Alvaro Castillo
Coffee Heater
Tired of drinking your coffee too cold or too hot? Fear no more! This device can keep your coffee at the perfect temperature.
IntermediateFull instructions provided690
Coffee Heater
BeagleBoard.org PocketBeagle
Male/Female Jumper Wires
Multi-Turn Precision Potentiometer- 10k ohms (25 Turn)
Li-Ion Battery 1000mAh
Darlington High Power Transistor
LEDs (generic)
×3
Resistor 1k ohm
Resistor 1k ohm
×3
Resistor 10k ohm
Resistor 10k ohm
×2
Adafruit Electric Heating Pad
1N4007 – High Voltage, High Current Rated Diode
Adafruit Hex Display
Adafruit Waterproof DS18B20 Digital temperature sensor
DC Voltage Regulator
Laser Cutter (generic)
Soldering Tool (generic)
Custom parts and enclosures
Coffee Heater Box
Box that houses the device
Wiring Diagram
Project Program
This is the code used for the device. You will need to update the path of the hex display library based on where you include the file (line 36).
Coffee Heater Project
License:
Copyright 2018 Alvaro Castillo
import sys
sys.path.append("/var/lib/cloud9/ENGI301/i2c/") #Path for the hex display library
import Adafruit_BBIO.ADC as ADC
import ht16k33_i2c as HT16K33
import os
import glob
# Global Variables
base_dir = '/sys/bus/w1/devices/'
device_folder = glob.glob(base_dir + '28*')[0]
device_file = device_folder + '/w1_slave'
# Main Tasks
def setup():
    """Setup the hardware components."""
    # Initialize Display
    HT16K33.display_setup()
    HT16K33.display_clear()
    #Set up the Analog input
    ADC.setup()
    #Set the GPIOS
    GPIO.setup("P2_18", GPIO.OUT)
    GPIO.setup("P2_20", GPIO.OUT)
    GPIO.setup("P2_22", GPIO.OUT)
    GPIO.setup("P2_24", GPIO.OUT)
    GPIO.output("P2_24", GPIO.LOW)
# End def
def read_temp_raw():
    f = open(device_file, 'r')
    lines = f.readlines()
    f.close()
    return lines
#End def
def read_temp():
    lines = read_temp_raw()
    while lines[0].strip()[-3:] != 'YES':
        time.sleep(0.2)
    equals_pos = lines[1].find('t=')
    if equals_pos != -1:
        temp_string = lines[1][equals_pos+2:]
        temp_c = float(temp_string) / 1000.0
        return temp_c
#End def
def cleanup():
    """Cleanup the hardware components."""
    # Set Display to something fun to show program is complete
    HT16K33.display_set_digit(0, 13)        # "D"
    HT16K33.display_set_digit(1, 14)        # "E"
    HT16K33.display_set_digit(2, 10)        # "A"
    HT16K33.display_set_digit(3, 13)        # "D"
    GPIO.output("P2_22", GPIO.LOW) #Blue LED
    GPIO.output("P2_20", GPIO.LOW) #Green LED
    GPIO.output("P2_18", GPIO.LOW) #Redb LED
# End def
def temp_test():
    while(1):
        #get the desired temp
        desired_temp = int(round (ADC.read ("P1_19")*100))
        #Update the display
        HT16K33.update_display(desired_temp)
        #get current temp
        current_temp = read_temp()
        # If the temperature is higher than desired temperature
        if(current_temp > desired_temp):
            #Temperetaure is too high, needs to cool down
            if (current_temp > (desired_temp + 5)):
                #Adjust the LEDs
                GPIO.output("P2_18", GPIO.HIGH) #Red LED
                #Turn off the heating pad
            #Temperature is OK
                #Adjust the LEDs
                GPIO.output("P2_18", GPIO.LOW) #Red LED
                GPIO.output("P2_20", GPIO.HIGH) #Green LED
        # If temperature is lower than desired temperature
        if(current_temp < desired_temp):
             #Adjust the LEDs
             GPIO.output("P2_22", GPIO.HIGH) #Blue LED
             #Turn on the heating pad
             GPIO.output("P2_24", GPIO.HIGH)
# End def
# Main script
if __name__ == '__main__':
    #Run the setup function
    setup()
    #Run the main function
        temp_test()
    except KeyboardInterrupt:
        pass
    #Run the clean up function
    cleanup()
    print("Program Complete.")
DTS File for the DS18B20 Temperature Sensor
Plain text
Use this file to compile the .dtbo file needed to interact with the temperature sensor.
 * Copyright (C) 2015 Robert Nelson <robertcnelson@gmail.com>
 * Virtual cape for onewire on connector pin P2_31
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
/dts-v1/;
/plugin/;
#include <dt-bindings/board/am335x-bbw-bbb-base.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/pinctrl/am33xx.h>
	 * Free up the pins used by the cape from the pinmux helpers.
	fragment@0 {
		target = <&ocp>;
		__overlay__ {
			P2_33_pinmux { status = "disabled"; };
	fragment@1 {
		target = <&am33xx_pinmux>;
		__overlay__ {
			dallas_w1_pins: pinmux_dallas_w1_pins {
				pinctrl-single,pins = <
					0x34 0x37
	fragment@2 {
		target-path="/";
		__overlay__ {
			onewire {
				status = "okay";
				pinctrl-names = "default";
				pinctrl-0 = <&dallas_w1_pins>;
				compatible = "w1-gpio";
				gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>;
Alvaro Castillo
Alvaro Castillo
