Logan BaldridgeErik Welsh
Published © MIT
Spotify-Pod: Streaming Music to the PocketBeagle
Create your own headless music player with the PocketBeagle and Mopidy!
ExpertWork in progress8 hours1,559
BeagleBoard.org PocketBeagle
pHAT DAC
Pimoroni pHAT DAC
Adafruit 1.8" Color TFT LCD
Adafruit USB Mini Hub with Power Switch
Edimax USB Wifi Dongle
Plugable USB Audio Adapter
Fritzing Diagram
Simplified Diagram
mopidy.config
Plain text
This is an example config file for Mopidy
# For further information about options in this file see:
#   http://docs.mopidy.com/
# The initial commented out values reflect the defaults as of:
#   Mopidy 2.2.1
#   Mopidy-EvtDev 0.1.1
#   Mopidy-File 2.2.1
#   Mopidy-HTTP 2.2.1
#   Mopidy-Local 2.2.1
#   Mopidy-M3U 2.2.1
#   Mopidy-MPD 2.2.1
#   Mopidy-SoftwareMixer 2.2.1
#   Mopidy-Spotify 3.1.0
#   Mopidy-Stream 2.2.1
#   Mopidy-Touchscreen 1.0.0
# Available options and defaults might have changed since then,
# run `mopidy config` to see the current effective config and
# `mopidy --version` to check the current version.
[core]
#cache_dir = $XDG_CACHE_DIR/mopidy
#config_dir = $XDG_CONFIG_DIR/mopidy
#data_dir = $XDG_DATA_DIR/mopidy
#max_tracklist_length = 10000
#restore_state = false
[logging]
#color = true
#console_format = %(levelname)-8s %(message)s
#debug_format = %(levelname)-8s %(asctime)s [%(process)d:%(threadName)s] %(name)s\n  %(message)s
#debug_file = mopidy.log
#config_file =
[audio]
#mixer = software
#mixer_volume =
#output = autoaudiosink
#buffer_time =
[proxy]
#scheme =
#hostname =
#port =
#username =
#password =
[mpd]
#enabled = true
#hostname = 127.0.0.1
#port = 6600
#password =
#max_connections = 20
#connection_timeout = 60
#zeroconf = Mopidy MPD server on $hostname
#command_blacklist =
#  listall
#  listallinfo
#default_playlist_scheme = m3u
[http]
#enabled = true
#hostname = 192.168.7.2
#port = 6680
#static_dir =
#zeroconf = Mopidy HTTP server on $hostname
#allowed_origins =
#csrf_protection = true
[stream]
#enabled = true
#protocols =
#  http
#  https
#  mms
#  rtmp
#  rtmps
#  rtsp
#metadata_blacklist =
#timeout = 5000
[m3u]
#enabled = true
#base_dir =
#default_encoding = latin-1
#default_extension = .m3u8
#playlists_dir =
[softwaremixer]
#enabled = true
[file]
#enabled = true
#media_dirs =
#  $XDG_MUSIC_DIR|Music
#  ~/|Home
#excluded_file_extensions =
#show_dotfiles = false
#follow_symlinks = false
#metadata_timeout = 1000
[local]
enabled = false
#library = json
#media_dir =
#scan_timeout = 1000
#scan_flush_threshold = 100
#scan_follow_symlinks = false
#  .directory
#  .html
#  .log
#  .nfo
#  .txt
[touchscreen]
enabled = true
screen_width = 320
screen_height = 240
resolution_factor = 8
cursor = true
fullscreen = true
#cache_dir = $XDG_CACHE_DIR/mopidy/touchscreen
gpio = false
#gpio_left = 4
#gpio_right = 27
#gpio_up = 22
#gpio_down = 23
#gpio_enter = 24
#sdl_audiodriver = disk
#sdl_path_dsp = /dev/null
sdl_fbdev = /dev/fb0
sdl_mousdrv = TSLIB
sdl_mousedev = event0
[evtdev]
#enabled = true
#dev_dir = /dev/input
#devices =
#refresh = 10
#vol_step_size = 10
[spotify]
enabled = true
username = *************
password = ********************
client_id = ***********************
client_secret = ********************************
#bitrate = 160
volume_normalization = true
#private_session = false
#timeout = 10
#allow_cache = true
#allow_network = true
#allow_playlists = true
#search_album_count = 20
#search_artist_count = 10
#search_track_count = 50
#toplist_countries =
Spotify-Pod Github
Logan Baldridge
Logan Baldridge
Erik Welsh
Erik Welsh
12 projects • 12 followers
