Reed KaczmarekJeffrey CalhounJacques St. LouisJon Key
2Hot2Handle
Using a BeagleBone Black, this coffee temperature detector works in an Internet of Things to create a comprehensive and useful display.
IntermediateFull instructions provided1,351
2Hot2Handle
BLE 4.0 USB Dongle
cc2650 Sensor Tag
LED (generic)
LED (generic)
×3
Buzzer
BeagleBone Schematic
We used Eagle CAD to draw the circuit related to the BeagleBone Black.
SensorTag_BLE
This is the script we run on the beaglebone black to connect with the sensortag and to display the results.
import binascii
import pexpect
import sys
def floatfromhex(h):
    t = float.fromhex(h)
    if t > float.fromhex('7FFF'):
        t = -(float.fromhex('FFFF') - t)
        pass
    return t
GPIO.setup("P8_18", GPIO.OUT) #BLUE LED
GPIO.setup("P8_14", GPIO.OUT) #RED LED
GPIO.setup("P8_16", GPIO.OUT) #GREEN LED
GPIO.output("P8_18", GPIO.LOW)
GPIO.output("P8_14", GPIO.HIGH) #RED LED ON
GPIO.output("P8_16", GPIO.LOW)
bluetooth_adr = 'C4:BE:84:71:0D:80'
tool = pexpect.spawn('gatttool -b ' + bluetooth_adr + ' -I')
tool.expect('\[LE\]>')
print "\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\nPreparing to connect...\n\n\n\n\n\n"
tool.sendline('connect')
# test for success of connect
tool.expect('\[CON\].*>')
print "\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\nConnected!\n\n\n\n\n\n"
GPIO.output("P8_18", GPIO.HIGH) #BLUE LED ON SINCE BLE IS CONNECTED
ready_temp = 40
print "\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\nPick a Profile (by number):\n1-Tough Guy, 2-Hot Head, 3-Medium Man, 4-Lukewarm Larry, or 5-Ice-Cold Izzy\n\n\n\n\n"
name = raw_input()
if(name == '1'):
    ready_temp = 50
    if(name == '2'):
        ready_temp = 48
        if(name == '3'):
            ready_temp = 46
            if(name == '4'):
                ready_temp = 44
                ready_temp = 42
print "\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\nBeverage enjoyment temperature set at: ", ready_temp, " C, ", ((float)(1.8*ready_temp) + 32), " F\n\n\n\n\n\n"
tool.sendline('char-write-cmd 0x24 01')
time.sleep(2)
ready_flag = 0
    tool.sendline('char-read-hnd 0x21')
    tool.expect('descriptor: .*')
    rval = tool.after.split()
    objT = floatfromhex((rval[2] + rval[1]))
    objT_shift = ((objT/4))
    output_obj = ((float)(objT_shift)) * 0.03125
    ambT = floatfromhex(rval[4] + rval[3])
    ambT_shift = ((ambT/4))
    output_amb = ((float)(ambT_shift)) * 0.03125
    print "\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\nToo Hot To Handle\nTemperature Dashboard:\n\nIR Temp: ", output_obj, " C,  ", (1.8*output_obj + 32), " F"
    print "Ambient Temp: ", output_amb, "  C,  ", (1.8*output_amb + 32), " F\n\n\n\n\n\n"
    if(output_obj > (ready_temp + 2)): #real use 55
        ready_flag = ready_flag + 1
    if((ready_flag > 3) and (output_obj < ready_temp)): #real use 53
        #CHANGE GPIO pins for LED
        GPIO.output("P8_14", GPIO.LOW)
        GPIO.output("P8_16", GPIO.HIGH)
        #PRINT TO MONITOR
        print "\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\nYour beverage is no longer Too Hot To Handle!\n\t\t   Enjoy!\n\n\n\n\n\n"
        #BUZZER 3 BEEPS
        tool.sendline('char-write-cmd 0x50 01')
        time.sleep(0.5)
        tool.sendline('char-write-cmd 0x50 00')
        time.sleep(0.5)
        time.sleep(0.5)
        time.sleep(0.5)
        time.sleep(0.5)
        time.sleep(5)
Reed Kaczmarek
Reed Kaczmarek
0 projects • 3 followers
Jeffrey Calhoun
Jeffrey Calhoun
0 projects • 2 followers
Jacques St. Louis
Jacques St. Louis
Jon Key
Jon Key
