Christina Mezmur
Published © GPL3+
Remote Control Car w/ PocketBeagle and Arduino
Have you ever wanted to use a PocketBeagle? And build a remote car? Well, I have! Here is how you can too!
IntermediateFull instructions provided10 hours5,479
BeagleBoard.org PocketBeagle
Arduino UNO & Genuino UNO
Bluetooth Low Energy (BLE) Module (Generic)
Spark-fun Multi-Chassis Basic 4WD Kit
Dual H-Bridge motor drivers L293D
Texas Instruments Dual H-Bridge motor drivers L293D
Anker PowerCore+ mini, 3350mAh Lipstick-Sized Portable Charger (3rd Generation, Premium Aluminum Power Bank), One of the Most Compact External Batteries
Resistor 10k ohm
Resistor 10k ohm
×4
Resistor 4.75k ohm
Resistor 4.75k ohm
×4
AA Batteries
AA Batteries
×2
9V battery (generic)
Arduino IDE
Arduino IDE
Adafruit Bluefruit LE Connect
Soldering iron (generic)
Fritzing Diagram
Cloud 9: Python RC_car
import random
# Constants
# Peripheral path
GPIO_BASE_PATH               = "/sys/class/gpio"
ADC_BASE_PATH                = "/sys/bus/iio/devices/iio:device0"
# GPIO direction (if it is outputting or inputting a signal to the GPIO)
IN                           = True
OUT                          = False
# GPIO output state
LOW                          = "0"
HIGH                         = "1"
#Motor 1
motor_1_ln1 				 = (0,30) #gpio30 P2_P5
motor_1_ln2					 = (0,31) #gpio31 P2_P7
motor_1_en1  				 = (1,28) #gpio60 P2_P8
#Motor 2
motor_2_ln4					 = (1,25) #gpio57 P2_P6
motor_2_ln3					 = (1,26) #gpio58 P2_P4
motor_2_en3					 = (1,27) #gpio59 P2_P2
#Motor 3
motor_3_ln1					 = (1,10) #gpio42 P1_P32
motor_3_ln2					 = (1,11) #gpio43 P1_P30
motor_3_en1					 = (0,26) #gpio26 P1_34
#Motor4
motor_4_ln4					 = (3,15) #gpio111 P1_33
motor_4_ln3					 = (2,24) #gpio88 P1_35
motor_4_en3					 = (3,14) #gpio110 P1_36
ard1                        =(3,20) #going to ard6
ard2                        =(3,17) #going to ard5
ard3                        =(3,16) #going to ard3
ard4                        =(3,19) #going to ard2
motor1						 = (motor_1_ln1, motor_1_ln2, motor_1_en1)
motor2						 = (motor_2_ln3, motor_2_ln4, motor_2_en3)
motor3						 = (motor_3_ln1, motor_3_ln2, motor_3_en1)
motor4						 = (motor_4_ln3, motor_4_ln4, motor_4_en3)
# Global variables
start_time                    = 30.0              # Start time (in seconds)
# GPIO / ADC access library
import os
def gpio_setup(gpio, direction, default_value=False):
    """Setup GPIO pin
      * Test if GPIO exists; if not create it
      * Set direction
      * Set default value
    gpio_number = str((gpio[0] * 32) + gpio[1])
    path        = "{0}/gpio{1}".format(GPIO_BASE_PATH, gpio_number)
    if not os.path.exists(path):
        # "echo {gpio_number} > {GPIO_BASE_PATH}/export"
        print("Create GPIO: {0}".format(gpio_number))
        with open("{0}/export".format(GPIO_BASE_PATH), 'w') as f:
            f.write(gpio_number)
    if direction:
        # "echo in > {path}/direction"
        with open("{0}/direction".format(path), 'w') as f:
            f.write("in")
        # "echo out > {path}/direction"
            f.write("out")
    if default_value:
        # "echo {default_value} > {path}/value"
        with open("{0}/value".format(path), 'w') as f:
            f.write(default_value)
# End def
def gpio_set(gpio, value):
    """Set GPIO ouptut value."""
    # "echo {value} > {path}/value"
        f.write(value)
# End def
def gpio_get(gpio):
    """Get GPIO input value."""
