Welcome to Team Coming Soon's autonomous vehicle story! Our car uses a beaglebone and a camera to drive itself along a blue taped path. It follows the path, staying at a consistent speed and turning itself and bends, and will stop for a few seconds at stop signs, red papers on the ground.
Our project is based off of raja_961's "Autonomous Lane-Keeping Car Using Raspberry Pi and OpenCV" and Team ReaLly BaD Idea's "Autonomous path following car". Much of our code is from these sources. These two projects can be found by clicking the links.
Selecting Values for Resolution, Proportional Gain, and Derivative GainWe determined our resolution, proportional gain, and derivative gain by starting with the values given to us in the assignment, which was to set the proportional gain to a low value, the derivative gain to zero, and the resolution to a low value. The resolution we started with worked pretty effectively, so we were able to keep it similar, while the proportional and derivative gains needed to be changed to follow the track. Through testing, we updated these values until it correctly followed the path. In doing so, if we needed the car to be more responsive to error we raised the proportional gain, and if we needed to reduce the oscillation caused by this, we increased the derivative gain. We use our shaft encoder to keep our car traveling at consistent speed, which made this process easier. Eventually we were able to get working values, which were 0.080 for the proportional gain and 0.012 for the derivative gain. The resolution we ended up using was 160 x 120. The camera was set to take 320x240, then in the loop each new frame is resized to 160 x 120. This is what team Really Bad Idea used, and it worked for us, so we felt no need to change it.
Handling Stop BoxesOur car also needed to complete the challenge of taking a brief stop at any stop box it passed. These stop boxes are represented by red papers on the path of the car. In order to do this, we check the color values of the image coming into the camera to determine if the car sees red and if it sees enough red that it can confirm a stop box is ahead. We count "red" as in between (140, 80, 170) and (200, 255, 250). The paper is pretty dusty/muted so its not a strong red. We basically printed out the values our camera got when looking at the paper and used those to make this range. When this occurs, the car continues on for a brief delay so that it will reach the stop box that is saw ahead, then stops its motion for a couple of seconds. After this pause, it will continue on, still following the path.
Plots of PWM and PD# Uses code from https://www.instructables.com/Autonomous-Lane-Keeping-Car-Using-Raspberry-Pi-and/ and from https://www.hackster.io/really-bad-idea/autonomous-path-following-car-6c4992
import cv2
import numpy as np
import matplotlib.pyplot as plt
import math
def getRedFloorBoundaries():
Gets the hsv boundaries and success boundaries indicating if the floor is red
:return: [[lower color and success boundaries for red floor], [upper color and success boundaries for red floor]]
return getBoundaries("redboundaries.txt")
def isRedFloorVisible(frame):
Detects whether or not the floor is red
:param frame: Image
:return: [(True is the camera sees a red on the floor, false otherwise), video output]
#print("Checking for floor stop")
boundaries = getRedFloorBoundaries()
return isMostlyColor(frame, boundaries)
def isMostlyColor(image, boundaries):
Detects whether or not the majority of a color on the screen is a particular color
:param image:
:param boundaries: [[color boundaries], [success boundaries]]
:return: boolean if image satisfies provided boundaries, and an image used for debugging
#Convert to HSV color space
hsv_img = cv2.cvtColor(image, cv2.COLOR_BGR2HSV)
#print(hsv_img[len(hsv_img) // 2, len(hsv_img) // 2])
#parse out the color boundaries and the success boundaries
color_boundaries = boundaries[0]
percentage = boundaries[1]
lower = np.array(color_boundaries[0])
