Irene Kwon
All-in-One Morning Updates with PocketBeagle
PocketBeagle tablet device that displays the weather (highs and lows) for the day as well as the news headlines of the day.
BeginnerFull instructions provided748
BeagleBoard.org PocketBeagle
Adafruit 2.8" TFT LCD with Touchscreen Breakout Board w/ MicroSD Socket
EDIMAX Wi-Fi Nano USB Adapter N150
Cylewet 25Pcs 12x12x7.3mm Momentary Tact Tactile Push Button Switch Touch Switch Micro Switch 4 Pins SMD PCB with Cap for Arduino (Pack of 25) CYT1009
Resistor 1k ohm
Resistor 1k ohm
Soldering Station, 110 V
Complete Circuit Diagram of PocketBeagle and Components
Script to Display News Headlines and Weather Data
Imports the individual scripts for each task (gathering news headlines and weather data) to display on the LCD screen
Display News Headlines and Daily Weather Forecast on LCD Screen
License:
Copyright 2019 Irene Kwon
Software API:
    * adafruit_rgb_display
        * used to interface ILI9341 LCD Screen with PocketBeagle
    * Adafruit_Blinka
        * used for circuit python to then use digitalio
Background Information:
    * Base code/instructions:
        * https://learn.adafruit.com/adafruit-2-dot-8-color-tft-touchscreen-breakout-v2/python-wiring-and-setup
Outline:
    - Set up the PocketBeagle and LCD screen
    - Import/use the functions to gather the necessary data
    - Display text on LCD screen
    - Control display with button
# Setup for LCD Display/Interfacing with Display
#Import necessary libraries
import os
import digitalio
import board
from PIL import Image, ImageDraw, ImageFont
import adafruit_rgb_display.ili9341 as ili9341
#Define the CS, DC, and Reset pins
cs_pin    = digitalio.DigitalInOut(board.P2_2)
dc_pin    = digitalio.DigitalInOut(board.P2_4)
reset_pin = digitalio.DigitalInOut(board.P2_6)
# Config for display baudrate (default max is 24mhz):
BAUDRATE  = 24000000
# Setup the SPI bus
spi       = board.SPI()
# Create the display
disp      = ili9341.ILI9341(spi, rotation=90,
                            cs=cs_pin, dc=dc_pin, rst=reset_pin, baudrate=BAUDRATE)
# Setup Button
BUTTON0    = "P2_8"
# Setup FinalNews.py and FinalWeather.py and Outputs Desired
import FinalNews
import FinalWeather
import textwrap
DH_raw      = str(FinalWeather.high)
DL_raw      = str(FinalWeather.low)
DC_raw      = str(FinalWeather.curr)
News_Header = str(FinalNews.header)
Article     = FinalNews.article
News_Info   = News_Header.splitlines()
# Functions
def setup():
    GPIO.setup(BUTTON0, GPIO.IN)
    print("Setup Complete")
# End def
def setup_wifi():
    os.system("connmanctl enable wifi")
    os.system("connmanctl agent on")
    os.system("connmanctl connect wifi_74da38de508b_526963652056697369746f72_managed_none")
# End def
# For displaying on the LCD Screen
def cleanstring(string):
    cleana = string.replace("(", "")
    cleanb = cleana.replace(")", "")
    cleanc = cleanb.replace("'", "")
    cleand = cleanc.replace(",", "")
    def createRGB(disp):
        if disp.rotation % 180 == 90:
            height = disp.width   # we swap height/width to rotate it to landscape!
            width  = disp.height
            width  = disp.width   # we swap height/width to rotate it to landscape!
