Madeline SternKatrina JiAngela LiuAndrew Yan
Team Angeldrew Katraline
We have coded an RC car to autonomously follow a track and stop at a "stop sign".
BeginnerShowcase (no instructions)5
Webcam, Logitech® HD Pro
USB Expansion HUB, USB 2.0 Powered
Test Accessory, USB Wi-Fi Dongle
OpenCV
OpenCV
Video of Car on Track (download to watch)
Our Car Setup (Front View)
Our Car Setup (Top View)
Graph of Steering, Throttle and Error vs Frame Number
Graph of Proportional Gain, Derivative Gain and Error vs Frame Number
# Code based on user raja_961's instructable found here:
# https://www.instructables.com/Autonomous-Lane-Keeping-Car-Using-Raspberry-Pi-and/
import cv2
import numpy as np
import math
import sys
# GPIO.setwarnings(False)
#throttle = physical pin 66
throttlePin = "P8_13" # Physical pin 22
# in3 = 23 # physical Pin 16
# in4 = 24 # physical Pin 18
#Steering
steeringPin = "P9_16" # Physical Pin 15
# in1 = 17 # Physical Pin 11
# in2 = 27 # Physical Pin 13
# Throttle
PWM.start(throttlePin,7.5, 50)
#PWM.set_duty_cycle(throttlePin,7.5)
# PWM.stop(throttlePin)
# Steering
PWM.start(steeringPin,7.5, 50)
#PWM.set_duty_cycle(steeringPin, 7.5)
# PWM.stop(steeringPin)
def detect_stop(hsv):
    #takes image in hsv as input
    #mask for the lower hue values
    red_lower = np.array([0,50,50], dtype = "uint8")
    red_higher = np.array([10,255,255], dtype = "uint8")
    #find pixels that are within the mask range
    mask0 = cv2.inRange(hsv, red_lower, red_higher)
    #mask for the higher hue values
    red_lower = np.array([170,50,50], dtype = "uint8")
    red_higher = np.array([180,255,255], dtype = "uint8")
    #find pixels within upper mask range
    mask1 = cv2.inRange(hsv, red_lower, red_higher)
    #get all pixels that are red
    superMask = mask0+mask1
    #sum up all values (0 if not red, 255 = logical 1 if red)
    totalRed = np.sum(superMask)
    #if more than 3/8's of total screen (3/4s of bottom half) is red -> there is a "stop sign"
    #return true if stop sign, false otherwise
    return True if totalRed >= 80*60/9*1*255 else False
def detect_edges(hsv):
    #changed to have hsv as input so that it doesnt need to be computed for edges and stops
    # filter for blue lane lines
    #cv2.imshow("HSV",hsv)
    lower_blue = np.array([90, 120, 0], dtype = "uint8")
    mask = cv2.inRange(hsv,lower_blue,upper_blue)
    #cv2.imshow("mask",mask)
    # detect edges
    #cv2.imshow("edges",edges)
    return edges
def region_of_interest(frame):
    #changed to find ROI from original frame
    height, width, depth = frame.shape
    mask = np.zeros_like(frame)
    cropped_frame = np.zeros_like(frame)
    polygon = np.array([[
        (0, height//2),
        (width, height // 2),
        (width, height - 1),
        (0, height - 1)
    ]], np.int32)
    # on image "mask", fill a square with corner points "polygon" with 1's
    cv2.fillPoly(mask, polygon, (255,)*frame.shape[2])
    #blackens out top half of the screen
    cropped_frame = cv2.bitwise_and(frame, mask)
    # cv2.imshow("roi",cropped_frame)
    return cropped_frame
    rho = 1
    theta = np.pi / 180
    min_threshold = 10
    return line_segments
    lane_lines = []
    if line_segments is None:
        #print("no line segments detected")
        return lane_lines
    height, width,_ = frame.shape
    left_fit = []
    right_fit = []
    boundary = 1/3
            if x1 == x2:
                #print("skipping vertical lines (slope = infinity")
                continue
            slope = (y2 - y1) / (x2 - x1)
            intercept = y1 - (slope * x1)
            if slope < 0:
    if len(left_fit) > 0:
    if len(right_fit) > 0:
    return lane_lines
def make_points(frame, line):
