Nikhita GanglaCathy Wicks
Published © GPL3+
Mini AC Unit with PocketBeagle® & Mikro Click Boards™
Make a mini AC unit to keep you cool! Add MikroElektronika DC Motor & Weather Click Boards to a BeagleBoard. org® PocketBeagle®.
BeginnerFull instructions provided2 hours252
BeagleBoard.org PocketBeagle
MikroElektronika Weather Click
MikroElektronika DC Motor Click
Snap Circuits 6SCM1 Motor
Snap Circuits 6SCM1F Fan
Battery, 1.2 V
Battery, 1.2 V
×6
Hook Up Wire Kit, 22 AWG
TempSensor directory
Drag and drop zip folder into /var/lib/cloud9 directory, and then unzip
No preview (download only).
DC Motor Driver
Drag and drop into /var/lib/cloud9 directory
MikroElectronica DC Motor Click Driver
License:
Copyright 2019, Octavo Systems, LLC. All rights reserved.
Software API:
  Change direction and speed of motor on MikroElectronica DC Motor Click
import os
import Adafruit_BBIO.PWM as PWM1
# set direction constants for select2
FORWARD  = 0
REVERSE  = 1
# set direction constants for select1
MODE0    = 0
MODE1    = 1
# set minimum and mazimum thresholds for PWM
PWM_MIN  = 0
PWM_MAX  = 100
class DC_Motor():
    def __init__(self):
        self.select1 = MODE0
        self.select2 = FORWARD
        self.PWM     = PWM_MIN
        # Pin configuration
        os.system("config-pin P1_2 gpio")       # nsleep
        os.system("config-pin P1_4 gpio")       # select1
        os.system("config-pin P1_6 gpio")       # select2
        os.system("config-pin P2_1 pwm")        # pwm
        os.system("config-pin P2_3 gpio")       # fault
        # initialize GPIO
        # Set up pins as inputs or outputs
        GPIO.setup("P1_2", GPIO.OUT)            # P1.2 is output
        GPIO.setup("P1_4", GPIO.OUT)            # P1.4 is output
        GPIO.setup("P1_6", GPIO.OUT)            # P1.6 is output
        GPIO.setup("P2_3", GPIO.IN)             # P2.3 is input
        # set GPIO output pins to default values
        GPIO.output("P1_2", 1)
        GPIO.output("P1_4", MODE0)
        GPIO.output("P1_6", FORWARD)
        # initialize PWM
        # Set up and start given PWM channel
        PWM1.start("P2_1", PWM_MIN)
    # End def
    # set direction of turning
    def set_direction(self, direction):
        # See datasheet for table
        if select1 == MODE0:
            self.select2 = direction
            GPIO.output("P1_6", direction)
            self.select2 = ((~direction) & 0x1)
            GPIO.output("P1_6", ((~direction) & 0x1))
    # End def
      # set speed of turning
    def set_speed(self, speed):
        # only allow speeds between 0 and 100
        if ((speed >= PWM_MIN) and (speed <= PWM_MAX)):
            # new speed is only set when different from current speed
            if ((self.PWM == 0) and (speed > 0)):
                self.PWM = speed
                PWM1.start("P2_1", speed)
            elif ((self.PWM > 0) and (speed == 0)):
                self.PWM = 0
                PWM1.stop("P2_1")
            print("ERROR in speed")
    # End def
    def get_speed(self):
        return self.PWM
    # End def
    def cleanup(self):
        PWM1.cleanup()
    # End def
Nikhita Gangla
Nikhita Gangla
3 projects • 1 follower
Cathy Wicks
Cathy Wicks
18 projects • 11 followers
Beagleboard.org fan
