Hello everyone. This week mostly involved a lot of chasing stuff around (sometimes in vain), so while there was not much headline work, this post might end up a bit longer than usual. Let’s get started without delay.
BeagleConnect Freedom Adventures
I started the week by trying to add IEEE802154 subg socket support in MicroPython for BeagleConnect Freedom. However, I quickly learned that it would not be simple. For some reason, BeagleConnect Freedom would completely lock up after starting.
Initially, I thought it might be a MicroPython issue, so I tried tracking down where the freeze happened. This, however, led to a dead end since, for some reason, the program would not be able to read from the UART console. While doing this, I also remembered a similar issue I encountered while working on BeagleConnect Freedom rc car demo. At the time, I fixed it by just removing unused config items like ADC and PWM from config, but forgot about it after the OOSC conference.
After some experimenting with PWM, ADC, and IEEE802154 subg radio, I figured out that the problem is reproducible in other Zephyr samples like echo_cliet, etc. For some reason, if both PWM pins (MB1 PWM and MB2 PWM) are enabled alongside the subg radio, everything freezes. If one or both of the PWM are disabled, everything works fine. This seems to be an issue with timers but it needs further investigation.
I have created a Zephyr issue and a Ti E2E question for the same.
Code Composer Studio Theia Adventures
With the MicroPython issue and a bricked BeagleConnect Freedom, I thought it is a good time to setup and learn Ti’s Code Composer Studio.
I use Fedora Sway Atomic as my daily driver, and thus mostly rely on flatpaks or podman containers. However, running Code Composer Studio inside a podman container (created using toolbox) was not a great experience for me. It would randomly stutter (maybe a hardware acceleration problem?) and freeze. Additionally, while udev can make it almost painless to handle device permissions, it can occasionally cause hiccups with flashing. In fact, one of the primary reasons I switched to neovim was that my emacs GUI kept having weird performance problems inside the container.
So, I finally went ahead and installed CCS Theia on my base system. The install procedure is a bit weird since there is no rpm
or deb
package. Instead, there is an installer which installs everything in $HOME/ti
folder. It also creates an uninstall, which seems to work. All in all, while I prefer a flatpack or app image, it wasn’t too bad.
I hit a snag quite early on when I was unable to flash the cc1352p1 on my launchpad. I tried various things and opened a Ti E2E question for the same. However, the solution turned out to be quite weird. I was not saving my workspace since, well, nothing was working anyway, and CCS Theia would open the unsaved workspace. But everything magically worked once I saved my workspace because I was tired of the dialog on exit. Not really sure why.
Once I could flash the launchpad, I tried using the xds110 in launchpad with my BeagleConnect Freedom. I was able to flash a simple blinky on it and even set up breakpoints.
Now, I need to figure out how to use openocd and add instructions in Beagle docs and Zephyr docs for the same.
KUnit Adventures
I have been working on kernel patches that require writing some unit tests. So I was trying to get KUnit to work. However, kunit run
kept on failing for some reason, even with the default config. The output was not very clear either. However, after following some debugging instructions, I found out that I could not execute the user mode kernel from inside the podman container. I have created an issue in Fedora toolbox regarding the same.
MicroPython
I have added MicroPython support for BeaglePlay cc1352p7 in my draft PR. It supports IEEE802154 subg sockets and also helped me ensure that MicroPython networking should work fine on BeagleConnect Freedom as well once the timer issue is resolved.
Since BeaglePlay cc1352p7 Zephyr support was merged after the 3.7.0 release, the MicroPython support will continue to live in the draft PR until MicroPython supports a newer Zephyr version.
Zephyr
Zephyr support for BeagleBoard boards continues to improve. We will continue to work to make Beagle one of the best-supported platforms for Zephyr development.
BeagleBone AI-64
Thanks to the work by Andrew Davis, Zephyr support for R5 cores in BeagleBone AI64 was merged this week. Here is the Zephyr page for BeagleBone AI 54. This adds one more board to the growing list of BeagleBoard boards that support Zephyr.
BeagleY-AI
A PR for Zephyr support was opened by Andrew Davis after BBAI-64 support was merged. Anyone interested should feel free to try it out. Hopefully, it can get merged upstream soon.
BeagleBoard Imager Rust Updates
While working on BeagleY-AI, I found a bug in the sha256 handling of the Rust-based imager while translating the old bb-imager config. So, I have created release 0.0.2 for the imager. I probably should implement changelogs before the next release.
