Rebecca Liu
Light Up Multi-Kpop Group Fan Display with Music
For kpop fans who stan more than one group and want to jam out to their groups' best hits while showing support with the light display.
BeginnerFull instructions provided61
BeagleBoard.org PocketBeagle
Sabrent USB External Stereo Sound Adapter for Windows and Mac.
4-Port USB 3.0 Hub with Individual LED Power Switches
HKBAYI 240 pixels programmable RGB LED Strip
OontZ Angle 3 - Bluetooth Portable Speaker
USB 2.0 A Male Plug to 5 Pin Female Bolt Screw Shield terminals Pluggable Type Adapter
Adafruit Colorful Round Tactile Button Switch
×6
Female USB Type A adapter
Through Hole Resistor, 1.5 kohm
×6
Jumper wires (generic)
Audio Schematic
Use this to build the audio and controls hardware setup.
Full Schematic
This is what the circuit should look like in the final product.
Power Block Diagram
Final Full Code
Includes the lights and audio portions of the project.
#!/usr/bin/env python
Multi-Fandom Kpop Light Display with Music
License:
Copyright 2019 Rebecca Liu
Software API:
  * play_song(song)
      - Plays song(s) through USB audio connected speakers. Media format must be in mp3. Multiple songs must be in a list.
  * mpg123 -() filename.mp3
      - command line audio player that can take in individual song files in mp3 format or multiple audio files at once in a list
  * opc.client ensures that server is running so that LED string can be displayed
Background Information:
    * Uses USB audio adapter and push button controls. Plays stored mp3 files that are downloaded onto PocketBeagle.
    * Key functions used:
        - glob - returns an array of files by identifying a pattern that can be used to match multiple files
          (i.e. * or ?, etc) in the specified path
        - subprocess - creates a new process and allows for running of terminal commands
        - mpg123 - command line audio player that is compatible with mp3 files.
          Has several variable arguments which can be appended with the command for different effects and control
          https://linux.die.net/man/1/mpg123 provides all of the possible extensions that can be used with mpg123
    * Base code for LED functions came from the following repositories:
        https://markayoder.github.io/PRUCookbook/01case/case.html#_neopixels_5050_rgb_leds_with_integrated_drivers_ledscape
        https://markayoder.github.io/PRUCookbook/06io/io.html#io_uio
        https://github.com/Yona-Appletree/LEDscape.git
        https://github.com/zestyping/openpixelcontrol
import opc
from glob import glob
import subprocess
BUTTONC                      = "P2_24" #blue stop button
BUTTONK                      = "P2_22" #black button
BUTTONY                      = "P2_20" #yellow button
BUTTONG                      = "P2_18" #green button
BUTTONR                      = "P2_19" #red button
BUTTONB                      = "P2_17" #blue button
ADDRESS                      = 'localhost:7890'
process                      = None    #set value for process variable
# Create a client object
client = opc.Client(ADDRESS)
# Test if it can connect
if client.can_connect():
    print ('connected to %s' % ADDRESS)
    # We could exit here, but instead let's just print a warning
    # and then keep trying to send pixels in case the server
    # appears later
    print ('WARNING: could not connect to %s' % ADDRESS)
def play_song(song):
    """Play selected set of songs"""
    global process
    #if something is playing, kill the process (i.e. stop the music) so that new process (i.e. play new set of songs) can be started
    if not process == None:
        process.kill()
    #set slight delay to decrease sound distortion
    #define process: mpg123 -Z used to play songs in a playlist continuously at random, subprocess creates new process for mpg123
    process = subprocess.Popen(['/usr/bin/mpg123','-Z'] + glob(song))
#end def
def setup():
    """Setup the hardware components."""
