edges = detect_edges(frame)
    lane_lines = average_slope_intercept(frame,line_segments)
    lane_lines_image = display_lines(frame,lane_lines)
    heading_image = display_heading_line(lane_lines_image,steering_angle)
    #Button Interrupt
    if GPIO.input(button):
        PWM.set_duty_cycle(throttlePin, 7.5)
        print("button pressed")
    now = time.time()
    dt = now - lastTime
    #Get steering angle
    error = abs(deviation)
    #default steer is 7.5 (straight)
    set_steer = 7.5
    #START OF STOP SIGN CODE
    if i % 10 == 0:
        #check every 10 frames for stop sign
        hsv_red = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
        # define range of red color in HSV
        lower_red = np.array([160,50,50])
        upper_red = np.array([180,255,255])
        #Threshold the HSV image to get only red colors, count pixels remaining
        mask_red = cv2.inRange(hsv_red, lower_red, upper_red)
        countRed = cv2.countNonZero(mask_red)
        #if pixel count is significant and a stop sign has not recently been seen, stop
        if(countRed > 500 and i > 20):
            time.sleep(2)
            #if this is the second sign, stop forever
            if(signs_seen == 1):
                print("all done")
                while(1):
                    #Just hang out here forever
                    print(":D")
            signs_seen = 1
            #increase speed, P coefficient for turn and restart
            speed = speed + 0.02
            kp = 5
            PWM.set_duty_cycle(throttlePin, speed)
            i = 0 #reset frame count
    #END OF STOP SIGN CODE
    if deviation < 3 and deviation > -3:
        deviation = 0
        error = 0
        #10 degree error range
    #PD logic
    proportional = kp * error
    PD = (int(derivative + proportional)) / 60
    #set correct steering angle
    if deviation >= 3:
        set_steer = set_steer - PD
    elif deviation <= -3:
        set_steer = set_steer + PD
    #max out at full left/full right turns
    if set_steer > 9:
        set_steer = 9
    if set_steer < 6:
        set_steer = 6
    #turn and go
    PWM.set_duty_cycle(steeringPin, set_steer)
    lastError = error
    lastTime = time.time()
    key = cv2.waitKey(1)
    if key == 27:
#Clean up for end of code
video.release()
cv2.destroyAllWindows()
PWM.set_duty_cycle(steeringPin, 7.5)
PWM.stop(throttlePin)
PWM.stop(steeringPin)
Alan Lopez
Alan Lopez
BenZaltsman
BenZaltsman
1 project • 1 follower
I love Ray Simar AND Joe Young
Teddy Hoisington
Teddy Hoisington
2 projects • 0 followers