upper = np.array(color_boundaries[1])
mask = cv2.inRange(hsv_img, lower, upper)
output = cv2.bitwise_and(hsv_img, hsv_img, mask=mask)
#Calculate what percentage of image falls between color boundaries
percentage_detected = np.count_nonzero(mask) * 100 / np.size(mask)
#print("percentage_detected " + str(percentage_detected) + " lower " + str(lower) + " upper " + str(upper))
# If the percentage percentage_detected is betweeen the success boundaries, we return true, otherwise false for result
result = percentage[0] < percentage_detected <= percentage[1]
#if result:
print(percentage_detected)
return result, output
def getBoundaries(filename):
Reads the boundaries from the file filename
Format:
[0] lower: [H, S, V, lower percentage for classification of success]
[1] upper: [H, S, V, upper percentage for classification of success]
:param filename: file containing boundary information as above
:return: [[lower color and success boundaries], [upper color and success boundaries]]
default_lower_percent = 50
default_upper_percent = 100
with open(filename, "r") as f:
boundaries = f.readlines()
lower_data = [val for val in boundaries[0].split(",")]
upper_data = [val for val in boundaries[1].split(",")]
if len(lower_data) >= 4:
lower_percent = float(lower_data[3])
lower_percent = default_lower_percent
if len(upper_data) >= 4:
upper_percent = float(upper_data[3])
upper_percent = default_upper_percent
lower = [int(x) for x in lower_data[:3]]
upper = [int(x) for x in upper_data[:3]]
boundaries = [lower, upper]
percentages = [lower_percent, upper_percent]
return boundaries, percentages
def stop():
Stops the car
:return: none
with open('/dev/bone/pwm/1/a/duty_cycle', 'w') as filetowrite:
filetowrite.write(str(int(FACTOR * dont_move)))
def go():
Sends the car forward at a default PWM
:return: none
filetowrite.write(str(int(FACTOR * go_forward)))
def detect_edges(frame):
# filter for blue lane lines
# cv2.imshow("HSV",hsv)
lower_blue = np.array([90, 120, 0], dtype="uint8")
mask = cv2.inRange(hsv, lower_blue, upper_blue)
# cv2.imshow("mask",mask)
# detect edges
# cv2.imshow("edges",edges)
return edges
height, width = edges.shape
mask = np.zeros_like(edges)
polygon = np.array([[
(0, height),
(0, height / 2),
(width, height / 2),
(width, height),
]], np.int32)
cv2.fillPoly(mask, polygon, 255)
# cv2.imshow("roi",cropped_edges)
return cropped_edges
rho = 1
theta = np.pi / 180
min_threshold = 10
return line_segments
lane_lines = []
if line_segments is None:
print("no line segments detected")
return lane_lines
left_fit = []
right_fit = []
boundary = 1 / 3
if x1 == x2:
print("skipping vertical lines (slope = infinity")
continue
slope = (y2 - y1) / (x2 - x1)
intercept = y1 - (slope * x1)
if slope < 0:
if len(left_fit) > 0:
if len(right_fit) > 0:
return lane_lines
def make_points(frame, line):
slope, intercept = line
y1 = height # bottom of the frame
y2 = int(y1 / 2) # make points from middle of the frame down
if slope == 0:
slope = 0.1
return [[x1, y1, x2, y2]]
if lines is not None:
for line in lines:
for x1, y1, x2, y2 in line:
return line_image
def display_heading_line(frame, steering_angle, line_color=(0, 0, 255), line_width=5):
x1 = int(width / 2)
y1 = height
y2 = int(height / 2)
return heading_image
if len(lane_lines) == 2:
mid = int(width / 2)
y_offset = int(height / 2)
elif len(lane_lines) == 1:
x_offset = x2 - x1
elif len(lane_lines) == 0:
x_offset = 0
return steering_angle
def plot_pd(p_vals, d_vals, error, show_img=False):
fig, ax1 = plt.subplots()
t_ax = np.arange(len(p_vals))
ax1.plot(t_ax, p_vals, '-', label="P values")
ax1.plot(t_ax, d_vals, '-', label="D values")
ax2 = ax1.twinx()
ax2.plot(t_ax, error, '--r', label="Error")
ax1.set_xlabel("Frames")
ax1.set_ylabel("PD Value")
ax2.set_ylim(-90, 90)
ax2.set_ylabel("Error Value")
plt.title("PD Values over time")
fig.legend()
fig.tight_layout()
plt.savefig("pd_plot.png")
if show_img:
plt.show()
plt.clf()
def plot_pwm(speed_pwms, turn_pwms, error, show_img=False):
t_ax = np.arange(len(speed_pwms))
ax1.plot(t_ax, speed_pwms, '-', label="Speed PWM")