    slope, intercept = line
    if slope == 0:
        slope = 0.1
    return [[x1, y1, x2, y2]]
    if lines is not None:
        for line in lines:
            for x1, y1, x2, y2 in line:
    return line_image
def display_heading_line(frame, steering_angle, line_color=(0, 0, 255), line_width=5 ):
    x1 = int(width / 2)
    y1 = height
    y2 = int(height / 2)
    return heading_image
    height,width,_ = frame.shape
    if len(lane_lines) == 2:
        mid = int(width / 2)
        y_offset = int(height / 2)
    elif len(lane_lines) == 1:
        x_offset = x2 - x1
    elif len(lane_lines) == 0:
        x_offset = 0
    return steering_angle
video = cv2.VideoCapture(0)
video.set(cv2.CAP_PROP_FRAME_WIDTH,320)
video.set(cv2.CAP_PROP_FRAME_HEIGHT,240)
##fourcc = cv2.VideoWriter_fourcc(*'XVID')
##out = cv2.VideoWriter('Original15.avi',fourcc,10,(320,240))
##out2 = cv2.VideoWriter('Direction15.avi',fourcc,10,(320,240))
speed = 7.96
lastTime = 0
lastError = 0
kp = 0.095
kd = kp * 0.07 #0.05
foundStop = False
red = 0
PWM.set_duty_cycle(throttlePin, speed)
i = 0
while i < 300:
    ret,frame = video.read()
    frame = cv2.resize(frame, (80, 60), interpolation=cv2.INTER_AREA)
    # frame = cv2.flip(frame,-1)
    if red > 1:
    #cv2.imshow("original",frame)
    #computed first so it doesnt have to be found each time for edges and stop sign detection
    roi = region_of_interest(frame)
    #moved outside detect edges to only convert roi frame once
    hsv = cv2.cvtColor(roi, cv2.COLOR_BGR2HSV)
    #check for stops
    if detect_stop(hsv):
        #makes sure it's detecting stop for the first time
        if not foundStop:
            #sleep for 3 seconds and set the speed to 0
            PWM.set_duty_cycle(throttlePin, 7.5)
            time.sleep(3)
            #notes that we detected it for the first time, will not run again until another stop sign
            foundStop = True
            speed += .025
            #print("STOOOOOOOOOOOOOOOOP")
            red += 1
            continue
            PWM.set_duty_cycle(throttlePin,speed)
    #if no stop sign but foundStop is true -> we just passed a stop sign
    elif foundStop:
        #set foundStop to false for the next time
        foundStop = False
    # print(i)
    edges = detect_edges(hsv)
    line_segments = detect_line_segments(edges)
    lane_lines = average_slope_intercept(frame,line_segments)
    lane_lines_image = display_lines(frame,lane_lines)
    heading_image = display_heading_line(lane_lines_image,steering_angle)
    #cv2.imshow("heading line",heading_image)
    now = time.time()
    dt = now - lastTime
    error = -1*deviation
    if deviation < 13 and deviation > -13:
        deviation = 0
        error = 0
    #    PWM.set_duty_cycle(steeringPin,7.5)
    # elif deviation > 5:
    #    PWM.set_duty_cycle(steeringPin,7.2)
    # elif deviation < -5:
    #     PWM.set_duty_cycle(steeringPin,7.9)
    proportional = kp * (error)
    PD = 7.5 + derivative + proportional
    if PD > 8.7:
         PD = 8.7
    if PD < 6.3:
         PD = 6.3
    print(PD, speed, error, derivative, proportional)
    if abs(error - lastError) <= 10 and i < 100: # 5
        lastError = error
        lastTime = time.time()
        continue
    PWM.set_duty_cycle(steeringPin,PD)
    if abs(PD- 7.5) > .80:
        PWM.set_duty_cycle(throttlePin,speed-.005)
    lastError = error
#    out.write(frame)
#    out2.write(heading_image)
    i += 1
    key = cv2.waitKey(1)
    if key == 27:
#print("Reseted")
video.release()
##out.release()
##out2.release()
cv2.destroyAllWindows()
PWM.cleanup()
Madeline Stern
Madeline Stern
2 projects • 1 follower
Katrina Ji
Katrina Ji
2 projects • 0 followers
Angela Liu
Angela Liu
Andrew Yan
Andrew Yan
