Daniel Zoch
Automated PocketBeagle WiFi Access Point!
This project will help you set up your PocketBeagle to automatically create a WiFi access point on boot.
IntermediateWork in progress2 hours2,492
Netgear N150 Wifi Adapter
BeagleBoard.org PocketBeagle
Adafruit MicroUSB to USB adapter
Adafruit MicroUSB Breakout Board
Texas Instruments L298 Motor Driver
Soldering iron (generic)
How to connect the breakout board to the pocketbeagle
This diagram shows the breakout board with a MicroUSB to USB cable, but in the components portion you can find a breakout board that you can use in lieu of the cable. In my experience this helps keep the N150 adapter more stable.
You will have to solder the connections shown on the breakout board for the best experience with this setup.
Additionally, you do not have to use the Netgear N150 adapter, but the driver on the adapter you use has to be nl80211 for HostAPD to work.
Pocketbeagle DSTR Repository
Here's a walk-through on how to set up Hostapd, creating a WiFi script, and having the system run that script on boot. This walk-through also contains PWM and GPIO scripts for the Pocketbeagle.
Daniel Zoch
Daniel Zoch
Thanks to T Star, Mobile Integrated Solutions Laboratory at Texas A&M University, Roland Pelayo, and Cathy Wicks.