ax1.plot(t_ax, turn_pwms, '-', label="Steering PWM")
ax2 = ax1.twinx()
ax1.set_ylabel("PWM Values")
plt.title("PWM Values over time")
fig.legend()
plt.savefig("pwm_plot.png")
if show_img:
plt.show()
plt.clf()
filetowrite.write('1500000')
input()
with open('/dev/bone/pwm/1/b/duty_cycle', 'w') as filetowrite:
FACTOR = 20000000 / 100
# Going
go_forward = 8.0
dont_move = 7.5
# Steering
left = 9
right = 6
# Max number of loops
max_ticks = 2000
# Booleans for handling stop light
passedStopLight = False
atStopLight = False
passedFirstStopSign = False
secondStopLightTick = 0
# set up video
video = cv2.VideoCapture(2)
video.set(cv2.CAP_PROP_FRAME_WIDTH, 320)
video.set(cv2.CAP_PROP_FRAME_HEIGHT, 240)
# wait for video to load
# PD variables
kp = 0.080
kd = kp * 0.15
lastTime = 0
lastError = 0
# counter for number of ticks
counter = 0
# start the engines
go()
# arrays for making the final graphs
p_vals = []
d_vals = []
err_vals = []
speed_pwm = []
steer_pwm = []
current_speed = go_forward
sightDebug = True
stopSignCheck = 1
isStopSignBool = False
stopSignTick = 0
stopSignCheck = 1
turnRightCount = 0
stopSignCount = 0
while counter < max_ticks:
ret, original_frame = video.read()
frame = cv2.resize(original_frame, (160, 120))
if sightDebug:
cv2.imshow("Resized Frame", frame)
# check for stop sign/traffic light every couple ticks
if ((counter + 1) % stopSignCheck) == 0:
if counter > stopSignTick:
isStopSignBool, floorSight = isRedFloorVisible(frame)
if sightDebug:
cv2.imshow("floorSight", floorSight)
# If a stop sign is detected, then stop it and sleep for 2 seconds
if isStopSignBool:
stopSignCount += 1
time.sleep(0.10)
print("Detected stop sign, stopping now.")
stop()
time.sleep(2)
stopSignTick = counter + 200
passedStopLight = True
print("Stop sign finished.")
if stopSignCount == 2:
# If the car has just passed a stop light, then it goes again
if passedStopLight:
go()
# process the frame to determine the desired steering angle
# cv2.imshow("original",frame)
edges = detect_edges(frame)
lane_lines = average_slope_intercept(frame, line_segments)
lane_lines_image = display_lines(frame, lane_lines)
# heading_image = display_heading_line(lane_lines_image,steering_angle)
# cv2.imshow("heading line",heading_image)
# calculate changes for PD
now = time.time()
dt = now - lastTime
if sightDebug:
cv2.imshow("Cropped sight", roi)
# PD Code
error = -deviation
base_turn = 7.5
proportional = kp * error
# take values for graphs
p_vals.append(proportional)
d_vals.append(derivative)
err_vals.append(error)
# determine actual turn to do
turn_amt = base_turn + proportional + derivative
# caps turns to make PWM values
if 7.2 < turn_amt < 7.8:
print("Keep STRAIGHT")
turn_amt = 7.5
turnRightCount = 0
elif turn_amt > left:
print("Turn LEFT")
turn_amt = left
turnRightCount = 0
elif turn_amt < right:
print("Turn RIGHT")
turnRightCount += 1
turn_amt = right
# turn!
filetowrite.write(str(int(FACTOR * turn_amt)))
if turnRightCount == 5:
time.sleep(0.25)
steer_pwm.append(turn_amt)
speed_pwm.append(current_speed)
# update PD values for next loop
lastError = error
lastTime = time.time()
key = cv2.waitKey(1)
if key == 27:
counter += 1
# clean up resources
video.release()
cv2.destroyAllWindows()
plot_pd(p_vals, d_vals, err_vals, True)
plot_pwm(speed_pwm, steer_pwm, err_vals, True)
//Uses code from https://www.instructables.com/Autonomous-Lane-Keeping-Car-Using-Raspberry-Pi-and/ and from https://www.hackster.io/really-bad-idea/autonomous-path-following-car-6c4992
#include <linux/module.h>
#include <linux/of_device.h>
#include <linux/kernel.h>
#include <linux/gpio/consumer.h>
#include <linux/platform_device.h>
#include <linux/init.h>
#include <linux/gpio.h>
#include <linux/interrupt.h>
#include <linux/ktime.h>
//Inturupt handler number
int irq_number;
// //Refers to LED pin P9-27
// struct gpio_desc *led;
//refers to button pin P8_14
struct gpio_desc *button;
ktime_t curr_time, previous_time;
int diff;
module_param(diff, int, S_IRUGO);
* Interrupt service routine is called, when interrupt is triggered
