BeagleBoard Rust Imager
I am gearing up for a v1 release of BeagleBoard Rust Imager soon. As such, a lot of work went into it this week.
BB-Downloader
While working on BeagleBoard Rust Imager, I initially tried searching for crates that provided the kind of downloading functionality I needed. The features I needed were the following:
- Cache downloads to a specific location.
- Use SHA256 for caching.
- Live progress
- Async
I did not find something that met all the criteria, so I ended up rolling my own. Initially, it was just part of bb-imager
, but it was overdue for a refactor, so I thought might as well spin it up as its own crate. It is now in crates.io.
BB-Config
BeagleBoard.org maintains a distros.json which contains information regarding the distro images available for each board. The format is defined by Raspberry Pi Imager (old bb-imager was a fork of it), and is still being used by the Rust imager.
I have created a data structure (using serde) to parse and generate this config format. It was initially part of bb-imager
, but since it was also in need of refactor, I have spun it off as an independent crate.
Note: While the config format used by bb-imager-rs
is compatible with the old bb-imager
, it is strictly speaking more of a subset. So it should probably not be used for working with the old imager.
BB-Flasher
With all the refactoring of bb-imager
library, the only functionality that was left in the crate was for flashing. So, I have renamed the crate to bb-flaser
and just made a lot of general improvements in the code. Additionally, BeagleConnect Freedom and MSP430 support is now optional features. This is nice since that functionality does not work on macOS right now.
Some of the individual flashers (bb-flasher-bcf and bb-flasher-sd) have already been pushed to crates.io. These aim to provide lower level functionality in a simple manner.
The bb-flasher
crate acts as a wrapper over the lower level crates, while adding the following stuff:
- Support for parsing
xz
compressed files. - Providing common trait based interface over different flashers.
- Providing common trait based interface over different types of Os Images.
- Async adapters
I have not pushed bb-flaser
to crates.io yet since PocketBeagle 2 MSPM0 flasher is still not ready to be pushed to crates.io. Let’s see when the time comes for it.
GitHub Migration
As an experiment to attract more contributors, I have decided to migrate BeagleBoard Rust Imager to GitHub.
I am still in the middle of figuring out the migration to GitHub Actions, but things seem to be working decently well. GitHub CI has a lot of friendly actions, so it has been pretty simple. However, I feel like GitLab CI is still much easier to test locally, since there are no magic actions.
I also now have a continuous integration pre-release, which is quite useful. I also ended up simplifying the CI quite a bit (no longer building packages in PR CLIs) to avoid going over the free CI limits.
Let’s hope that GitHub migration proves fruitful.
Cargo Packager
As a part of GitHub migration, I ended up revisiting how I was generating the different packages. I was aware of the existence of cargo-packager for a while, but I had been bitten by cargo-dist in the past, so I was a bit cautious regarding switching to something generic again.
However, since I was doing a huge migration anyway, I thought I might as well use something standard for packaging. I was pleasantly surprised to see how simply I was able to do migration for the GUI. Here are the things I like about it:
- Much simpler that my custom Makefile/justfile solution.
- Does not need me to create the deb package inside the cross container.
- AppImage creation works flawlessly as well.
- Now have a Windows installer using Wix.
However, I am not currently using it for the CLI. The reason is that there is no way to disable generating desktop entry right now. CLIs like bb-imager-cli should not have a desktop entry in the package, so this poses a problem. I have created a PR to disable it, so hopefully, I can complete my migration soon.
I also think that it should probably migrate to the newer go-appimage tools for generating AppImages (it currently uses linuxdeployqt). Hopefully, I will get time to create PR regarding this soon.
Export Symbols Patch
Since there was almost no discussion in the v1 Export Symbols Patch, I have sent v2 with better examples, and trailers. Hopefully, I will get some feedback this time. Feel free to check it out in the mailing list.
