This Week in Beagle #22
BeagleBoard Rust Imager
BeagleConnect Freedom Fixes
My last updates seem to have caused BeagleConnect Freedom (both CC1352P7 and MSP430) flashing to break. This was reported by @OhioMeasurementDevices on Discord. I have pushed the fixes to crates.io as version 1.0.2. Additionally, I have also yanked the broken version (1.0.1).
Release v0.0.5
I have also created a new release for bb-imager-rs, which has BeagleConnect Freedom Flashing working again. Additionally, it also fixes links to MicroBlocks firmware, which were broken previously due to some SHA256 problems.
Zephyr Support for PocketBeagle 2 M4 Core
PocketBeagle 2 features the TI AM62x SoC based around an Arm Cortex-A53 multicore cluster with an Arm Cortex-M4F microcontroller, Imagination Technologies AXE-1-16 graphics processor (from revision A1), and TI programmable real-time unit subsystem microcontroller cluster coprocessors.
The PR brings ZephyrRTOS support for the Arm Cortex-M4F microcontroller. This core can be used to offload time-sensitive workflows (PWM bit-banging, Light handling, etc) allowing the A53 cores with Linux to focus on other heavier tasks.
Only UART support is present in the initial PR. However, I will slowly be adding support for other peripherals to be used from the M4F core.
Migrate MicroBlocks to GitHub
As might be visible, there has been an effort to move a lot of BeagleBoard.org development to GitHub. This week, I migrated MicroBlocks to our GitHub. Since the CI for MicroBlocks was already broken on openbeagle.org, it just felt like a good project to migrate.
PocketBeagle 2 Examples
Migrate to GitHub
The development of PocketBeagle 2 Examples will mostly happen on GitHub now. Hopefully, this will make the examples more discoverable.
Make the accelerometer example less abstracted
In a recent discussion, it was decided that the examples should try more to teach using Linux APIs instead of just how to use a library to access various peripherals. So as a start, I have added a small abstraction to make interacting with the sysfs entries a bit easier, while keeping things mostly transparent.
The accelerometer example was the first to be switched to the sysfs abstraction. The full diff can be found in the PR.
Make the light-sensor example less abstracted
Following the footsteps of the accelerometer example, I have also switched the light-sensor example to use the sysfs abstraction. The full diff can be found in the PR.
Make blinky example less abstracted
The blinky example was a bit different since it is the first example that requires writing to a sysfs entry. It is still in the draft stage, waiting for review from everyone, but can be found here.
Helpful links
