This Week in Beagle #18
BeagleBoard Rust Imager
I have been planning to make BeagleBoard Rust Imager more modular, and extract some of its functionality to other crates. This was to clean up bb-imager (library that powers the GUI and CLI), which now had a lot of platform specific functionality.
The cleanup also helped get some significant performance improvements, which is always nice to see. Let’s go over the crates that are now in crates.io.
bb-drivelist
I have been using a patched version of rs-drivelist for a while in bb-imager. This was because the version published in crates.io did not have macOS support. I did contribute the patches upstream, and they were merged. However, it seems that due to some personal issues, the original author cannot push a new release.
Additionally, I also wanted to drop dependencies on the old json crate, and instead use a serde based solution. So I finally decided to make a hard fork and publish a new release.
It would be nice if I could also drop wiapi in favor of windows, but that seems a bit more work that I have the time for right now. So if anyone wants to take a crack at it, feel free to try.
bb-flasher-bcf
Support for BeagleConnect Freedom was the main reason for the creating BeagleBoard Rust Imager. It has been present for a while, so, was straightforward to extract. The bb-flasher-bcf crate contains support for both CC1352P7 and MSP430F5503, which serves as the USB to UART bridge.
I have also made the flashing sync, since I feel that most of the flashing should be done in separate threads. The flashing still includes support for real-time progress and early cancellation.
The library has only been tested on Linux and Windows.
bb-flasher-sd
For the longest time, SD card flashing in BeagleBoard Rust Imager was slower than Raspberry Pi Imager. However, with all the cleanup while creating bb-flasher-sd, the flashing got a huge speed-up, and should now be similar to Raspberry Pi Imager. Additionally, I have drastically cut down on the stack usage, so that should also help.
Finally, I have moved SD card flashing to a separate OS thread instead of tokio thread. This is because it is better to use OS threads for such long-running tasks.
The library should allow SD card flashing of OS images (even non Beagle ones) from Linux, Windows and macOS.
PocketBeagle 2 Examples
More work went into improving PocketBeagle 2 Examples. They are almost at the point where they can serve as nice getting started to teach new people about embedded programming.
Sysfs LED
The original LED abstraction in Beagle Helper library only supported GPIO pins. However, some LEDs (like USR_LED{1-4} in PocketBeagle 2) are defined in the devicetree and use the Kernel LED driver.
I have added support in LED abstraction to allow using LEDs defined in the devicetree using the sysfs entry. I have also modified the PocketBeagle 2 blinky example to use USR_LED4, since it seemed better to not require external LED for a simple blinky example.
Update README
The README of all the examples for PocketBeagle 2 have been greatly improved. They now follow a common structure with the following sections:
  1. Goal: Goals of the example
  2. Overview: Details regarding the background of the example.
  3. Challenges: Some challenges to get better acquainted with the example.
They should provide a better start for creating tutorials using the examples.
CI Testing
All the Rust examples were already being built in CI to ensure that at least everything builds fine. However, I was not certain how to do it for an interpreted language like Python. However, I have now started using pylint, which seems to provide at least a basic level of guarantees regarding all python examples.
Helpful links
