Zoran Roncevic
Published © GPL3+
BeagleBone with Accelerometer MM8452
Simple article for BeagleBone and Sparkfun MM8452 accelerometer. Python code is used.
BeginnerProtip30 minutes2,046
MikroElektronika MicroBUS Cape
SparkFun Triple Axis Accelerometer MMA8452Q
mm8452.py
Python library for MMA8452 breakout board
from Adafruit_I2C import Adafruit_I2C
def twos_comp(val, bits):
    """compute the 2's compliment of int value val"""
    if (val & (1 << (bits - 1))) != 0: # if sign bit is set e.g., 8bit: 128-255
        val = val - (1 << bits)        # compute negative value
    return val
class MM8452_ACCEL :
    address = None
    i2C = None
    scale = None
    SCALE_2G = 2
    SCALE_4G = 4
    SCALE_8G = 8
    ODR_800 = 0 # output data rate
    ODR_400 = 1
    ODR_200 = 2
    ODR_100 = 3
    ODR_50 = 4
    ODR_12 = 5
    ODR_6 = 6
    ODR_1 = 7
    WHO_AM_I = 0x0D
    STATUS = 0x00
    OUT_X_MSB = 0x01
    OUT_X_LSB = 0x02
    OUT_Y_MSB = 0x03
    OUT_Y_LSB = 0x04
    OUT_Z_MSB = 0x05
    OUT_Z_LSB = 0x06
    CTRL_REG1 = 0x2A
    XYZ_DATA_CFG = 0x0E
    def __init__(self, address = 0x1D):
        self.address = address
        self.i2C = Adafruit_I2C(self.address)
    def whoAmI(self):
        reg_val = self.i2C.readU8(self.WHO_AM_I)
        return reg_val
    def standby(self):
        reg_val = self.i2C.readU8(self.CTRL_REG1)
        reg_val = reg_val & 0xFE # clear the active bit
        self.i2C.write8(self.CTRL_REG1,reg_val)
    def active(self):
        reg_val = reg_val | 0x01 # set the active bit
    def config(self, fsr = 2, odr = 0):
        self.scale = fsr
        self.standby()
        self.setScale(self.scale)
        self.setODR(odr)
        self.active()
    def setScale(self, scale):
        # must be in standby mode!
        reg_val = self.i2C.readU8(self.XYZ_DATA_CFG)
        reg_val = reg_val & 0xFC
        scale = scale >> 2
        reg_val = reg_val | scale
        self.i2C.write8(self.XYZ_DATA_CFG,reg_val)
    def setODR(self,odr):
        reg_val = reg_val & 0xCF # clear the active bit
        odr = odr << 3
        reg_val = reg_val | odr
    def available(self):
        reg_val = self.i2C.readU8(self.STATUS)
        reg_val = reg_val & 0x08
        reg_val = reg_val >> 3
        return reg_val
    def readX(self):
        reg_XH = self.i2C.readU8(self.OUT_X_MSB)
        reg_XL = self.i2C.readU8(self.OUT_X_LSB)
        reg_x = (reg_XH << 8) | (reg_XL)
        res = reg_x >> 4
        res = twos_comp(res,12)
        return res
    def readY(self):
        reg_YH = self.i2C.readU8(self.OUT_Y_MSB)
        reg_YL = self.i2C.readU8(self.OUT_Y_LSB)
        reg_x = (reg_YH << 8) | (reg_YL)
        res = reg_x >> 4
        return res
    def readZ(self):
        reg_ZH = self.i2C.readU8(self.OUT_Z_MSB)
        reg_ZL = self.i2C.readU8(self.OUT_Z_LSB)
        reg_x = (reg_ZH << 8) | (reg_ZL)
        res = reg_x >> 4
        return res
accel.py
Example code for testing
from mm8452 import MM8452_ACCEL
acc = MM8452_ACCEL()
print format(acc.whoAmI(),'02x')
acc.config(acc.SCALE_8G, acc.ODR_100)
time.sleep(0.1)
while 1:
    if acc.available():
        print acc.readX(), acc.readY() , acc.readZ()
        time.sleep(0.3)
Zoran Roncevic
Zoran Roncevic
3 projects • 123 followers
Hackster Live ambassador in Serbia. Organizer of Maker NS community.
