Cathy WicksEshtaartha Basu
Published © GPL3+
BeagleBoard PocketBeagle Halloween LED Pumpkin
Tech out your Halloween Pumpkin with PocketBeagle from BeagleBoard.org This low cost embedded 1GHz Linux PC is fun and easy to learn.
BeginnerFull instructions provided3 hours1,359
BC548 NPN Transistor
×7
BeagleBoard.org PocketBeagle
LED 5mm Red Clear Lens
×71
Breadboard (generic)
Jumper wires (generic)
Rotary potentiometer (generic)
1k Potentiometer should be used
PocketBeagle Halloween Pumpkin Blinky
LED blinky circuit to light up your favorite sketch!
PocketBeagle Halloween Pumpkin Fritzing File
LED blinky circuit Fritzing File to light up your favorite sketch!
This Python code can be used to control several sets of LEDs to light up your favorite sketch using PocketBeagle. Adafruit BeagleBone library (with PocketBeagle support) has been used to manage GPIOs.
1. Install the recommended Debian image and Adafruit BBIO libraries on PocketBeagle using the procedure given in https://github.com/adafruit/adafruit-beaglebone-io-python
2. Download pumpkinBlinky_v2.zip file. Extract the contents to the same directory.
3. Make the bash script executable by using the following command:
"chmod ugo+x pumpkinBlinkyScript.sh"
4. Run the bash script using the command "./pumpkinBlinkyScript.sh".
No preview (download only).
Cathy Wicks
Cathy Wicks
19 projects • 20 followers
Beagleboard.org fan
Eshtaartha Basu
Eshtaartha Basu
7 projects • 5 followers
Electrical Engineer by profession but love physics in general. I like to build stuff. Have been building electro-mechanical systems from 15y
Thanks to Adafruit.