    # Initialize Buttons
    GPIO.setup(BUTTONK,GPIO.IN)
    GPIO.setup(BUTTONY,GPIO.IN)
    GPIO.setup(BUTTONG,GPIO.IN)
    GPIO.setup(BUTTONR,GPIO.IN)
    GPIO.setup(BUTTONB,GPIO.IN)
    GPIO.setup(BUTTONC,GPIO.IN)
#end def
# Black out all of the LEDs
STR_LEN=240
for i in range(STR_LEN):
    leds = [(0, 0, 0)] * STR_LEN
def task():
        #wait for button press
        if(GPIO.input(BUTTONB) == 0):
            #set light display CHEN
            for i in range(7,31):
                leds[i] = (0,128,255)
            for i in range(215,239):
            for i in [7,31,33,57,59,83,85,109,111,135,137,161,163,187,189,213,215,239]:
            for i in [145,180,181,142,130,90,77,76,93,178,146,126,94,74,125,176,148,124,96,72,175,149,123,97,71,174,173,122,70,69,172,152,120,100,68,153,118,103,64,104,116,156,168]:
            #pass light display to LEDs
            if client.put_pixels(leds, channel=0):
                pass
                #print ('sent')
                print ('not connected')
            time.sleep(0.1)
            #call function to play the songs in this playlist
            play_song('/var/lib/cloud9/ENGI301/Project1/Chen/*.mp3')
        elif(GPIO.input(BUTTONR) == 0):
            #set light display BIGBANG
                leds[i] = (255,0,0)
                leds[i] = (255,0,0)
                leds[i] = (255,0,0)
            for i in [185,139,133,87,81,184,141,132,89,80,182,142,130,90,78,179,180,143,129,91,76,75,93,127,128,178,146,126,94,74,177,148,125,96,73,149,123,97,71,174,151,121,99,69,122,172,152,120,100,68,153,102,65,103,117,155,169,166,167,156,116,104,63,62,106,114,115]:
                leds[i] = (255,0,0)
                pass
                #print ('sent')
            time.sleep(0.1)
            play_song('/var/lib/cloud9/ENGI301/Project1/BigBang/*.mp3')
        elif(GPIO.input(BUTTONG) == 0):
            #set light display NCT
                leds[i] = (0,255,0)
                leds[i] = (0,255,0)
                leds[i] = (0,255,0)
            for i in [182,142,130,90,78,143,128,93,74,94,126,146,178,150,175,176,147,125,95,72,71,98,173,172,171,170,169,153,119,101,67]:
                leds[i] = (0,255,0)
                pass
                #print ('sent')
            time.sleep(0.1)
            play_song('/var/lib/cloud9/ENGI301/Project1/NCT/*.mp3')
        elif(GPIO.input(BUTTONY) == 0):
            #set light display INFINITE
                leds[i] = (255,255,0)
            for i in [185,139,133,87,81,184,140,132,88,80,141,90,77,91,129,143,181,180,144,128,92,76,179,178,127,177,147,125,95,73,176,148,124,96,72,149,98,69,99,121,151,173,172,152,120,100,68,171,170,169,154,118,102,66,168,156,116,104,64,167,166,115,63,62]:
                pass
                #print ('sent')
            time.sleep(0.1)
            play_song('/var/lib/cloud9/ENGI301/Project1/Infinite/*.mp3')
        elif(GPIO.input(BUTTONK) == 0):
            #set light display EXO
                leds[i] = (255,255,255)
            for i in [182,142,130,90,78,181,180,179,129,128,77,76,75,177,148,123,98,69,73,96,150,173,171,170,169,168,156,116,104,64,65,66,67,101,119,153]:
                pass
                #print ('sent')
            time.sleep(0.1)
            play_song('/var/lib/cloud9/ENGI301/Project1/EXO/*.mp3')
            #NOTE: the path for the playlist MUST be correct and complete otherwise program will not be able to find variable 'song' for function play_song
        elif(GPIO.input(BUTTONC) == 0):
            #turn all the LEDs off
            for i in range(0,240):
                leds[i] = (0,0,0)
            #pass to string light
                pass
                #print ('sent')
            time.sleep(0.1)
            #stop all processes when the control button is pressed
            process.kill()
#end def
# Main script
if __name__ == '__main__':
    setup()
        task()
    except KeyboardInterrupt:
        pass
    print("Program Complete.")
GitHub Repository for Multi-Fandom Kpop Light Display with Music
Rebecca Liu
Rebecca Liu
Thanks to Erik Welsh.