    # "cat {path}/value"
    with open("{0}/value".format(path), 'r') as f:
        out = f.read()
    return float(out)
# End def
def setforward(motor):
	gpio_set(motor[0],HIGH)
	gpio_set(motor[1],LOW)
#End def
def setbackward(motor):
	gpio_set(motor[0],LOW)
	gpio_set(motor[1],HIGH)
#End def
def move():
	gpio_set(motor1[2],HIGH)
	gpio_set(motor2[2],HIGH)
	gpio_set(motor3[2],HIGH)
	gpio_set(motor4[2],HIGH)
#End def
def stop():
	gpio_set(motor1[2],LOW)
	gpio_set(motor2[2],LOW)
	gpio_set(motor3[2],LOW)
	gpio_set(motor4[2],LOW)
#End def
def setleft():
	"""move the left wheels forward"""
	setforward(motor1)
	setforward(motor3)
	"""move the right wheels backward"""
	setbackward(motor2)
	setbackward(motor4)
#End def
def setright():
	"""move the left wheels backward"""
	setbackward(motor1)
	setbackward(motor3)
	"""move the right wheels forward"""
	setforward(motor2)
	setforward(motor4)
#End def
def setupcar():
	"""Setup gpio"""
	gpio_setup(motor_1_ln1, OUT, LOW)
	gpio_setup(motor_1_ln2, OUT, LOW)
	gpio_setup(motor_1_en1, OUT, LOW)
	"""motor 2"""
	gpio_setup(motor_2_ln3, OUT, LOW)
	gpio_setup(motor_2_ln4, OUT, LOW)
	gpio_setup(motor_2_en3, OUT, LOW)
	"""motor 3"""
	gpio_setup(motor_3_ln1, OUT, LOW)
	gpio_setup(motor_3_ln2, OUT, LOW)
	gpio_setup(motor_3_en1, OUT, LOW)
	"""motor 4"""
	gpio_setup(motor_4_ln3, OUT, LOW)
	gpio_setup(motor_4_ln4, OUT, LOW)
	gpio_setup(motor_4_en3, OUT, LOW)
	gpio_setup(ard1, IN)
	gpio_setup(ard2, IN)
	gpio_setup(ard3, IN)
	gpio_setup(ard4, IN)
#End def
def drive_forward(drivetime):
    setforward(motor1)
    setforward(motor2)
    setforward(motor3)
    setforward(motor4)
    move()
    time.sleep(drivetime)
    stop()
#End def
def drive_backward(drivetime):
    setbackward(motor1)
    setbackward(motor2)
    setbackward(motor3)
    setbackward(motor4)
    move()
    stop()
#End def
def drive_right(drivetime):
    setright()
    move()
    stop()
#End def
def drive_left(drivetime):
    setleft()
    move()
    stop()
#End def
# Main script
if __name__ == '__main__':
    setupcar()
    while (True):
        if gpio_get(ard1):
           # print("Forward")
            drive_forward(0.5)
        if gpio_get(ard2):
            #print("Backward")
            drive_backward(0.5)
        if gpio_get(ard3):
            #print("Right")
            drive_right(0.5)
        if gpio_get(ard4):
           # print("Left")
            drive_left(0.5)
Cloud9: Config Pins
#!/bin/bash
# Motion Detection Demo Pin Configuration
# Copyright 2017-18 Octavo Systems LLC
# Redistribution and use in source and binary forms, with or without modification,
# are permitted provided that the following conditions are met:
# 1. Redistributions of source code must retain the above copyright notice, this
   # list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright notice,
   # this list of conditions and the following disclaimer in the documentation and/or
   # other materials provided with the distribution.
# 3. Neither the name of the copyright holder nor the names of its contributors may be
   # used to endorse or promote products derived from this software without specific
   # prior written permission.
   # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
   # ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
   # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
   # IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
   # INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
   # BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
   # DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
   # LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
   # OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
   # ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# Auto-run script
# Add to crontab:
#   - In code directory <code>
#     1) mkdir logs
#     2) sudo crontab -e
#     3) @reboot sh <code>/run_motion_demo.sh > <code>/logs/cronlog 2>&1
# Reboot the PocketBeagle to then auto-run the program
/var/lib/cloud9/RCCar/config_pins.sh
python /var/lib/cloud9/RCCar/remotecontrolcar.py
Christina Mezmur
Christina Mezmur
1 project • 9 followers
I am a Mechanical Engineer student at Rice University in a Practical Electrical Engineering course.
