Grace Wilson
Putt Speed Tracker
Tracks and records the speed at which a golf ball falls into the hole. Provides audio and visual feedback. Also has a history display mode.
IntermediateFull instructions provided6
Putt Speed Tracker
BeagleBoard.org PocketBeagle
Proximity Sensor
Proximity Sensor
×2
Generic Push Button
×4
Adafruit Standard LCD Display 20x4
Adafruit i2c / SPI character LCD backpack
Jumper wires (generic)
Resistor 1k ohm
Resistor 1k ohm
×6
microUSB pin adapter
microUSB to USB Adapter
USB Stereo 3D Sound Adapter
Generic Speaker
1inx1in 16in long Piece of Wood
Drill / Driver, Cordless
Green Spray Paint
Fritzing Diagram Download
Diagram of Putt Project Set Up
Fritzing Diagram
putt_main.py
Main code file.
Putt Project
License:
Copyright 2018-2020 Grace Wilson
modification, are permitted provided that the following conditions are
met:
1. Redistributions of source code must retain the above copyright notice,
this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
3. Neither the name of the copyright holder nor the names of its
contributors may be used to endorse or promote products derived from this
software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# importing necessary libraries
import os
import board
import busio
import adafruit_character_lcd.character_lcd_i2c as character_lcd
# initializing LCD Screen
i2c = busio.I2C(board.SCL, board.SDA)
cols = 20
rows = 4
lcd = character_lcd.Character_LCD_I2C(i2c, cols, rows)
# setting up GPIO inputs for sensors and butttons
GPIO.setup("P2_4", GPIO.IN) # sensor 1
GPIO.setup("P2_6", GPIO.IN) # sensor 2
GPIO.setup("P2_2", GPIO.IN) # record button
GPIO.setup("P2_8", GPIO.IN) # history button
GPIO.setup("P2_10", GPIO.IN) # gpio52 toggle1 button
GPIO.setup("P2_19", GPIO.IN) # gpio 27 toggle2 button
# initializing time variables for speed calculation
t_1 = 0.0
t_2 = 0.0
# distance between sensors
d = 17.75 # cm
# initializing variables for history collection and display
reading = []
index = 0
# record function
def record():
    # setting up for recording putt speed with "Ready" message and audio
    sensor_1 = False
    lcd.clear()
    lcd.message = ("Ready")
    os.system("aplay /var/lib/cloud9/Ready2.wav")
    # while loop that detects sensor activation and performs speed    calculation
        if sensor_1 and (time.time() - t_1 > 2.0):
            print("Reset P2_4")
            sensor_1 = False
            t_1      = 0
        if GPIO.input("P2_4") == 1 and not sensor_1:
            print("P2_4 = 1")
            sensor_1 = True
            t_1      = time.time()
        if GPIO.input("P2_6") == 1 and sensor_1:
            print("P2_6 = 1")
            t_2      = time.time()
            t        = t_2-t_1
            s        = d/t
            s = round(s, 5)
            # Appending recorded speeds
            reading.append(s)
            # Displaying speeds in real time
            lcd.message = ("speed = {0:3.7}".format(s))
            # Audio Feedback depending on detected putt speed
            if s < 60:
                os.system("aplay /var/lib/cloud9/Too_Slow.wav")
            if (s >= 60) and (s <= 80):
                os.system("aplay /var/lib/cloud9/perf_putt.wav")
            if s > 80:
                os.system("aplay /var/lib/cloud9/Too_Fast.wav")
            time.sleep(0.75)
            # clearing screen for next putt and re-initializing screen
            lcd.clear()
            sensor_1 = False
        if GPIO.input("P2_8") == 0:
        time.sleep(0.038) # based on sensor timing
# End def
# print_history function
def print_history(index):
    # initializing message
    message = ""
    # printing message
    print("history index = {0}".format(index))
    # clearing LCD screen
    lcd.clear()
    # for loop that displays and numbers the appended putts starting at 1
    for i, item in enumerate(reading):
        if (i >= index) and (i < index + 4):
            message = message + "{0}: {1}\n".format(i + 1, item)
    lcd.message = message
# End def
# history function
def history():
    print("History")
    index = 0
    # calling print history function and play history audio
    os.system("aplay /var/lib/cloud9/History.wav")
    # scrolling
        if GPIO.input("P2_10") == 0:
            print("P2_10 pressed")
            if (index > 0):
                index = index - 1
        if GPIO.input("P2_19") == 0:
            print("P2_19 pressed")
            if (index < len(reading) - 1):
                index = index + 1
        # breaks out of history display
        if GPIO.input("P2_2") == 0:
            break;
        time.sleep(0.1)
# End def
# main code
# waits for specific buttons to be pressed to carry out the different functions
        if GPIO.input("P2_2") == 1:
            pass
        time.sleep(0.1)
        if GPIO.input("P2_8") == 1:
            pass
        time.sleep(0.1)
            print("record")
            record()
        time.sleep(0.1)
            print("history")
            history()
        time.sleep(0.1)
# Keyboard interrupt
except KeyboardInterrupt:
    GPIO.cleanup()
    lcd.clear()
    print("Program Complete")
# End def
configure_pins.sh
Configures pins.
# !/bin/bash
Putt Project - Configure Pins
License:
met:
3. Neither the name of the copyright holder nor the names of its contribut
ors may be used to endorse or promote products derived from this software
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS
; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
# Configure pins for Putt Project:
#   - I2C1
#   - Sensors
#   - Buttons
# I2C1
config-pin P2_09 i2c
config-pin P2_11 i2c
# Buttons
config-pin P2_02 gpio_input # record button
config-pin P2_08 gpio_input # history button
config-pin P2_10 gpio_input # toggle1 button
config-pin P2_19 gpio_input # toggle2 button
# Sensors
config-pin P2_04 gpio_input
config-pin P2_06 gpio_input
Run Script
Run script for Putt Project
# !/bin/bash
Putt Project - Run Script
License:
met:
# Run Putt Project in /var/lib/cloud9/ENGI301/project
cd /var/lib/cloud9/ENGI301/project
./config_pins.sh
PYTHONPATH=/var/lib/cloud9/ENGI301/project python3 putt_main.py
Putt Project GitHub Repository
Grace Wilson
Grace Wilson
Thanks to Professor Welsh.