* Got this code from https://github.com/Johannes4Linux/Linux_Driver_Tutorial/blob/main/11_gpio_irq/gpio_irq.c
static irq_handler_t gpio_irq_handler(unsigned int irq, void *dev_id, struct pt_regs *regs) {
printk("Speed encoder triggered.\n");
//gpiod_set_value(led, (gpiod_get_value(led) + 1) %2);
//clock_t new_time = clock();
// if last_time == NULL {
// last_time = new_time;
// } else {
curr_time = ktime_get();
int temp = ktime_to_ns(curr_time - previous_time) / 1000000;
if(temp > 1) { diff = temp; }
printk("Difference between triggers: %d\n", diff);
previous_time = curr_time;
// last_time = current;
// int millseconds = diff * 1000/CLOCKS_PER_SEC;
// printk("Milliseconds: %d", millseconds);
// if (millseconds > 1){
// FILE *fptr;
// fptr = fopen("speed.txt", "w");
// fprintf(fptr, "%d", millseconds);
// fclose(fptr);
// je = jiffies;
// printk("This is the previous time (js): %ld\n", js);
// printk("This is the current time (je): %ld\n", je);
// diffj = js - je;
// unsigned int check;
// check = jiffies_to_usecs(diffj);
// if (check > 1000){
// diff = check;
// js = je;
// printk("Difference in rotations is now: %d\n", diff);
return (irq_handler_t) IRQ_HANDLED;
// probe function, takes in the platform device that allows us to get the references to the pins
static int led_probe(struct platform_device *pdev)
printk("gpiod_driver has been inserted.\n");
//Get the pins based on what we called them in the device tree file: "name"-gpios
//led = devm_gpiod_get(&pdev->dev, "led", GPIOD_OUT_LOW);
button = devm_gpiod_get(&pdev->dev, "userbutton", GPIOD_IN);
//Set waiting period before next input
gpiod_set_debounce(button, 1000000);
//Pair the button pin with an irq number
irq_number = gpiod_to_irq(button);
//Pair the number with the function that handles it
if(request_irq(irq_number, (irq_handler_t) gpio_irq_handler, IRQF_TRIGGER_RISING, "my_gpio_irq", NULL) != 0){
printk("Error!\nCan not request interrupt nr.: %d\n", irq_number);
free_irq(irq_number, NULL);
return -1;
return 0;
// remove function ,takes in the platform device that allows us to get the references to the pins
static int led_remove(struct platform_device *pdev)
printk("Custom gpiod_driver module has been removed and irq has been freed\n");
//TBH not sure what goes in the second argument
return 0;
static struct of_device_id matchy_match[] = {
{.compatible = "gpiod_driver"},
{/* leave alone - keep this here (end node) */},
// platform driver object
static struct platform_driver adam_driver = {
.probe = led_probe,
.remove = led_remove,
.driver = {
.name = "The Rock: this name doesn't even matter",
.owner = THIS_MODULE,
.of_match_table = matchy_match,
module_platform_driver(adam_driver);
MODULE_DESCRIPTION("424\'s finest");
MODULE_AUTHOR("GOAT");
MODULE_LICENSE("GPL v2");
MODULE_ALIAS("platform:adam_driver");
init_pwm.py
Python# P9_14 - Speed/ESC
with open('/dev/bone/pwm/1/a/period', 'w') as filetowrite:
filetowrite.write('20000000')
filetowrite.write('1550000')
with open('/dev/bone/pwm/1/a/enable', 'w') as filetowrite:
filetowrite.write('1')
# P9_16 - Steering
with open('/dev/bone/pwm/1/b/period', 'w') as filetowrite:
with open('/dev/bone/pwm/1/b/enable', 'w') as filetowrite:
print("init_pwn has been executed")
// SPDX-License-Identifier: GPL-2.0
* Copyright (C) 2022 BeagleBoard.org - https://beagleboard.org/
* https://elinux.org/Beagleboard:BeagleBone_cape_interface_spec#PWM
/dts-v1/;
/plugin/;
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/board/k3-j721e-bone-pins.h>
* Helper to show loaded overlays under: /proc/device-tree/chosen/overlays/
&{/chosen} {
overlays {
BONE-PWM0.kernel = __TIMESTAMP__;
&bone_pwm_0 {
status = "okay";
gpio-leds {
compatible = "gpiod_driver";
userbutton-gpios = <gpio_P8_03 GPIO_ACTIVE_HIGH>;
label Linux eMMC
kernel /Image
append console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait net.ifnames=0 quiet
fdtdir /
fdtoverlays /overlays/BONE-PWM0.dtbo /overlays/BONE-PWM1.dtbo /overlays/BONE-PWM2.dtbo
initrd /initrd.img
