Babs  Ogunbanwo
Published © GPL3+
PocketBeagle Automatic Light Switch
Create an automatic light switch using a simple servo, PocketBeagle board, and Adafruit PIR motion sensor!
BeginnerFull instructions provided3 hours1,388
Solderless Breadboard Full Size
Female Header 20 Position 2 Row (0.1")
×2
PIR Motion Sensor (generic)
USB-A to Micro-USB Cable
Hitec HS-422 Servo Motor
MicroSD card
BeagleBoard.org PocketBeagle
Servo and Motion Sensor Connectivity
This is an example diagram for connecting the servo and PIR motion sensor to the pocketbeagle on a breadboard.
Servo Control Code Using PIR Motion Sensor
Open Cloud 9 (192.168.7.2:3000) on a web browser and add this python file to a directory.
# Import Libraries
# Initial Variables
servo = "P2_1"
pir_value = 0
PIR_PIN = "P2_4" # Pin number connected to PIR sensor output wire.
# Calibrate servo
PWM.start(servo,50,60)
time.sleep (1.0)
PWM.stop(servo)
PWM.cleanup()
# Get PIR Output
# Setup digital input for PIR sensor:
direction = GPIO.setup(PIR_PIN, GPIO.IN)
# Get PIR output from GPIO port
pir = GPIO.input(PIR_PIN)
# Main loop that will run forever:
old_value = pir_value
    pir_value = GPIO.input(PIR_PIN)
    print("pir_value = {0}".format(pir_value))
    if pir_value:
        # PIR is detecting movement!
        # Check if this is the first time movement was
        # detected and print a message
        if not old_value:
        # Rotate the servo CCW 180 degrees
            PWM.start(servo,0,60)
            time.sleep (1.0)
            PWM.stop(servo)
            PWM.cleanup()
            print('Motion detected!')
        # PIR is not detecting movement. Turn off LED.
        # Again check if this is the first time movement
        # stopped and print a message.
        if old_value:
        # Rotate the servo CW 180 degrees
            time.sleep (1.0)
            PWM.stop(servo)
            PWM.cleanup()
            print('No motion detected')
    time.sleep(5.0)
    # Press CTRL + C to end program
Babs  Ogunbanwo
Babs Ogunbanwo
Rice University Student