            height = disp.height
        image = Image.new('RGB', (width, height))
        # Reset the screen to black
        draw = ImageDraw.Draw(image)
        draw.rectangle((0, 0, width, height), outline=0, fill=(0, 0, 0))
        disp.image(image)
        # Display the desired output
        if ("Headlines" in cleand):
            size = 16
            size = 20
        fnt = ImageFont.truetype('Pillow-master/Tests/fonts/FreeMono.ttf', size)
        draw.text((0,0), text=cleand, fill = (255,255,255), font=fnt)
        disp.image(image)
    return createRGB(disp)
    # End def
# End def
def WeatherUpdate(DL_raw, DH_raw, DC_raw):
    temps     = [DC_raw, DL_raw, DH_raw][0:]
    all_temps = "\n".join(temps)
    cleanstring(all_temps)
# End def
def NewsUpdate(News_Info, Article):
    newslist = News_Info + Article
    news     = newslist[1:]
    all_news    = "\n".join(news)
    cleanstring(all_news)
def task():
    initialize        = True
    button_press      = 0
    button_press_time = 0.0
    while(1):
            # Wait for button press
            #print("Here")
            while(GPIO.input(BUTTON0) == 1):
    #            print("Here1")
                pass #don't do anything if 1, just keep coming back to check condition
            # Record time
            button_press_time = time.time()
            # Wait for button release
            while(GPIO.input(BUTTON0) == 0):
                pass
            # If instantaneously pressed (ie less than 2)
            if ((time.time() - button_press_time) > 2.0): #if beyond 2 seconds
                exit() #exits out of script
                button_press += 1
    #            print(button_press)
                #Times the button is pressed: display news (even) or weather (odd)
                # Run on the first button press to initialize the wifi
                if initialize:
                    setup_wifi()
                    initialize = False
                if (button_press % 2) == 1:
        except:
            pass
# End def
# Main Script
if __name__ == '__main__':
    setup()
        task()
    except KeyboardInterrupt:
        pass
Individual Script to Gather Weather Data
Gathering Weather Forecast (Daily Highs and Lows) from OpenWeatherMap
License:
Software API:
    * pyowm
        * Python library for OpenWeatherMap API
        * Free subscription only allows for current weather
    * Information about pyowm
        * https://buildmedia.readthedocs.org/media/pdf/pyowm/latest/pyowm.pdf
Outline:
    - Get an API key for OpenWeather
    - Retrieve daily forecast
from pyowm import OWM
#Load with the API_key for openweather
API_key  = 'ada0a3424a34c9445c81fba49df33410'
owm      = OWM(API_key)
#For Houston (city ID = 46990066)
obs      = owm.weather_at_id(4699066)
#Retrieve daily lows and highs as well as the current temperature
w        = obs.get_weather()
temp     = w.get_temperature('fahrenheit')
#Set up strings for displaying the daily forecasts
m_symbol = '\xb0' + 'F'
curr     = ('Current Temp: ', temp['temp'], m_symbol)
high     = ('Daily High: ', temp['temp_max'], m_symbol)
low      = ('Daily Low: ', temp['temp_min'], m_symbol)
#Prints the temperatures
    print(curr)
    print(high)
    print(low)
Individual Script to Gather News Headlines
Scraping News Headlines (from New York Times)
License:
Software API:
    soup.find_all
      - Finds all instances of the search keys in the parentheses
    requests.get
      - Get/retrieve data from the given url
    * Base code (adapted below):
        * https://stackoverflow.com/questions/55033291/scraping-headlines-from-news-website-homepages-using-beautifulsoup-in-python/
    * Information about libraries:
        * https://www.crummy.com/software/BeautifulSoup/bs4/doc/
Outline:
    - News headlines from New York Times
    - Scraping news headlines off of nytimes.com
    - Print the top 10 headlines
#Import necessary packages
import requests
from bs4 import BeautifulSoup
import json
import datetime
import textwrap
#Retrieve data from New York Times
url = "https://www.nytimes.com/"
r   = requests.get(url)
now = datetime.datetime.now()
now = now.strftime('%A, %B %d, %I:%M %p')
#Parse the script on the page
r_html = r.text
soup   = BeautifulSoup(r_html, "html.parser")
scripts = soup.find_all('script')
for script in scripts:
    if 'preloadedData' in script.text:
        jsonStr = script.text
        jsonStr = jsonStr.split('=', 1)[1].strip()
        jsonStr = jsonStr.rsplit(';', 1)[0]
        jsonObj = json.loads(jsonStr)
#Print the first 10 headlines
count   = 0
header  = ('%s\nHeadlines\n%s\n' %(url, now))
article = []
for ele, v in jsonObj['initialState'].items():
        if v['headline'][0] != '{':
            article.append(v['headline'])
            count += 1
    except:
        continue
    if count == 10:
GitHub for Complete Code
Irene Kwon
Irene Kwon
Thanks to Erik Welsh.
